New sticky tires and LCAs - Mustang Evolution
Old 08-17-2012, 05:49 PM   #1
Jetag93's Avatar
BFG comp2 275/40ZR19s and UPR Billet Alum Rear LCA's installed today. LCA's courtesy of a tip from Napoleon85. They are sexy!
ID:	64294   Click image for larger version
ID:	64296   Click image for larger version
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 08-17-2012, 06:34 PM   #2
back n a stang's Avatar
Re: New sticky tires and LCAs
Do those have poly bushings and on both ends? Just a few dollars to replace but the aggravation of pulling them is the not so good part. I see you are manual so be easy on major heavy launches. If you ever plan to drag strip with drag radials or slicks you will split them. Common problem. You can bet if you burn out and launch at 6000 or even 5000 + RPM's they will split. Just a heads up. Stands the reason I went with BMR QA1 solid teflon ends and of course adjustable. Hey, I am not knocking them.Hell, I have mine riding in the trunk for 7 months. Never put on yet. Paid a pretty penny for them. BMR# TA-020 I think is the number. They use them on their track car. I just know they are gonna give alot of NVH and clunk with them but they will damn sure hook and hold when I do. I figure when I buy some 15'' rear weld racing wheels or race stars then I will put them on and head to the track.I got several tracks not to far from me. Rockingham has test and tunes and fayetteville has alot happening on w/e's. I may buy some that are just affordable like J&M and try out around town.I don't do much burning rubber for nothing or launching beyond my tire ability so they would be worth the having. My next purchase is springs and some more susp. stuff. Want that MGW though bad. It will just have to wait. Funds are pretty dried up...LOL. You car is looking good man,
Old 08-17-2012, 06:45 PM   #3
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Damn I love the color of your car!
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 08-17-2012, 06:50 PM   #4
Jetag93's Avatar
Yea, 3 piece poly urethane bushings. Don't have any plans for that type of hard launching but we'll see. They say the 3 piece bushing design absorbs energy to stop wheel hop. Hopefully they won't come apart any time soon!
Old 08-17-2012, 06:52 PM   #5
Pretty car
Old 08-17-2012, 09:34 PM   #6
Ravnus's Avatar
Nice tires...i have the same ones. They hook really well. I love them so far
Ravnus is offline   Reply With Quote
Old 08-17-2012, 10:16 PM   #7
Jetag93's Avatar
Great to hear!
Old 08-18-2012, 12:04 AM   #8
DWC_SmOziLLa's Avatar
How did you fit a 275 on a 8.5" wheel?
Old 08-18-2012, 12:15 AM   #9
11stangGT's Avatar
Region: Arkansas
I had 275s on my 04 gt's factory 17x8 bullits
Bama 93 race tune, bbk o/r xpipe, gt500 axle backs, frpp k-springs, steeda rear lca's, 3d carbon 3d500 wing, boss/cs front fascia w boss brake cooling kit, plenty more...
11stangGT is offline   Reply With Quote
Old 08-18-2012, 02:37 AM   #10
I had 285/35/19 on the rear of mine when I was still running the Brembo wheels. We are talking about the OEM 19x9" wheel. I run 245/40/19 fronts amd 285 35/19 in the rear.Alot of times man, you can go on tirerack and it will automatically tell u the tires sizes compatible. The misconception is some are slightly different than others and what not! My next purchase is for sure springs.I got some agjustable LCA's to put on too.I think I found some 15'' weld racing rears.If I can get them right and just wheels I will snag them. One guy about 25 miles from me has some nice 15'' weld but the front are like 15'too.so, I don't know yet.I got several good wheels to go look mat. on the slicks or Dr
Old 08-18-2012, 07:20 AM   #11
Jetag93's Avatar
275 is the widest recommended size for 8.5, but they don't look to big at all and they handle great.
Old 08-18-2012, 10:30 AM   #12
I have always read 255s were the widest recommended. I could be wrong though. I have put a few posts on here about it and everybody always said 255s on 8.5" wheels. I just worry about the 275s, looking at your pics it seems the bead is excessively pulled in and the sidewalls are budged out, this leaves me to be concerned about the tire wanting to bulge a little in the center of the tread, similar to over inflation, and cause excessive tread wear down the middle of the tread. Keep us posted on your tire wear. Good luck!
01:28 AM
