E85 - Mustang Evolution
Old 08-27-2012, 04:01 PM   #1
E85
If i want to re-tune for E85, all i need to do is upgrade my Injectors right? If so, what size should i get 47LB, 60LB or larger? and what brand would you recomend?
Black 2012 Mustang GT 6MT mods: Borla S-type cat backs, 15% window tint, Raxiom Smoked headlights, Pioneer 8400, scosche dash kit, hertz speakers, JL Audio 500 watt amp, 2 JL audio 12" W3 subs. *more to come*
D00m3dHitm4n is offline   Reply With Quote
Old 08-27-2012, 05:37 PM   #2
stangaroo's Avatar
Actually all you need is a tune I think the hardware is all compatible, I know AED has one running e85 and I'm pretty sure the only hardware change they made at first was offroad h pipe
2008 4.0 SOLD (I will miss my first stang forever)
2011 5.0 black on black with 3.73 manual and I still get over 26 mpg
stangaroo is offline   Reply With Quote
Old 08-27-2012, 09:26 PM   #3
Redsteel's Avatar
You must use 40% more e85 to get the same power output of gas. So 1.6 gallons of e85 has the same chemical energy as 1 gallon of gas. Thought about doin tjis on my fox, so I've looked into it. Also you need steel fuel lines as the e85 will eat through rubber lines. Hope this helps.
---------- Post added at 11:26 PM ---------- Previous post was at 11:26 PM ----------
You must use 40% more e85 to get the same power output of gas. So 1.4 gallons of e85 has the same chemical energy as 1 gallon of gas. Thought about doin tjis on my fox, so I've looked into it. Also you need steel fuel lines as the e85 will eat through rubber lines. Hope this helps.
Redsteel is offline   Reply With Quote
07:51 PM
