My Paxton Install Experience - Mustang Evolution
Old 08-29-2012, 08:17 PM   #1
Jukens's Avatar
Well I finally have my Paxton supercharger kit installed and finished besides getting my vortech pump booster to work correctly. Here's my story:
Early June I get the go ahead from the wife. I'm currently stationed in Ft Gordon, Georgia but they have a great shop that I can do the install at so I make the call for the order to Terry from beefcake racing. Great help over the phone and helping me get everything I need. He up sales me the ID1000 injectors and the vortech programmable pump booster along with the email Jon Lund tune. About 2 weeks pass and I receive all the parts from vortech, but I am still waiting on a base tune file for the install. After contacting Terry a couple times about it I finally get the base file from Jon Lund Tuning.
Now the install. I got a buddy of mine to give me and hand and we had all weekend in the shop with all the tools needed. Started Saturday morning and went 6 hours that day. The guide supplied from paxton was in black and white. Highly recommend getting the colored PDF from them as it will make the install much easier. We ran into a couple of hitches mainly because of the guide. When I installed the new coolant res the guide said the a/c line had to be moved 2-3 inches for clearance. Of course I got to almost 2 inches and it busted the line. No big deal as I didn't have enough support on the bend of the pipe so it cracked open there. So I get a new line and was able to install it without bending it as there was plenty of clearance. So I'd recommend checking before risking it, but that was mostly my fault. Also my bracket with the pulleys was preassembled incorrectly, one of the pulleys was in the wrong position. Be sure to verify yours before mounting it. Rest of the install was pretty easy and straight forward until I got to the fan. This is where the colored manual can help as there are no measurements in the guide, just "cut to look like the picture" guide. We probably spent almost 2 hours on the fan alone cutting, installing, removing, and doing more cutting for the fitment. It gets super tight with all the I/C piping and installing the fan. I checked and rechecked all the modified coolant lines and I/C piping and refilled the coolant res. I plugged the battery back up and went to install the base tune. Fired right up and idled pretty good. Let it heat up and idle for a bit to check for leaks and everything looked good. It took about 10 hours for the total install. I installed the vortech boost a pump the next day and my problems started.
Now the tuning. I logged onto Jon Lunds site and got in contact with Ken Bjonnes and he told me everything he needed from data logs. Here's where the fun starts. Now I am getting hard starts like its not getting any fuel before cranking over. Not knowing what it is I tell Ken along with the data logs. He proceeds to dial in my tune for wot. Feels pretty good up top now but I notice random idle surging and really bad light/part throttle hesitation and bucking. Ken try's to tune out the startup issues but it doesn't work. He then tries to tune out the part throttle issues and it doesn't work. We both agree to try to get the drivability tuned and then look at the startup issues. Long story short, I spent 3 weeks data logging, over 200$ in gas, and over 15 tune revisions later I get no further than the few days after we started and he had the wot dialed in. The last morning I had contact with him I removed the BAP and the cars startup issues ended. I played with it for a bit and now know my car acts "funny" when it's installed and refuses to do an initial prime. I tell Ken this and that I just need to drivability worked out and I would diagnose the BAP issue. Then I got tired of waiting and gave up with Ken as it seemed a lot of the time it was my parts, install, or car was to blame. I spent countless hours checking and reinstalling my work as he had me thinking it was something on my end. So I contacted another tuner and had the car dialed in, in less than 2 days and only 5 tunes later. Perfect drivability. Idles, cruises, and WOTs better than my intake/ bama tune did. I am loving it now. Major props to the other tuner as he worked with me Saturday and Sunday to get my car where it should've been weeks ago. Took it to the track and ran an 11.7 120mph with my 285 Nitto Invos at 45 psi. No dyno numbers yet. WOT AFR is 11.8 max and that's with about 9 psi at 7k rpm using the JLT intake and not the vortech BAP.
Now that vortech BAP. Been almost 3 weeks trying to figure out the priming issues. Vortech had no idea what it could be so they replaced the BAP. Still didn't help. I've wired and rewired it, checked all voltage readings, tried all recommendations and still can't get it to prime while installed. Once started everything works with the BAP installed, but the car won't prime.
All said and done I would definitely do things differently next time around purchasing, installing, and tuning wise. Learned quite a bit during the install and tuning process.
Jukens is offline   Reply With Quote
Old 08-29-2012, 08:32 PM   #2
Jukens's Avatar
Here's a few pics.
ID:	66168   Click image for larger version
Old 08-29-2012, 08:52 PM   #3
Mustang936's Avatar
1 word: badass!
Mustang936 is offline   Reply With Quote
Old 08-29-2012, 09:24 PM   #4
Topless04GT's Avatar
Sooo sexy! Now get some rubber to drop that 60ft!!!
My girl... ehh, cars never leave you! stick to cars!
My name is Josh, Whats yours?
Topless04GT is offline   Reply With Quote
Old 08-29-2012, 09:33 PM   #5
JG5.0's Avatar
A lot of info haha! Had mine installed last week. No problems on my end except for the up and down idle randomly. It seemed to get better as maybe the car adjusted I guess. My kit didn't need a BAP with it so no problems there but just seeing If you knew what fixed the idle problem?
JG5.0 is offline   Reply With Quote
Old 08-29-2012, 09:46 PM   #6
Jukens's Avatar
Re: My Paxton Install Experience
A different tuner fixed my idle surging.....and everything else
Old 08-29-2012, 10:01 PM   #7
JG5.0's Avatar
Niceeee! Vortech told me it was a vacuum problem which was def wrong so I didn't wanna argue when he kept insisting he knew, just told him to have a nice day. Def something in the tune, gonna have it hooked up and see why it's doing it next week. Other then that, runs like a champ! Love it, especially the sound!
Old 08-29-2012, 10:05 PM   #8
stangaroo's Avatar
A guy on youtube with Steeda intake tuner combo and radials ran an 11.88... Shouldn't you be in the high tens at least with that thing? 11.7 is damn fast don't get me wrong but something seems off to me.
2008 4.0 SOLD (I will miss my first stang forever)
2011 5.0 black on black with 3.73 manual and I still get over 26 mpg
stangaroo is offline   Reply With Quote
Old 08-29-2012, 10:07 PM   #9
Jukens's Avatar
It's a manual with 3.73 gears and I was running street tires at full pressure
Old 08-29-2012, 10:09 PM   #10
JG5.0's Avatar
It's a manual and I was running street tires at full pressure
Just get some tires and practice a lil bit if your goal is the 1/4 mile times. Your 60ft isnt helping for sure due to traction it seems.
Old 08-29-2012, 10:12 PM   #11
Jukens's Avatar
No doubt there. I just hit the track because I was bored and curious what I could do with street tires. I couldn't launch over 1300rpm and had to baby it throughout first, second, and the shift into third to keep traction.
Old 08-29-2012, 10:24 PM   #12
JG5.0's Avatar
I know what you mean, as soon as she boosts up, traction is a problem! Good problem though! I got the 6spd and 373s as well with the brembo package, the pirellis do ok when it's 85 and up outside but forget it when it drops in the 70s and 60s. I'll prob never run at the track bc I'm very competitive and I know it will lead to something I shouldn't do haha. Any exhaust work, meth injection, etc. done to the car as well or just the blower?
Old 08-29-2012, 10:28 PM   #13
Venomouz831's Avatar
Nice looks good too!! One of the few that talk the talk and walk the walk
)02 Gt, Founder of WE2G
Old 08-29-2012, 10:35 PM   #14
Jukens's Avatar
X pipe on the way and meth injection in near future.
Old 08-29-2012, 10:42 PM   #15
JG5.0's Avatar
Awesome! Def A LOT more ponies to unleash with a free flowing off road exhaust, meth injection, and a retune! Lemme know how it goes, I'm saving for a few parts so I can retune all together. Fun to see the differences each car makes with about the same mods.
Old 08-30-2012, 07:04 AM   #16
Jukens's Avatar
Going to the dyno tomorrow morning.
Old 08-30-2012, 07:41 AM   #17
get on the dyno ASAP and have the a/f and everything checked, dont even WOT it any more, be safe and be smart here. Be sure its spot on and where it needs to be and you will be ready to go, without that no tune can be assumed safe really. Since yo are getting it done tomorrow you should be good with any last adjustments, be sure to data log the runs as well.
let us know the results!
Old 08-30-2012, 08:43 AM   #18
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Awesome write up on the install. This will be really helpful for other users, you included a lot of great information! I'm glad to hear you got the tune dialed in the second time around and am definitely excited to check out your Dyno graph!
Also with a trap speed of 120 your well into the low 11's with a good tire and some suspension! Let me know if you ever have any questions.
- Dan
Old 08-30-2012, 06:04 PM   #19
avengnd's Avatar
Glad it worked out and it sounds like you are having a blast with it. Yep always a different perspective after doing something. Some things are better left to others to do.
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 08-31-2012, 12:47 PM   #20
Jukens's Avatar
Dyno numbers:
Conditions: 90F 58% Humidity SAE Corrected
Before and after x pipe
Old 08-31-2012, 12:51 PM   #21
Redstang1's Avatar
Dyno numbers:
Damn good numbers
Redstang1 is offline   Reply With Quote
Old 08-31-2012, 02:39 PM   #22
Napoleon85's Avatar
Thanks for all the info. Who was the tuner that got it all sorted out?
Old 08-31-2012, 02:41 PM   #23
Jukens's Avatar
Shaun from AED
Old 08-31-2012, 02:51 PM   #24
Napoleon85's Avatar
Originally Posted by Jukens View Post
Shaun from AED
Cool, I've heard good things about him. This isn't the first time Ive heard of driveability issues with Lund (or Lethal) tunes either ... I plan on ordering my Paxton kit from Beefcake too, but will probably have it dyno tuned somewhere rather than have Lund remote tune it.
Old 08-31-2012, 03:04 PM   #25
got an A/F chart anywhere?
Old 08-31-2012, 05:16 PM   #26
Jukens's Avatar
11.7 til 6800 leaned out a bit til 7100 got it fixed now.
Old 08-31-2012, 08:40 PM   #27
stangaroo's Avatar
Gotcha
Old 08-31-2012, 09:09 PM   #28
Loc: Austin,TX
You are gonna hear bad things about every tuner on the web. I've heard nothing but bad things about AED but you have to take those things with a grain of salt.
Old 08-31-2012, 11:33 PM   #29
Jukens's Avatar
Lol....
Old 09-01-2012, 09:57 AM   #30
AED has treated me great. From tune quality, power delivery, and customer service. I started with Lund tune- for reference.
How's the car feel now that you've remedied the problems
Previous: '02 GT, '04 GT, '07 GT & a few chevys in between
'13 GT
Woodga16 is offline   Reply With Quote
Old 09-01-2012, 04:35 PM   #31
Jukens's Avatar
It feels great, cant even tell the car is running at idle if it wasnt for the exhaust and paxton whine, the power is amazing and the smoothness of acceleration no matter my rpm or amount of throttle is butter.
10:51 PM
