Annoying rattle...help - Mustang Evolution
Old 10-06-2012, 01:39 PM   #1
13BlkSunshine's Avatar
I have a rattle somewhere in the back of my car...I have Roush axle-backs but I just had it on a lift and everything is tight and good...I removed the spare and everything in the trunk but the rattle is still there. It sounds like metal on metal and happens mostly on bumpy roads at low speeds. It reverberates for awhile after a bump. I want to get it taken care of but I am not sure what it could be if it is not the things I checked....help please
2013 Mustang GT/CS: Black On Black/6 Speed MT/BAMA 91R Tune/Glass Roof/Electronics Pkg/Comfort Pkg/3.73s/Roush Axle-Backs/C&L CAI/JLT Oil Separator/Tint 30/5
Gripping the wheel, his knuckles went white with desire! The wheels of his Mustang exploding on the highway like a slug from a .45. True death: 400 horsepower of maximum performance piercing the night...This is Black Sunshine-White Zombie
13BlkSunshine is offline   Reply With Quote
Old 10-06-2012, 02:19 PM   #2
michael81's Avatar
It's most likely one of the exhaust hangers from your after market axle backs, I had the same problem and so have dozens of others. One of the front hangers is vibrating against the metal bracket that houses the rubber bushing that your hanger slides into. Just take a pair of vice grips or channel locks and bend the hanger back a little nearest the 90 degree angel bend toward the front of the car. That should take care of it.
michael81 is offline   Reply With Quote
Old 10-06-2012, 03:31 PM   #3
+1-Had same problem, and that fixed it
Previous: '02 GT, '04 GT, '07 GT & a few chevys in between
'13 GT
Woodga16 is offline   Reply With Quote
Old 10-06-2012, 03:38 PM   #4
Ok I will take it back in and put it back on the lift and see if that fixes it. It drives me nuts.
Old 10-06-2012, 03:53 PM   #5
It drove me crazy as well. I had that rattle and the stock lca bushings popping every bump! Fixed lca problem
'13 GT
Old 10-06-2012, 04:30 PM   #6
I don't notice the popping yet, probably because i am so annoyed at the rattle
Old 10-06-2012, 04:36 PM   #7
Mine went quick...one day quiet, next day going to work bushings went. There's a tsb out for it. My new dealer, recently moved, wouldn't replace them because I'm lowered so I put CHE lcas on; problem solved.
'13 GT
Old 10-08-2012, 02:03 PM   #8
Well i did this and I still had the rattle. I took it to my dealership and they confirmed it was not the exhaust that was causing the rattle. They kept it and said it will take some time to figure it out. I will update when I find out what it is/was.
Old 10-08-2012, 05:20 PM   #9
Lobo67's Avatar
Have you checked any of your suspension ?
Lobo67 is offline   Reply With Quote
Old 10-08-2012, 05:32 PM   #10
92mustang2.3's Avatar
My wife's 5.0 rattle was the license plate border vibrating try looking to see if its that
92mustang2.3 is offline   Reply With Quote
Old 10-08-2012, 05:34 PM   #11
The dealership checked the suspension and said it all checked out
---------- Post added at 07:34 PM ---------- Previous post was at 07:33 PM ----------
That was one of the first things I checked....I even drove it without the plate and frame just to make sure
Old 10-08-2012, 05:41 PM   #12
Might be inside the mufflers that making the noise
Old 10-08-2012, 05:57 PM   #13
That is possible....They are supposed to locate the rattle using magnets or something....all I am glad of is that my dealership is mod friendly when it comes to my warranty.
06:05 PM
