Oil Separator Education - Mustang Evolution
Old 08-14-2012, 05:46 AM   #1
So, my package from AM with rims, some vinyl, and my JLT Separator should be here today.
I totally understand my having the oil sucked back into the engine is a Bad Thing.
Couple of basic questions, just for educational purposes.
1) I understand that the passenger side is the one to get if you're only getting one ... why is this? I asked elsewhere and was told that the passenger side would capture more oil ... yeah, ok ... but WHY?
2) I see little discussion on what to do with the oil ... but I assume that putting it back into the engine would be a Bad Idea, correct?
3) Do all engines generally benefit from this sort of device? Or, is there something about our 5.0 engines that causes more oil to be collected here?
Thanks ... I like to fully understand things when possible.
mmike87 is offline   Reply With Quote
Old 08-14-2012, 09:11 AM   #2
claudermilk's Avatar
Re: Oil Separator Education
I'm just getting up to speed on this myself (and becoming convinced I ought to get one). From reading around the forums it seems the placement of the PCV valve has a lot to do with why the passenger side sucks most of the oil. I've also seen mentioned a few times to just dump the oil since it is now contaminated.
claudermilk is offline   Reply With Quote
Old 08-14-2012, 10:28 AM   #3
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
not to mention the passenger side one leads straight back in through your air intake. I have one installed on the passenger side and the way to think of it overall is that the system is constantly cycling from side to side so the oil vapors that come through the driver side will eventually end up over at the passenger side and get filtered out through the oil separator. Another thing I did is is disconnected the pcv from the driver and passenger side and the passenger side did have oil residue on it while the driver side did not.
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 08-14-2012, 10:52 AM   #4
There's two "sides" to your PCV system. The passenger side is the high pressure side, as that the side receiving most blow by gases and pumping losses from the crankcase and is subjected to post-throttle plate manifold pressure, which is usually high vacuum in most driving conditions. the system is closed so there isn't a major vacuum leak from this. The other side is open to atmo via the air filter and thus is only affected by intake flow velocity and atmo pressure.
Hence, putting the catch can in the place where the oil vapours are under the highest pressure, negative or positive, will yield the best results in operation.
That help explain it?
Old 08-14-2012, 10:53 AM   #5
OK, that makes sense.
My wife tells me my packages are waiting for me ... so I will do this install this evening. It appears to be very simple.
Old 08-14-2012, 05:55 PM   #6
CorDog009's Avatar
I need to pick up one. My LS cars would do the same thing and I used a small air/oil separator for an air compressor to catch the oil. These with the factory hoses will be much easier and look better too.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 08-14-2012, 07:08 PM   #7
Installed. Even easier than the easy I thought it would be. I did have to take the strut tower brace off to get the cover off ... maybe I could have gotten the hose off with it in place, but it only takes a few minutes to take it off. Used the opportunity to clean it up really well.
Old 08-15-2012, 12:00 AM   #8
gregtommy's Avatar
There you go and yeah it's easy to install n then just check it now and again
MOTM DEC 2011
Old 08-15-2012, 05:44 AM   #9
Yes, thanks. That was very helpful.
Old 08-15-2012, 09:19 AM   #10
Thanks, 5LHO. Nice clear explanation of what is going on. This mod will be done soon for me--probably right after the first oil change (dealer is covering that & I don't need to raise modding issues right away ).
Old 08-18-2012, 08:49 PM   #11
CorDog009's Avatar
I went ahead and ordered a JLT one a couple of days ago. I've got 2k miles on mine and need to go ahead and peek into the intake and see how much oil has made it in there so far.
Old 08-18-2012, 09:14 PM   #12
back n a stang's Avatar
I would not bother trying to look. Just put it on. You are good to go. The 1st 8-10,000 miles will use oil so keep a eye on that.It will scare the **** out of you.It's normal ring flutter break-in on these type motors.These motors are excellent.I have had hot rods from 60's to late model LS motors and other 5.0 from way back and I still think Ford has carried it to the future with this design.It will continue to get better.Not at all shabby now!! If you make close redline pulls or any racing keep a close eye on the oil.CAN'T say that enough.Be on very level ground when checking.Bad move if anybody thinks they can buy one of these cars and not even watch the oil till oil change time.That JLT catch can will collect some but just dump every 500 or so miles.Thats what I do.Never put back in the motor.And for god sakes do not stick just any oil, especially just any weight thinking you are doing something smart.The tolerances are so close that it's thin for a reason.If you want to know how your motor is doing internally......Collect a sample in one of BLACKSTONES bottles and send it in.Only 25.00. They will give you a real lab report.Just my .02
Old 08-19-2012, 08:03 AM   #13
I checked mine after just a short while and there was like a 1/2 teaspoon in there. I have been driving a little harder lately since the installation of the tune and I have been doing some data logging.
Old 08-19-2012, 10:39 AM   #14
That is all good and would be the case for mine too.
05:05 PM
