Rear suspension clunk - Mustang Evolution
Old 09-02-2012, 06:53 PM   #1
CaptainBeyond's Avatar
I know there have been alot of threads on this so I apologize. But my car is lowered about 1.5" in the rear and a little over 1 in front. I have h&r race springs, steeda shocks/struts, j&m camber plates and stallion adjustable panhard. I mainly hear the clunking noise when I'm going going under 35 or 40 and driving over bumps. Ive read many threads and the main thing ive found is people saying the rear swaybar link bolts will loosen. But i have been under my car twice and have gone over all the nuts and bolts and havent found anything loose. The exhaust seems to have plenty of clearance. Im not sure what else to check. Only other things i can think of are maybe my stock swaybar and links or possibly the LCAs?? My car has been lowered for a while now and its been making the same noise since i first lowered it. I dont think anything is really wrong, it just annoys me when im cruising around slowly. Hoped maybe i could get some insight. Thanks in advance everyone!
Life's a garden, dig it
CaptainBeyond is offline   Reply With Quote
Old 09-02-2012, 08:31 PM   #2
Re: Rear suspension clunk
double check your exhaust, mine hits in two places
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 09-02-2012, 10:33 PM   #3
Cobrarunnin9s's Avatar
Make sure all your bushing have grease in them, but don't over fill them either. check them for damage as well while your there.
Cobrarunnin9s is offline   Reply With Quote
Old 09-02-2012, 11:17 PM   #4
TommyV's Avatar
Check your panhard, mine came loose and was clunking. LocTite and it's fine now.
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 09-05-2012, 05:31 PM   #5
Make sure all your bolts are tight
RedBandit11 is offline   Reply With Quote
Old 09-05-2012, 06:14 PM   #6
im just wondering if you found your clunk? if so fill us in?
---------- Post added at 08:14 PM ---------- Previous post was at 08:12 PM ----------
my exhaust hits the rear end vent cap on drivers side and it hits the the front of the housing , and it annoyed the hell out of me everytime i hit a bump it hit so i heated up the pipe and took a hammer to them and now no clunk.....
10:20 AM
