Amsoil manual trans fluid - Mustang Evolution
Old 08-15-2012, 02:37 PM   #1
gtstyles2's Avatar
I have just a little over 7000 miles and am finally planning to change the trans fluid. I hear amsoil is the best choice, but I haven't found a good website that specifies the correct weight I should use... I also have the Barton shifter with the two post bracket on order. Can anyone fill me in on which specific fluid to get?
Old 08-15-2012, 02:42 PM   #2
Napoleon85's Avatar
MTG
Btw, it's great in summer but might not be ideal in cold weather
Old 08-15-2012, 02:45 PM   #3
gtstyles2's Avatar
Originally Posted by Napoleon85
MTG
Ok , does it come in different weights? Or just MTG? That's what I was confused about.... I don't have any issues whatsoever, but I want to do everything possible so I won't have issues later.
Old 08-15-2012, 02:58 PM   #4
Napoleon85's Avatar
Re: Amsoil manual trans fluid
No, MTG is a specific product.
AMSOIL - Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 (MTG)
Old 08-15-2012, 03:13 PM   #5
gtstyles2's Avatar
Cool, 2.7 qts it takes right? What's the best way to fill? I have no idea what it looks like underneath
Old 08-15-2012, 04:58 PM   #6
Napoleon85's Avatar
It's tricky. I had a thread on it last winter that you should look up.
Old 08-17-2012, 12:01 PM   #7
Along with the Amsoil you need to add a friction modifier. Says which to order on the Amsoil website.
2012 GT Coupe Premium 6 speed MT with 3.73 option, black on black
pcarman is offline   Reply With Quote
Old 08-22-2012, 12:28 PM   #8
Napoleon85's Avatar
I've never heard of anyone adding a friction modifier with mtg in a mt82. Are you sure you aren't thinking of the rear end?
Old 08-22-2012, 01:01 PM   #9
Darn it you're right. Did both at the same time and got them confused. Sorry about that.
Old 08-22-2012, 08:07 PM   #10
gtstyles2's Avatar
I finally wedged myself under the car to get an idea how to change the trans fluid and was wondering which of these is the fill plug?? I can clearly see the drain, but I'm assuming the fill plug is the one with the yellow mark? And not that one all the way up top??
ID:	65154   Click image for larger version
Old 08-22-2012, 09:16 PM   #11
Napoleon85's Avatar
Yes, that looks like it. See this to be sure:
Ford Service Manuals - GENERAL PROCEDURES
---------- Post added at 11:16 PM ---------- Previous post was at 11:12 PM ----------
PS - it should say "FILL" directly above the plug, just like the label by the drain plug.
Old 08-25-2012, 10:54 AM   #12
gtstyles2's Avatar
I know this subjects beat to death by now, I still haven't pulled the trigger yet... only because I know amsoil is great for the summer but not so good in the winter... its not my DD, but in the winter here and there I take my car out when the roads are clean and not salty. I was wondering if Redline MTL is a good one to go with, supposedly being better than the stock crap that most believe it is. I just don't want to replace the fluid every season, since I don't drive my car that much, I probably only get to drive 4-6K a year, so whatever I put in, I need the piece of mind of knowing I have good stuff w/o the worry of replacing the fluid all the time
Old 08-25-2012, 04:58 PM   #13
drivinglesson's Avatar
Just do it, you will wonder what took you so long. Stay with a major brand and you will be fine. I chose Royal Purple max gear due to availability, and was really pissed I hadn't made the switch sooner; that was my only regret. Just do it.
2016 Mustang GT
drivinglesson is offline   Reply With Quote
Old 08-25-2012, 11:34 PM   #14
gtstyles2's Avatar
Yea I guess I might as well go with the Amsoil, my garage isn't really heated but it stays around 40-50 degrees which isn't that bad... guess its better than the ones that stay out in the freezing zero degree cold. I'm just paranoid going the DIY approach and then the trans decides to grenade on me and warranty won't cover me cuz I did the fluid swap myself and not at an approved shop... I'm not having issues, but I have noticed the gears crunching a bit now, and I'm almost certain Ford dealership is gonna say its normal. Hate taking my car there, techs don't know anything, and the service advisors come and go there pretty often
07:08 AM
