Ground strap - Mustang Evolution
Old 09-05-2012, 05:34 PM   #1
Ground strap
Can someone take a pic of their motor ground strap for me.
Previous: '02 GT, '04 GT, '07 GT & a few chevys in between
'13 GT
Woodga16 is offline   Reply With Quote
Old 09-05-2012, 07:08 PM   #2
Re: Ground strap
its bolted to the right side motor mount
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 09-05-2012, 07:11 PM   #3
Is it easily seen?
'13 GT
Old 09-13-2012, 06:30 PM   #4
Re: Ground strap
not easy no
12:45 AM
