Performance issue - Mustang Evolution
Old 08-29-2012, 07:11 AM   #1
Region: Vermont
Send a message via AIM to GBlueGT
Performance issue
Guys this maybe just me but, Iv'e been driving my car alot lately and sometimes it seems like when in third gear, it pulls hard and other times it seems slow to rev? and pull hard. Is it just me or is there an issue with these 2013 cars I dont know about.
Rob
GBlueGT is offline   Reply With Quote
Old 08-29-2012, 07:48 AM   #2
SolidRRaxle's Avatar
Rob
I just posted a thread on this. 'power just drops off'. This is also in third btw, sounds like a fit.
Not much in the way of answers other than 'get a tune'. But on the same day there was a thread on SCT tuners bricking cars....
I am getting the Procal tuner on Tuesday. Will update you on whether or not this helps.
Also, where (region) are you located? Weather (heat) when it happens? Details on your car? Mine is a track pack, 2013, 3.73 gears and 1300 miles.
SolidRRaxle is offline   Reply With Quote
Old 08-29-2012, 08:00 AM   #3
Rynarok's Avatar
Re: Performance issue
Try turning the traction control off, or put advancetrac in sport mode (doubletap the traction control button with the brake pressed).
The nannies in the '13 are very restrictive. Mine acts funny when I get aggressive and traction control is still on...sometimes it just cuts nearly all power on a shift, or it will bog down when i apply the gas, seems to be most noticeable on the 1st-2nd-3rd gear shifts, too. Also happens when you do that 6th to 3rd downshift at highway speeds >
I haven't had a single issue with it when I have sport mode turned on.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 08-30-2012, 11:52 AM   #4
Region: Vermont
I live in Vermont, 331 gears, 20 inch rubber,running 93 octane fuel. 2013 GT with 1200 miles on it so far. I just love the car.
Rob
Old 08-30-2012, 12:00 PM   #5
Intricate30's Avatar
This is 100% your advance trac.
---------- Post added at 12:00 PM ---------- Previous post was at 11:58 AM ----------
If you want the least restrictive setting just turn the car on, hold the brake and hold the trac button down for 7 seconds. You should see the display read that advance trac is off. Could lead to a very loose rear end. Have fun!!!
Intricate30 is offline   Reply With Quote
Old 08-30-2012, 01:46 PM   #6
I did this this morning for 'fun'. I (violently!) spun through first and second and had to drop straight to fourth. Went back home for lunch and saw the insane, dark black tires marks on the way out of the neighborhood. It is fun, but definitely be careful
Old 08-31-2012, 10:10 AM   #7
Serious fun but definitely be careful!!!
04:03 AM
