Eibach Pro Kit and BMR Pan hard - Mustang Evolution
Old 08-02-2012, 11:08 AM   #1
First post here,
Can I get by with using an Eibach pro-kit and BMR panhard bar at a minimum for right now? Car is a '12 GT with 1200 miles used mainly as a weekend car. How soon would I need to replace other parts? Is there anything else I should go with (camber bolts, strut mounts) My goal is to improve the aggressive stance of the car, sacrificing some ride quality is ok. Money is a little tight and how much would it be to install prokit and pan hard for my ride?
JayblesStang is offline   Reply With Quote
Old 08-02-2012, 11:35 AM   #2
GE3G's Avatar
You should be just fine... All ive done is the prokits and camber bolts and then alignment and she runs great
GE3G is offline   Reply With Quote
Old 08-02-2012, 11:47 AM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
That actually sounds like a great start! May need cc bolts or plates but isn't gonna hurt, install cost will vary by area, but shouldn't be much more than a few hundred
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 08-02-2012, 02:49 PM   #4
Re: Eibach Pro Kit and BMR Pan hard
Thanks for your responses. So, I think im gonna go with just the Pro Kit, Camber Bolt, and Pan Hard. If I was ordering from AM, it would be these
Eibach Mustang Pro-Alignment Camber Adjustment Bolts (05-13 All) 5.81260K - Free Shipping!
J&M Mustang Adjustable Panhard Rod (05-13 All) 23795B - Free Shipping!
and a pro kit for around 250 bucks. So around 450 for parts, 60-80 for an alignment. maybe 150 for install.
I'm looking at around 780 for the drop. Does this sound right?
How long until I should expect my stock shocks/struts to wear out?
Old 08-02-2012, 03:23 PM   #5
The Blue Dragon
50k on dampers, who is gonna do all that for $150 labor?
Old 08-02-2012, 03:48 PM   #6
I have a relative with a garage, maybe I can get it done for less. Thanks for the info.
Old 08-02-2012, 03:57 PM   #7
The Blue Dragon
O cool, good luck post pics
Old 08-03-2012, 10:21 AM   #8
Heres pics currently on stock cushy 4x4.
Old 08-03-2012, 10:58 AM   #9
I ordered an EIbach pro kit and a j&m panhard. I was told from a friend that has the same parts that I wouldn't need camber bolts. Would I need camber bolts? I don't mind having a little more camber around -1.5.
2012 Premium GT. Borla S-type catback
That Guy is offline   Reply With Quote
Old 08-03-2012, 11:17 AM   #10
The Blue Dragon
You might not mind it but your suspension and tires will wear more quickly
Old 08-03-2012, 12:18 PM   #11
-1.5 is a low amount of camber IMO. My tires won't see much of a difference the way I drive. I didn't buy this car to be easy on the tires and a little camber would help the cars cornering. How much camber would the front have on EIbach springs with no bolts?
Old 08-03-2012, 12:57 PM   #12
Ravnus's Avatar
Installed my Pro-Kit today..
[ATTACH]62053[/ATTACH
ID:	62053   Click image for larger version
Ravnus is offline   Reply With Quote
Old 08-03-2012, 05:20 PM   #13
Rolltide's Avatar
Bmr panhard and bmr springs
ID:	62070   Click image for larger version
Rolltide is offline   Reply With Quote
Old 08-03-2012, 06:34 PM   #14
Rolltide's Avatar
I installed mine in an hour and 30 min. Not bad at all
Old 11-02-2012, 03:24 PM   #15
So I put on steeda ultralites a week ago and will get it aligned today. Eventually Ill go with the konis, gt500 mounts, and phb. The ride is rougher over bumps but while cruising its exactly the same comfort level. I like the raked look and am pretty happy. The thing is i hear a squeaking noise coming from the rear and I hope its just the springs settling.
ID:	74467   Click image for larger version
Old 11-02-2012, 04:31 PM   #16
OzzyLiriano's Avatar
No you need to cut the yellow bushings i think they are called
OzzyLiriano is offline   Reply With Quote
Old 11-02-2012, 05:53 PM   #17
DWC_SmOziLLa's Avatar
They're called bump stops.
Old 11-03-2012, 09:46 AM   #18
Well im cuban man my bad, was trying to help
10:31 PM
