Low Tire Sensor - Mustang Evolution
Old 09-07-2012, 07:29 PM   #1
Tatsumake's Avatar
Low Tire Sensor
When I turn my car on a msg comes up that says "Low Tire Sensor Fault". I'm guessing that the tires aren't necessary low but the sensor it self is bad. This is my first mustang and my first vehicle with low tire sensor so I have no clue how they work or even where they are. Any ideas how I can get to them or do I have to take it to the dealer?
Tatsumake is offline   Reply With Quote
Old 09-07-2012, 07:47 PM   #2
DWC_SmOziLLa's Avatar
Have you checked the pressure yourself to confirm?
Old 09-07-2012, 07:51 PM   #3
Re: Low Tire Sensor
behind valve stem . CK tire pressure . take to dealer probably bad sensor
Lugnut is offline   Reply With Quote
Old 09-07-2012, 07:52 PM   #4
The TPMS sensors are inside the tires. You physically have to have the tires removed to get to them. Never fully trust the nannies, check the pressure at all four corners yourself. Add air if necessary to recommended tire pressure, located inside the door on the driver side. If all the tires are fine then go to the dealer and have them check it out. Remember that with lower profile tires the sidewalls are stronger and don't show low pressure as easy as bigger balloon tires. Good luck.
Old 09-07-2012, 08:39 PM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
Re: Low Tire Sensor
This seems to me like a bad sensor, completely independent of tire pressure. how old it is and how many miles? hit any mean potholes lately?
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 09-07-2012, 09:30 PM   #6
Napoleon85's Avatar
Re: Low Tire Sensor
My car says something similar every time I turn it on, but that's because I don't have TPMS sensors. Sounds like one of them ate it ... should be covered under warranty.
You didn't replace your wheels though, right?
Old 09-07-2012, 11:38 PM   #7
Tatsumake's Avatar
I bought the car as a certified pre-owned. It's a 2010 and, unless I'm mistaking, it does not have the stock wheels.
Old 09-07-2012, 11:53 PM   #8
Napoleon85's Avatar
Re: Low Tire Sensor
The new wheels probably don't have TPMS sensors then... they are very expensive.
Old 09-08-2012, 12:53 AM   #9
Tatsumake's Avatar
That would make sense.
Old 09-08-2012, 01:17 AM   #10
Napoleon85's Avatar
Re: Low Tire Sensor
Just so you know, it doesn't have any effect other than making the dash light and info center message come up. You get used to it after a while.
Old 09-08-2012, 02:06 AM   #11
Loc: Austin,TX
Re: Low Tire Sensor
If you have stock wheels........put some air in them and press the reset button.
Old 09-08-2012, 07:41 AM   #12
Tatsumake's Avatar
But it is kind of annoying. :/
Old 09-08-2012, 10:11 AM   #13
back n a stang's Avatar
Re: Low Tire Sensor
My light stays on year around.No sensors in mine either.Got 4 for sale though.Not sure they work with 10 model.You could pull them up on AM or wherever and check year dates. Off the 12 GT.
Old 09-08-2012, 12:11 PM   #14
Napoleon85's Avatar
Re: Low Tire Sensor
MY10-13 use the same sensors (valve stem style), 09 and below use the old band-style ones and aren't compatible with the newer cars.
Old 09-11-2012, 08:55 AM   #15
Tatsumake's Avatar
Thanks guys. It is annoying but I think I rather spend my money on more fun stuff first.
Old 09-11-2012, 09:00 AM   #16
The Blue Dragon
Lol agreed! I wouldn't have put sensors in my new wheels if I hadn't gotten them for $60 for all 4
Old 09-11-2012, 09:02 AM   #17
Tatsumake's Avatar
If that's all they were you got an awesome deal. I would have too.
Old 09-11-2012, 09:15 AM   #18
The Blue Dragon
Yea bought them off a guy, never installed. Usually costs that $60 for one
Old 09-12-2012, 09:12 AM   #19
Napoleon85's Avatar
The problem is that TPMS sensors have a tendency to fail and leak. When one does fail, I don't think the car tells which one isn't reporting so you might end up replacing all four, which includes having the tires unmounted, then remounted and balanced. I had we the money to but them, but didn't get them as much for reliability as much as cost savings.
Old 01-30-2013, 07:27 AM   #20
Tatsumake's Avatar
Uhm... How much would you like for them?
07:07 PM
