hp loss with 4.10 gears - Mustang Evolution
Old 08-22-2012, 09:16 AM   #1
Just curious what do you lose for hp numbers on the dyno with 4.10 gears rather than 3.55 or 3.31? I know you dont actually lose it but just wondering if there was an estimate in hp loss?
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 08-22-2012, 09:31 AM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Yea, like you said you don't actually lose power but the way the tq is multiplied and converted and all that crap by the gears will how lower hp numbers with shorter gears.
Borii is pretty good with this stuff, hopefully he'll chime in
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 08-22-2012, 09:37 AM   #3
Re: hp loss with 4.10 gears
im sure its been discussed a million times, i am just curious, 4.10's are really fun but would like to know what im losing on the dyno, even if its just a rough estimate
Old 08-22-2012, 09:49 AM   #4
Napoleon85's Avatar
Why does it matter/do you care if the dyno reads slightly lower? If the 4.10s suit your goals and needs, then install them. A dyno is nothing more than a tuning tool to measure immediate changes on the same car/day/dyno and make adjustments. What it reads at any given point outside of that context is a relatively useless number.
Old 08-22-2012, 09:56 AM   #5
The Blue Dragon
I think he's already got 4.10's and is curious what the dyno would read with other gears.
I do agree though, it doesn't really matter if you're having fun with it but it doesn't hurt to know for the sake of knowledge either
Old 08-22-2012, 10:14 AM   #6
its all good guys?? im only asking...i could really care less what the dyno tells me, i just wanted an estimate in what i lose with 4.10 gears? and i just read that it could be 20 hp on the dyno and if i lose 20 hp on the dyno then yeah i would like to know that...and as for how my car feels? well i love it...im only asking a question here and thats what i thought these forums were for?
---------- Post added at 12:14 PM ---------- Previous post was at 12:11 PM ----------
430 rwhp sounds alot better in my head rather than 407 after all the mods and money, but numbers mean diddly if you cant drive it.
Old 08-22-2012, 10:27 AM   #7
Napoleon85's Avatar
The short answer is, "it depends." way are you comparing it to (3.15. 3.31, 3.55, 3.73, 3.90)? Basically, you can tell (kinda) if you have an old dyno graph with the gears you want to compare to and a rpm-wheel speed calculator. But it varies from car, dyno, day, and a million other things.
Old 08-22-2012, 10:41 AM   #8
I understand there is a million variables... all im saying is it doesnt matter what your setup is if you dyno with 3.31 gears you will have a considerable hp increase over dyno'ing with 4.10's regardless of the mods or anything and i was only wondering what the loss was on average for the gears and i got my answer...it could be as much as 20 plus hp ....and thats nice to know, not that it matters really but its nice to know the loss.
Old 08-22-2012, 11:00 AM   #9
The Blue Dragon
I'm just making sure you don't get your head wrapped around it too much is all. Dyno numbers are cool but at the end of the day don't mean much with how easily they can be messed up by a number of variables. And I k ow you know, just reinforcing
Old 08-22-2012, 11:02 AM   #10
Napoleon85's Avatar
Well it isn't really a flat number ... that's why it's so complicated. A percentage of loss would be a better way to express it, but it's really tied to the wheel speed/redline/efective gear ratio relationship. Tire size has an effect on the dyno results as well for the same reason.
So, assuming stock tire size and rev limiter ...
As you can see the wheel speed is slower as you put steeper gears in the car, despite the engine turning at the same RPM. This causes the dyno to read less power progressively for each gear.
So if you were to use 3.31 as a baseline, you would see approximately 92.98% of the power with 3.55s, 88.88% with 3.73s, and 80.70% with 4.10s. This is a gross estimation, and will likely be way off, but if you insist on having some form of comparison, you can take you dyno sheets with 3.31s and multiply by that percentage to get a ballpark estimate of where you will be now (were it the same dyno, same car, same day).
If you don't have a baseline dyno, then there really isn't anything to do but take a completely uneducated guess. The numbers you put down will vary based on the fuel you're running, the weather conditions, and the calibration of the dyno, not to mention all of the factors discussed above. You can take a stock car to a well calibrated dyno and a poorly (intentionally or unintentionally) calibrated dyno and see huge variances, so there is no way for us to guess what numbers your car will put down.
Old 08-22-2012, 11:13 AM   #11
yeah i made the mistake of not getting my car dyno'd before and after, I already have the 4.10's and love them but i was just curious to what i was giving up on the dyno, i was 407 with the 4.10's and i was just on kennebell's website and they say you would lose 18 hp with 3.73's and more with 4.10's so it was just a thought no real big deal but it wouldve been nice to know what it was before and after.
Old 08-22-2012, 11:27 AM   #12
Napoleon85's Avatar
You're down about 20% TQ for the same RPM range, which is what I was referring to by "power" and is the number that's the most important. HP is a function of RPM and TQ.
The forumla for HP is HP = 2╥(T)(RPM) / 33000
T= TQ in lb/ft
RPM = the corresponding RPM of the engine at the corresponding moment of the TQ number above
So if you take your peak torque, multiply it by 0.807 and then plug that number into the formula above, you will have an approximation of what your HP number may have been.
Now ... I think you owe me a beer.
---------- Post added at 01:27 PM ---------- Previous post was at 01:25 PM ----------
Also, if you don't have a torque number for the exact same spot as your peak HP number, you could use the following formula to derive torque from the peak HP reading, then proceed as above.
T = HP(33000) / 2╥(RPM)
Old 08-22-2012, 12:04 PM   #13
Skulls98GT's Avatar
T= TQ in lb/ft
Is there an app for that.
Skulls98GT is offline   Reply With Quote
Old 08-22-2012, 12:07 PM   #14
Napoleon85's Avatar
Old 08-22-2012, 12:16 PM   #15
Edens5's Avatar
Hahahahaahahaha^^^ that made my day.
Edens5 is offline   Reply With Quote
Old 08-22-2012, 12:31 PM   #16
Skulls98GT's Avatar
LMFAO
Old 08-22-2012, 01:36 PM   #17
my torque was 355 so i will give u that beer but u gotto do that math for me...lol
---------- Post added at 03:22 PM ---------- Previous post was at 03:15 PM ----------
hp 407 tq355 @ 6700rpms?
---------- Post added at 03:25 PM ---------- Previous post was at 03:22 PM ----------
i wrote that crap all wrong im trying to load my chart?
---------- Post added at 03:31 PM ---------- Previous post was at 03:25 PM ----------
i cant load my graph, but it looks like its 355 tq @ 4700 rpms
---------- Post added at 03:36 PM ---------- Previous post was at 03:31 PM ----------
ok i will try that again peak tq was 355 @ 4700rpms and hp was 407 @ 6700rpms does that make sense?
08:54 AM
