How can you tell what rear end you got? - Mustang Evolution
Old 08-19-2012, 08:26 AM   #1
Am3gross's Avatar
I have a 13 gt and the sticker does not say what rearend... is there a way to tell?
2013 ford mustang gt, black, bought 16th of August. Only mod so far is tinted windows.
Am3gross is offline   Reply With Quote
Old 08-19-2012, 09:09 AM   #2
maldog's Avatar
Region: Nevada
Re: How can you tell what rear end you got?
How to Find Out Your Gear Ratio on a Ford Mustang | eHow.com
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-19-2012, 09:18 AM   #3
Jetag93's Avatar
If u don't see an upgrade to 3.55 or 3.73 on ur sticker then u have 3.31 for Manual trans or 3.15 I think for auto.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 08-19-2012, 09:23 AM   #4
Smoke's Avatar
Look under the car at the rearend its a sticker that will tell u
Smoke is offline   Reply With Quote
Old 08-19-2012, 09:28 AM   #5
SolidRRaxle's Avatar
Read 'a smaller gear will increase acceleration but has lower mpg.'
I read it twice, last sentence of the first long paragraph... Have I been working under all the wrong assumptions for years!? Higher gears have better mpg and top speeds?! That link is tarded, I wouldn't suggest using that as a learning tool.
SolidRRaxle is offline   Reply With Quote
Old 08-19-2012, 10:37 AM   #6
back n a stang's Avatar
you can get the info right off the diff. on the white sticker(s) or you can de-code it by the numbers on the sticker in your door. I can decifer it.Just don't have the info in front of me......but a example and do not think this is accurate,but, BB=3.73
Old 08-19-2012, 10:59 AM   #7
Blue2013's Avatar
+1
Ordered 7/14/2012 VIN 7/30/2012 Window Sticker 8/17/2012 Build 8/20/2012 ETA 8/31/2012 New ETA 9/3/2012 New ETA 9/17 - Cancelled...
2013 Grabber Blue GT
Blue2013 is offline   Reply With Quote
06:26 AM
