Removing resonators - Mustang Evolution
Old 09-05-2012, 10:09 AM   #1
JJB82's Avatar
Removing resonators
I have a 2012 GT 5.0. I heard that by removing the resonators you can make the exhaust louder. If this is true how can I remove them?
JJB82 is offline   Reply With Quote
Old 09-05-2012, 10:24 AM   #2
Napoleon85's Avatar
Either replace the over axle pipes, or have an exhaust shop cut them out and weld in straight pipe.
Old 09-05-2012, 10:48 AM   #3
JJB82's Avatar
Re: Removing resonators
Will that avoid my factory warranty?
Old 09-05-2012, 01:59 PM   #4
Napoleon85's Avatar
Probably not ...
Old 09-05-2012, 02:05 PM   #5
lilredgt's Avatar
No. It will not void your warranty. That's what I had done to mine. They removed the resonators and welded on straight pipes... then added some larger tips. It sounds awesome.
lilredgt is offline   Reply With Quote
Old 09-05-2012, 02:44 PM   #6
poloka's Avatar
I believe the consensus on here was Ford was cracking down on ANY modification from stock saying it 'could' void the warranty for repair IF the failed part was somehow related to your modification. Just build a good relationship with your dealer and usually they'll work with you. They want your return business. But if you blow an engine and you have a lot of power upgrades, they could say that put the engine out of specs and that is why 'blah blah blah failed cause of your mods' causing you to find a way to prove otherwise. Just be careful if you care about the warranty. If not, mod the crap out of it and make it your own!
2011 GT 5.0 Supercharged Phase 2 TVS2300
http://www.mustangevolution.com/forum/f376/t290294/
poloka is offline   Reply With Quote
Old 09-06-2012, 06:23 AM   #7
Napoleon85's Avatar
This is pretty much spot on. I would imagine the only thing that wouldn't be covered after something like this would be the exhaust system. I doubt they could refuse to cover engine/trans/suspension issues due to a minor exhaust mod that has little/no impact on the operation of the car.
12:36 PM
