Camber bolt placement in front struts - Mustang Evolution
Old 09-30-2012, 12:26 PM   #1
back n a stang's Avatar
I have read conflicting things about where it should be.Top or bottom?? Ford manual says top according to a forum member who works for ford.BMR pdf says top.Which way the bolt arrow and washer Flange should face to fix neg. camber is not clear on the coyote cars either. WHO KNOWS FACTS??????
Old 09-30-2012, 03:36 PM   #2
Napoleon85's Avatar
I would follow the instructions for the bolts you have. I have the eibach bolts and their instructions said to use the bottom holes. I think there are a couple different designs, some use the top, and some use the bottom.
Old 09-30-2012, 03:41 PM   #3
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
The company that makes them for Eibach states that you can use two cam bolts to effectively double the range of adjustability. Either hole will work.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
02:54 AM
