2012 GT Clutch Issues - Mustang Evolution
Old 08-30-2012, 12:29 PM   #1
Intricate30's Avatar
Ok. Has there been any sure fire way to fix the issues with clutch pedal sticking on these cars? If I'm in 1st/2nd WOT most of the time I can't even shift into third. It was so bad yesterday that I was stuck at a stop sign for 45 seconds till the pedal came off the floor and I could get it back into gear.
Intricate30 is offline   Reply With Quote
Old 08-30-2012, 02:58 PM   #2
Gil_T2's Avatar
Re: 2012 GT Clutch Issues
what does the dealer say? have you taken it in?
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 08-31-2012, 10:09 AM   #3
Dealer has not be able to replicate the issue as of yet. When the mechanic drives it he doesn't take it over 6k rpm.
Old 08-31-2012, 10:22 AM   #4
Gil_T2's Avatar
The 11 and some early 12 cars had a TSB on pressure plate bolts coming loose,
Old 08-31-2012, 10:35 AM   #5
Butch's Avatar
Region: New Mexico
What is the TSB? And what does it do?
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 08-31-2012, 01:33 PM   #6
2013_stang_gt's Avatar
if im not mistaken they are supposed to do that on the new mustangs. Some new technology that assists in changing gears quicker. at least mine does it when i start shifting quickly. the clutch will be like a inch from the floor, resulting in less time taken to change gears. it took me awhile to get used to it.
---------- Post added at 02:33 PM ---------- Previous post was at 02:31 PM ----------
at least i like to think its supposed to do that. it helps me, and i find it pretty cool
2013_stang_gt is offline   Reply With Quote
Old 09-04-2012, 07:51 PM   #7
mknlegs's Avatar
I have a 2012 gt with the same issue. If I'm getting on it hard the clutch pedal seems to stick and almost always cant get into third gear. Only does this if I'm running in the upper rpms though and only through the first three gears. I haven't noticed it doing it above third.
mknlegs is offline   Reply With Quote
Old 09-05-2012, 03:38 PM   #8
Thats the exact problem I have. It's definitely not working as intended. It's lot for faster shifting either. You can't get the car into gear when it does it.
Old 09-07-2012, 09:38 AM   #9
mknlegs's Avatar
Yep, sometimes it take me several tries to even get into third gear. There have even been times I couldn't get into third at all. I'm dropping mine off for service next week this is the third time for tranny issues. This is a completely different issue than I had before. They have corrected everything else so I'm pretty sure this will be fixed as well. I'll follow up after I get details.
Old 09-07-2012, 09:42 AM   #10
Napoleon85's Avatar
Guys stop making stuff up. The mt82 is perfect and has no problems.
In all seriousness though, it Sounds like the pressure plate bolts backing out ... There was a tsb for this on the job1 2011s, but I was under the impression they fixed it in the job2 and 11-12 cars.
Old 09-07-2012, 09:46 AM   #11
mknlegs's Avatar
I'll hopefully know next week what is causing it.
Old 09-07-2012, 10:33 AM   #12
that would make sense,,had a couple do that at work,,ended up pressure plates were warped,,but they were trucks not mustangs..But they drive them like mustangs,,because its not theirs..lol
mymustang is offline   Reply With Quote
Old 09-07-2012, 02:32 PM   #13
I've read elsewhere the only surefire way to fix it is to change to the GT500 clutch pedal assembly. Wish I could get a confirmation.
2012 gt
04:12 AM
