Additional parts needed to lower - Mustang Evolution
Old 08-29-2012, 06:52 AM   #1
11grabberblueGT's Avatar
I am about to lower my '11 GT with some h&r springs. 1.7" in front, 2.4" in rear. On previous models, this has really been the only equipment needed but I've read on here where with the new body style ('10+), you have to buy LCA relocation brackets and such. For those who have used springs to lower, what else is essential? Not looking to spend unnecessary money on things that would be helpful. I want simply the essential parts at the moment..
11grabberblueGT is offline   Reply With Quote
Old 08-29-2012, 07:03 AM   #2
Jetag93's Avatar
Re: Additional parts needed to lower
I lowered mine with the same springs and didn't need anything else. I just had it aligned, after a few weeks for it to settle, and camber was still spot on. You may want the GT500 strut mounts if your mileage is more than 5k. The stock mounts tend to fall apart if not new.
2013 DIB Premium GT/CS, 6MT, Cervinis Ram-Air Hood, RTR Charcoal 19X9.5s, BBK Cat Deletes & X-Pipe, DMH E-Cutouts, GT500 Rear Diffuser w/GT500 Quad-tip Axle-Backs, AED E85 Lope Tune, Boss 302 Intake, BBK 85mm TB, JLT CAI, Dynatech Alum DS, FRPP 3.73's, Eibach Pro-Springs and Pro-Struts/shocks, J&M Adj Panhard Bar, UPR Billet Alum LCA's, BMR UCA & Bracket & Relo Brackets, Eibach Adj Sway Bars, MGW Shifter, Brembo brake kit w/14" slotted 2 piece Boogie Full Tilt Racing Rotors, Llumar 30/5 Tint
Jetag93 is offline   Reply With Quote
Old 08-29-2012, 07:54 AM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
Adjustable panhard rod is a must to recenter rear axle, MAY need camber bolts as well
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 08-29-2012, 08:18 AM   #4
Napoleon85's Avatar
You don't have to have anything else, but an adjustable panhard bar may be in order if your rear end shifts too much. It's not very noticeable on the stock pizza cutters, but if you have decent sized tires on the rear it becomes more obvious. Adjustable control arms are also optional, and are used to correct the pinion angle and rear end geometry. Camber bolts or plates can be used in the front to correct for the negative camber you get when lowering. The negative camber won't hurt anything but your tires...
---------- Post added at 10:18 AM ---------- Previous post was at 10:18 AM ----------
Lca relocation brackets are generally only used with solid LCAs btw.
10:57 AM
