GT/CS Fog Light Extensions - Mustang Evolution
Old 09-10-2012, 09:32 AM   #1
Napoleon85's Avatar
In case anyone else is looking for the wiring harness extensions (pigtails), here's a link to the ones I got. I'll post back and let everyone know how they work. I think these will also work for the Roush foglights.
To answer the question that I know is coming, no, these will not allow you to operate both sets of fogs at once.
2005-2013 Mustang Fog Light Extensions H10 Set
I ordered them from their eBay store since they are bit of an unknown and this allows me to use PayPal. Price is the same.
2005-2012 Mustang Fog Light / Lamp Extensions SET H10-Roush / Aftermarket Bumper | eBay
Old 09-10-2012, 10:06 AM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
If I remember correctly, in order to run both sets you'd have to get a splitter to run a pigtail to both sets I believe
Thanks for the info Napoleon!
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 09-10-2012, 10:09 AM   #3
Napoleon85's Avatar
Yes, and it's also illegal in many places to have more than four lights on the front of your car running while driving. There's also the concern of blowing a fuse or melting the stock wiring since you're pretty much doubling the current.
Old 09-10-2012, 10:23 AM   #4
The Blue Dragon
Yea I wouldn't risk all that lol
Old 09-10-2012, 10:54 AM   #5
It's not me, it's you.
primer2tone's Avatar
If you buy the CS valance with fogs , they come with those extensions. Mine did.
Old 09-10-2012, 11:05 AM   #6
The Blue Dragon
Not if you bought used from me lol
Old 09-10-2012, 12:25 PM   #7
Napoleon85's Avatar
Yup, or if you buy the valence and get the fogs later.
Old 09-13-2012, 07:25 PM   #8
Re: GT/CS Fog Light Extensions
I wired all four fogs and made a longer harness on each side and i run them all the time, no issues with fuses , u wont burn up wiring unless u put a larger fuse, so far mine is a ok
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 09-15-2012, 09:55 PM   #9
Napoleon85's Avatar
Those extensions don't work...
Old 09-17-2012, 12:16 PM   #10
Napoleon85's Avatar
Turns out I'm a flipping ****** and ordered the wrong ones. FYI, the GT/CS (and V6) fog lights use a H11 connector, but the GT fog lights use a H10 connector. Not sure why this is, but going to bet that Ford just did some parts bin grabbing when building these cars. Here are the correct links for people upgrading from GT fog lights to the GT/CA Valence with fog lights:
Set of Fog Light Extensions. Converts from an H10 to an H11 bulb connector.
eBay:
2010-2012 Mustang Fog Light Extensions SET H10 to H11 - California Special GT | eBay
PS - called the company to talk about it and they were great. The guy on the phone was very helpful and they are accepting the ones that I screwed up and ordered wrong as return and are waiving the restocking fee.
Old 09-17-2012, 12:18 PM   #11
The Blue Dragon
Wow sounds like a great company to take care of you like that!
Old 09-17-2012, 12:32 PM   #12
Napoleon85's Avatar
Yeah, and I even told them that it was my fault. The guy I talked to was very understanding about it. Looks like I'll be under the car again next weekend
Old 09-17-2012, 01:33 PM   #13
Brian, can you show how you wired all four together?
joes_blue_12 is offline   Reply With Quote
Old 09-17-2012, 01:40 PM   #14
all I did is matched the wires from the connectors and then cut the connectors off and added longer wires and spliced into the connector going to the factory fog lights heat shrinked and that was it, just use the harnesses that come with the kit and extend them, I have no pics its all together, but its a pretty simple job as long as u make sure u match wire from factory fogs to the wires going to the lower fogs?? and use the same size wire, not sure but it was either 16 or 18 gauge?
» Members Mustangs
Ellie
sherv33
Eleanor
Ravnus
Add your Mustang
05:04 PM
