Slotted rotor sound question - Mustang Evolution
Old 08-24-2012, 11:43 PM   #1
nhcowboy's Avatar
Recently replaced the fronts with a 4 piston 14" slotted rotor and the rears with 13" rotor only...
I've read a lot of conflicting info and need my brake experts here to help me out.
5 - 20 mph with windows down, I hear a faint "Brushing" sound reflected off things as I drive by... No pressure applied to the pedal. No unusual clicks or squeaking under braking and they perform great... Is the light sound typical due to the slots? I did perform complete break in cycles with the new pads (Hawk HPS).
My mechanic said it was normal due to the slots and cross-thatching. Not sure I buy that.
Thanks.
Thanks!
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 08-25-2012, 12:11 AM   #2
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
Honestly slotted/drilled rotors make a little more noise.
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
gregtommy is offline   Reply With Quote
Old 08-25-2012, 12:21 AM   #3
nhcowboy's Avatar
Good to know... Just didn't want to find out my shop didn't align the calipers up right or something.
12.538 ET @112.33
Old 08-25-2012, 12:24 AM   #4
gregtommy's Avatar
Yeah ur fine, just as long as it isn't constant
MOTM DEC 2011
Old 08-25-2012, 12:26 AM   #5
nhcowboy's Avatar
Well, that was my concern. It is constant. I just can't hear it beyond 30 mph due to wind/road noise. But it isn't a clicking or grinding...
12.538 ET @112.33
Old 08-25-2012, 12:29 AM   #6
gregtommy's Avatar
They may have not put brake quieter on the back of the pad which prevents the metallic squeak of the pad n the bracket.
MOTM DEC 2011
Old 08-25-2012, 04:43 AM   #7
Mine do it. You get used to it after a while
Old 08-25-2012, 07:08 PM   #8
Re: Slotted rotor sound question
normal noise
Lugnut is offline   Reply With Quote
Old 08-25-2012, 07:15 PM   #9
nhcowboy's Avatar
Thanks guys
12.538 ET @112.33
Old 08-26-2012, 02:26 PM   #10
Stang8psi's Avatar
Region: Delaware
normal noise! it's the wind and air going through the slots
Stang8psi is offline   Reply With Quote
Old 09-24-2012, 05:35 PM   #11
Thanks.
Thanks!
I'm on the same boat as you. I had Steeda's slotted rotors kit installed last week (item 555-6015) and when I returned home from bedding in the rotors I could hear the same faint brushing sound as I was coasting in neutral with no brakes applied. My initial concern was that the pads might be dragging but the shop pretty much gave me the same response, that this sound is typical of slotted rotors. When braking the brakes sound/feel normal to me, or at least nothing catches my attention over my Borlas.
I'm still trying to find another Mustang owner with this same kit that can tell me if they're experiencing the same thing to ease my mind. You said you replaced the rotor only in the rear, you wouldn't happen to have the same kit would you?
fastandcurious is offline   Reply With Quote
Old 09-24-2012, 05:41 PM   #12
nhcowboy's Avatar
Not sure... It was the rear upgrade kit (13" rotor [dba], caliper relo bracket [had to pull the axles]).
I added hawk HPS pads.
Probably the same kit.
12.538 ET @112.33
Old 09-24-2012, 06:02 PM   #13
It's a normal sound. I enjoy it personallu
Old 09-25-2012, 08:42 AM   #14
claudermilk's Avatar
I'm still on stock rotors on the Mustang, but I switched to slotted on the last car & it's a normal sound. I ran those rotors for over 100k with no problems or unusual wear.
claudermilk is offline   Reply With Quote
03:55 AM
