ride hieght 2012 5.0 - Mustang Evolution
Old 08-18-2012, 02:44 PM   #1
does anyone know the measurment from wheel center cap to fender or from ground to fender well? I just lowered mine and forgot to take measurments and im not convinced it lowered it the inch??
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 08-18-2012, 03:03 PM   #2
Jetag93's Avatar
My 13 measured 29 1/8 Front & 30 1/4 rear.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 08-18-2012, 03:07 PM   #3
5pointOh's Avatar
Re: ride hieght 2012 5.0
What springs did you use to lower it? Visually, small differences are a little hard to notice. They might drop a little more once the springs settle..
2012 kona blue gt, GT500 exhaust, tinted windows, J&M Panhard bar, Steeda Ultralites, Koni STR shocks and struts, GT500 strut mounts, SR Performance shifter, Steeda Shifter Bracket, 20" Giovanna Monzas..damn I need more money!!
5pointOh is offline   Reply With Quote
Old 08-18-2012, 03:11 PM   #4
mine is 28 3/4 front and 29 1/8 rear I forgot to measure before but I really think it didnt come close to an inch drop?
---------- Post added at 05:11 PM ---------- Previous post was at 05:09 PM ----------
I used the roush susp. pack, struts, shocks springs and swaybars, dont get me wrong it is a handling dream...!
Old 08-18-2012, 04:25 PM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
How long ago? Needs time to settle too
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 08-18-2012, 07:52 PM   #6
its only been a day, i didnt know it needed time to settle.. kinda new to the lowering process..
09:44 PM
