Removed hood blanket - Mustang Evolution
Old 08-17-2012, 04:53 PM   #1
TommyV's Avatar
Due to the high temps plus high humidity in San Diego lately, along with C&L's high IAT's, I decided to remove the hood blanket. I didn't realize how much heat was being blocked from the hood vents by the blanket. When I put my hand over the vents now, you can really feel the heat escaping. Plus, I can hear the C&L sucking even more now!
I thought it would look worse. There's an area in the middle that needs some paint but I can do that with a rattle can. I've read that others have had theirs off for years with no paint problems, and with the vents, it should help.
I don't drive in the rain much, but if I do, I'll just have to clean the engine bay a little more.
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 08-17-2012, 05:04 PM   #2
maldog's Avatar
Region: Nevada
Re: Removed hood blanket
It looks good. I'm not sure, but in the old days if you took off the heat blanket paint on the hood would start to peal and bubble up. I'm sure the automotive paints now a days are much better?
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-17-2012, 05:11 PM   #3
It's not me, it's you.
primer2tone's Avatar
That's what I was thinking too. I imagine the extractors will disburse a lot more heat now, so maybe he won't have that issue.
The only think I'd say is, keep the blanket just I'm case you run into any problems.
Old 08-17-2012, 05:14 PM   #4
Jetag93's Avatar
Have your inlet air temps decreased?
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 08-17-2012, 06:34 PM   #5
CorDog009's Avatar
+1. Also, how much weight do you think it removed?
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 08-17-2012, 07:30 PM   #6
TommyV's Avatar
Yeah, I think the new paints hold up much better.
Originally Posted by primer2tone View Post
That's what I was thinking too. I imagine the extractors will disburse a lot more heat now, so maybe he won't have that issue. The only think I'd say is, keep the blanket just I'm case you run into any problems.
I plan on keeping it.
Just got back, 95 deg outside. From my 20 min drive, it appears that the temps are about 8 to 10 deg. less than before, relative to the ambient air temp. They also take longer to rise when stopped and drop more quickly when moving.
Probably a couple of pounds.
Old 08-17-2012, 08:41 PM   #7
lilredgt's Avatar
I've been wanting to remove mine, but I wasn't sure what the ramifications would be. I'm not all that car savvy, all I know is that it's kinda ugly.
lilredgt is offline   Reply With Quote
Old 08-17-2012, 08:48 PM   #8
TommyV's Avatar
Yeah, if I attend any car shows, I'll throw it back on.
Old 08-20-2012, 02:33 PM   #9
Jetag93's Avatar
I removed mine today and drove back roads for an hour. I saw the same temp decrease. My inlet air temps are only 2 deg over ambient air when moving. When stopped at a light it creeps up much more slowly and drops back down to almost ambient temp much more quickly. Cooler air makes more power. I like it!
Old 08-20-2012, 02:40 PM   #10
seems like water will get on your air filter~
Old 08-20-2012, 02:46 PM   #11
Jetag93's Avatar
Actually, the hood blanket catches the water and funnels it down where it dumps directly on the air intake. Without the blanket water will disperse better well in back if the air intake. But, I'm running the stock air box so the water isn't an issue either way.
09:58 PM
