question on cold take off - Mustang Evolution
Old 08-04-2012, 11:04 AM   #1
BlueDemon's Avatar
Region: New Mexico
What's up guys/gals,
Quick question. I have noticed that some mornings/first start of the day my car will have a jerking feeling in first gear and sometimes second. It feels as if the clutch is going in and out. This mainly happens if i try to accelerate hard. It's only the first few 100 yards then it's normal and good to go.
Any suggestions?
Thanks in advance
2013 5.0, 6 speed manual, Brembo Pckg, 3.73 gears, American Thunder 40 series Flowmasters, 1 inch Lowering springs from Roush, J&M LCA, J&M Adj.Panhard bar, 20% Tint all around.
BlueDemon is offline   Reply With Quote
Old 08-04-2012, 11:13 AM   #2
Rynarok's Avatar
Re: question on cold take off
I get this same thing. Normally it acts like this for the first mile or so, but then it evens out and acts perfectly fine. I guess the transmission needs to warm up?
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 08-04-2012, 11:15 AM   #3
claudermilk's Avatar
I've noticed that as well. I just slip the clutch a bit, shift to 2nd & go. It's really only when I'm leaving the neighborhood, once I'm on the street it's all good. It is like the clutch is cold & grabby, causing the manual noob hobby-horsing.
claudermilk is offline   Reply With Quote
Old 08-04-2012, 11:17 AM   #4
CCS86's Avatar
Any suggestions?
Thanks in advance
You shouldn't be hammering on the car when the engine is cold. Over time this can cause damage. You shouldn't let it idle excessively when cold either. Just start it up and keep it under half throttle and 4000 rpm at least until the coolant starts to come up to temp.
That said, mine is a little herky jerky sometimes when cold at parking lot speeds. Doing some ~40mph cruising in fifth and sixth gear (1000-2000 rpm) seemed to help by giving the computer more time in that range to get the long term fuel trims sorted.
CCS86 is offline   Reply With Quote
Old 08-04-2012, 12:02 PM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
Mine used to do that then I did the idle relearn procedure and she is very tame when cold
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 08-04-2012, 12:16 PM   #6
DWC_SmOziLLa's Avatar
How do you do said procedure?
Old 08-04-2012, 12:24 PM   #7
The Blue Dragon
read post #1 by Azure
---------- Post added at 02:24 PM ---------- Previous post was at 02:23 PM ----------
might help if I added link
Idle re-learn - works!
Old 08-04-2012, 03:02 PM   #8
gweze001's Avatar
Wow, I can't wait to try this out.
gweze001 is offline   Reply With Quote
Old 08-04-2012, 03:04 PM   #9
The Blue Dragon
Yea, it's not completely cured but it is about 150x better
Old 08-04-2012, 03:18 PM   #10
BlueDemon's Avatar
Region: New Mexico
Thanks guys I'll have to try the reset.
Old 08-04-2012, 08:43 PM   #11
Do you notice any fluid leaking around the main seal area..I would make sure no fluid was getting on the clutch disc
mymustang is offline   Reply With Quote
Old 08-04-2012, 09:04 PM   #12
BlueDemon's Avatar
Region: New Mexico
No leaks man. I did the reset the guys were taking about. We'll see how that works out.
Old 08-04-2012, 09:20 PM   #13
Butch's Avatar
Region: New Mexico
Mine does it when its cold outside, all the time in the winter time but if I let her warm up for about 3 minutes she bogs then back to normal, if I take off before that she'll bog where ever im at, about after those 3 minutes. I dont know if that's the same deal with you but I hope this helps out to any point.
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 08-05-2012, 12:27 PM   #14
Mine will do it every once and a while. I recently did the idle relearn thing and so far its been better.
Old 08-19-2012, 06:21 AM   #15
I get this also and these cars are cold blooded pigs, mine runs like crap until it warms up completely, then she purres like a kitty, the harder you pound her the better she runs, but she needs lots of foreplay...lol
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
04:06 AM
