Help with Steeda CAI install! - Mustang Evolution
Old 10-05-2012, 01:24 PM   #1
See:
http://1.cdn.lib.americanmuscle.com/...anual-1112.pdf
"Removing factory airbox" - step 4 - see the two holes with the rubber grommets? I need these and don't have them ... the dealer installed a Roush CAI that has plastic feet that stick down in the holes.
Is this a show stopper or can I rig something up and try and buy the parts from Ford and install later?
Not sure what to do ... I don't have the factory air box.
mmike87 is offline   Reply With Quote
Old 10-05-2012, 02:29 PM   #2
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Originally Posted by mmike87 View Post
See:
Mike87,
You can definitely throw your new CAI on and rig something up to fill those holes. However just to insure everything is installed probably I would order the missing parts from the dealer!
Let me know if you have any questions!
-Dan
Old 10-05-2012, 02:32 PM   #3
Thanks ... I actually have the factory shifter bracket ... that stiff foam rubber from that piece can be cut to fit the holes ... I think I'll try that.
Old 10-05-2012, 02:40 PM   #4
Lorraine's driver
ab_mach1's Avatar
These...?
Attachment 71239
If so, they may have something in an auto parts store or Lowe's/Home Depot, that will work until you pickup some legit parts from Ford.
Instagram: @ab_mach1
Old 10-05-2012, 02:41 PM   #5
Lorraine's driver
ab_mach1's Avatar
Originally Posted by AMDanBailer View Post
Mike87,
-Dan
Thanks Dan!
Old 10-05-2012, 03:47 PM   #6
These...?
Attachment 71239
Yup, those!
Do you need my address?
Old 10-05-2012, 04:34 PM   #7
Lorraine's driver
ab_mach1's Avatar
Yup, those!
Ha! If I had'em siting I would send them to ya.
Old 10-05-2012, 04:45 PM   #8
Are we serious - missing two screws. 22 miles each way to Lowes.
Old 10-05-2012, 05:29 PM   #9
Lorraine's driver
ab_mach1's Avatar
Fancy grommets brother, fancy grommets
Old 10-05-2012, 05:33 PM   #10
Cranker's Avatar
Sounds like a good ride to me.
Cranker is offline   Reply With Quote
Old 10-05-2012, 07:45 PM   #11
Mike87,
-Dan
Never Micky mouse anything, just put on recommended parts
I've learned the hardway
Mustang_5.0 is offline   Reply With Quote
Old 10-05-2012, 09:57 PM   #12
No, screws that hold the intake together. 10-32's - looks like someone threw two 8-32's in the bag in place of two of the 10's.
Made a trip to Lowes, rigged something for the missing grommets using pieces cut from the stock shifter bracket (repurposed!) and uploaded the new Steeda tune.
Drove it a few miles - no problems. How much of a difference over the Roush intake ... not sure yet. From a rolling start in 1st floored it and broke the back ties loose easily with 3.31's ... but it may have done that previously. I don't spin out much despite really, really wanting to.
The new tune is a 91 tune that uses the factor adaptive strategy to account for 93 ... so I was told. I guess they don't provide explicit 93 tunes anymore.
---------- Post added at 11:57 PM ---------- Previous post was at 11:56 PM ----------
Mickey mouse until next week ... I have a line on a factory airbox that I will be allowed to snag the grommets off of next weekend. So, I have a plan.
Old 10-05-2012, 10:18 PM   #13
Lorraine's driver
ab_mach1's Avatar
Good deal! Sorry, I thought your grommets were gone. Doh!
Glad you have a temp solution. Keep an eye on it.
Old 10-06-2012, 08:54 AM   #14
So, I can tell that the weather striping is not sealing against the hood ... is this really a big deal or just hype? I would think that the "snorkel" (in absence of a better word) that feeds air to the box would displace any hotter air from the engine compartment when the vehicle is moving, and a slightly higher intake temperature at idle doesn't seem like a big concern to me. I wonder if my "rig" in absence of the proper grommets isn't sitting the box high enough?
Old 10-06-2012, 09:09 AM   #15
Lorraine's driver
ab_mach1's Avatar
Looking at the grommets, I could see ~3/8 to 1/2 height loss without them.
Old 10-06-2012, 01:54 PM   #16
It's not me, it's you.
primer2tone's Avatar
I've got an aftermarket cowl hood and the weather striping on my Steeda CAI doesn't mate up for ****. Doesn't even come close. I'm not really gonna do anything about it. I've got bigger issues to deal with.
Old 10-06-2012, 02:25 PM   #17
Yeah, the rubber I used is probably 1/4" or less. I should hopefully have the correct grommets weekend after next.
But how important is the hood seal, really? Seems like the air coming in through the intake tube would keep cold air coming into the box.
Old 10-06-2012, 06:05 PM   #18
Lorraine's driver
ab_mach1's Avatar
Heck, it's possible none of those actually meet up with the hood and seal with the shield. Having it sealed could definitely keep heat out, but I'm not sure how much would really come through that small of an area. The air will follow the path of least resistance.
cai
» Members Mustangs
DD
87LX306
Mustang
cynthia
Add your Mustang
03:44 PM
