2011 Gt Mustang Premium Performance Mod Suggestions - Mustang Evolution
Old 10-03-2012, 05:49 AM   #1
I am looking into making my first performance mods on my Mustang and I was curious to see what other people thought about my plans.
•Boss 302 Intake Manifold
•Airaid CAI (is there a better option to use with the Boss Manifold?)
After this I am looking for some suggestions from other with experience. I don;t have the funds for a SC right now, but plan to add that in the future.
Anything Else I should consider adding in addition along with, or instead of, the manifold and CAI?
Thanks for any assistance you can offer.
- Patrick
PatrickZeigler is offline   Reply With Quote
Old 10-03-2012, 07:29 AM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Sounds like a good starts Patrick, I would definitely recommend the air raid or Steeda CAI, combine that with the boss IM and a good tune (91 or better) and you're in the path to a quick car. I will also recommend mufflers (no power will be gained but you will smile a lot more) and cat deletes if your state emissions allows it (this will net you about 15-20 more rwhp). Good luck and feel free to ask more questions.
We only ask that you search the forum first
Btw, welcome to ME!!
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 10-03-2012, 07:47 AM   #3
nosympathy's Avatar
Yeah I would agree here. Cai and tune first though, before the manifold. If you can do all three then awesomeness.
Also agree on axle backs. I smiled so wide when I first cranked her over after installing my roush axle backs.
Old 10-03-2012, 08:16 AM   #4
doug5.0's Avatar
Before you go with the Boss IM you may want to wait and see how the new Cobra Jet intake does. From what I've read there's a lot more advantage to it, but its twice as expensive and requires a new throttle body. Can't wait to see some dyno sheets on it.
http://www.lethalperformance.com/for...-manifold.html
CURRENT: 2016 GTPP, Vortech, Ford/Borla cat back, 1" drop on Vogtland, 1" Hubcentric spacers, APR Front Splitter, RTR Upper Grille.
SOLD: 2011 5.0, Auto, C&L CAI, Dyno Tuned, 3.73s, Boss 302 Intake, Magnaflow Competition axlebacks, Stallion Suspension LCAs, Whiteline Sway Bars.
doug5.0 is offline   Reply With Quote
Old 10-03-2012, 09:22 AM   #5
wheelman's Avatar
Oh hells yeah. Thanks for the link. Looks slightly better than the Boss intake too IMHO.
wheelman is offline   Reply With Quote
Old 10-03-2012, 09:26 AM   #6
Loc: Austin,TX
I would do a cat less mid pipe with the Boss intake for sure. Cats rob these 5.0s.
Old 10-03-2012, 10:01 AM   #7
Napoleon85's Avatar
Yep. You'll pick up 50 rwhp with a tune and offroad x or h pipe. Also, the boss should be the last thing you do, and you can use the stock airbox with it if you order the boss inlet tube from ford for like $70 (much cheaper than any CAI). If you do get a CAI, stay away from JLT.
Before adding the boss you should really get your suspension sorted out to support the high rpm launches it loves. Upper and lower controls arms, and drag radial or bias ply slicks are a must, springs and shocks are highly preferable. An air/oil separator is also a good idea, even though it doesn't add any power.
Oh btw... That CJ mani is going to be like $1500 with the TB that you need to install it. IMO putting that into your suspension or start a supercharger fund would be a better idea.
Old 10-03-2012, 01:50 PM   #8
doug5.0's Avatar
Agreed, but if you're planning on doing the Boss with a TB anyway I think this is the better way to roll. But the dyno tests will determine If it's worth it. Who knows, it may be a lot of hype.
Old 10-03-2012, 02:28 PM   #9
wheelman's Avatar
I want to stay NA so I want the best performing one I can afford.
Old 10-03-2012, 02:38 PM   #10
Napoleon85's Avatar
You don't need (or really see much gains from) a tb with the boss mani.
Old 10-04-2012, 02:40 PM   #11
Villero1834's Avatar
Napoleon is right man , is useless to hae all that power if u cant put it down, i would and will start by doing suspension mods plus they dont mess up your warranty
Villero1834 is offline   Reply With Quote
Old 10-06-2012, 10:24 PM   #12
Deepblue_coyote's Avatar
Suspension mods do void warranty however only in the area of change so to speak... For example if you throw lowering springs on the car and blow a strut through the tower lol (worst case scenario) that will be voided bit if u blow a head gasket after lower springs obviously it won't be voided lol
"If you can leave rubber exiting the apex...you have enough power"
Deepblue_coyote is offline   Reply With Quote
Old 10-06-2012, 11:16 PM   #13
Napoleon85's Avatar
Any mod voids the warranty for any directly affected components. Common sense goes a long way on this one ...
Old 10-07-2012, 08:47 AM   #14
Yhea im thinking of getting coilovers so no warranty needed , if they break i wolud either have the warranty from the aftermarket coilovers , or id put back the stock ones
2011 gt
06:20 AM
