Yet another exhaust question.. - Mustang Evolution
Old 10-09-2012, 07:19 AM   #1
USAF2754's Avatar
Hey all,
So i recently traded in my '12 V6 for a new 2013 5.0. Once I drove the GT, it was all over haha Yesterday, I ordered the GT500 axelbacks for the car and will have them tomorrow. I went to my local muffler shop to see about having the stock resonators cut off last night and this is where I need some advice.
After looking at the stock exhaust, the guy said that what he could do is cut from the stock H pipe to just past the resonators and install an X pipe and then just run the straight pipe back to just past where the resonators used to be. It would be 2.5" pipe in that section. He said I would be out the door for $215. How would this sound with the GT500s? Worth it? I'm going for a deep, aggressive tone on this car and he seemed to think that this setup would really open up the exhaust. Any help here would be appreciated!! Thanks!
USAF2754 is offline   Reply With Quote
Old 10-09-2012, 07:31 AM   #2
McQueen's Avatar
Try an off road H pipe, it will sound much deeper than the x pipe. X pipes sounds a little raspy but with an H pipe it will sound better for what you want, do a youtube search..
Is there a big difference in performance with an h pipe or x pipe????
McQueen is offline   Reply With Quote
Old 10-09-2012, 07:35 AM   #3
03whitey's Avatar
If your wanting deep tone id probably go with an o/r H pipe the X pipes are usualy pretty raspy
---------- Post added at 08:35 AM ---------- Previous post was at 08:33 AM ----------
Ive did a little research on the difference in H and X pipes and theres not a difference in hp gain from what ive read/saw just different sound!
03whitey is offline   Reply With Quote
Old 10-09-2012, 07:45 AM   #4
USAF2754's Avatar
That's pretty much been the majority of what I've read...that those X pipes will make it pretty raspy which is not what I'm looking to do here. Gotta find a way to get that aggressive tune and turn up the volume. Looks like the stock H pipe is pretty restrictive as well so the aftermarket o/r would be the best option?
Old 10-09-2012, 08:05 AM   #5
03whitey's Avatar
Yes, o/r H pipes make the ponys sound bad azz with that deep muscle car tone!
Old 10-09-2012, 08:13 AM   #6
Napoleon85's Avatar
Originally Posted by USAF2754
Hey all,
So you're going to cut an exhaust that's modular and weld in pipe that is a smaller diameter than the factory pipe? I know it sounds like a good deal, but this is going to be a serious hack job that will cost you more money down the road...
Old 10-09-2012, 08:17 AM   #7
deadsp0t's Avatar
Generally speaking H pipes produce better down low(lower RPMs) and an X will produce better near the top of the power curve(higher RPM's)
That's unimpressive
Old 10-09-2012, 06:01 PM   #8
Heartless's Avatar
I would recommend installing an aftermarket h pipe first before removing the resonators. It's always difficult for someone else to tell you exactly what to do to your exhaust to make it sound how YOU want it. Then if you want to turn it up just a bit more then get rid of the resonators but you should probably go 3" since stock is 2.75". The resonators are not very restrictive they are designed to minimize harmonics through the pipe. They are essentially straight through with baffling around it. It's the going from 2.75 to 3 that helps with flow. Your biggest difference besides the mufflers are the cats. So off road h takes care of that.
Heartless is offline   Reply With Quote
Old 10-11-2012, 08:12 PM   #9
USAF2754's Avatar
Well I ended up having the stock resonators cut out and today I installed the GT500 axle back. It sounds amazing on this car but I ran into an issue a little bit ago while driving home. My check engine light came on when I was accelerating pretty hard onto the freeway. Any ideas about where this came from? Could it be that the engine isn't used to the new exhaust on the car?
Old 10-11-2012, 08:29 PM   #10
Lorraine's driver
ab_mach1's Avatar
Do you know what code it's throwing?
Instagram: @ab_mach1
Old 10-11-2012, 08:41 PM   #11
USAF2754's Avatar
Not yet. I'm gonna see if it comes back up tomorrow and if it does ill take it to the shop and see what they say. The car is running fine and I haven't noticed anything different but that light came on while I was driving home
Old 10-11-2012, 08:47 PM   #12
The Blue Dragon
GrabberBlue5.0's Avatar
Should be completely irrelevant to the exhaust mods
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 10-11-2012, 08:51 PM   #13
Lorraine's driver
ab_mach1's Avatar
Yeah, made me curious. Was thinking maybe an O2 sensor came loose from the work.
Old 10-11-2012, 09:14 PM   #14
nosympathy's Avatar
Ehh they still could have a nice leak messing with the 02 sensors tho eh?
Old 10-11-2012, 09:51 PM   #15
Napoleon85's Avatar
Nothing behind the O2 sensor should matter.
Old 10-12-2012, 12:16 PM   #16
USAF2754's Avatar
P0430
Catalyst efficiency below threshold bank 2
That was the code that it was throwing. I had it reset and ill wait to see of it comes back up
Old 10-12-2012, 12:33 PM   #17
2013_stang_gt's Avatar
Check and make sure your O2 sensors werent disconnected or wires frayed during the install. Do you tune the car?
2013_stang_gt is offline   Reply With Quote
Old 10-12-2012, 12:57 PM   #18
USAF2754's Avatar
Nope no tune on it yet
Old 10-12-2012, 01:09 PM   #19
I had the same kind of catalyst code and turns out my tune was written with cats, so i was getting a CEL.
Old 10-12-2012, 04:25 PM   #20
Heartless's Avatar
P0430
Thats strange. It wouldn't be an o2 unplugged or anything, that would give you a o2 voltage code. That code is literally that the catalytic convertor is not filtering as well as it should. I hope your cats were not damaged during install. No reason why they would since you only did resonator delete and mufflers.
Old 10-12-2012, 09:08 PM   #21
Jrsgrabber50's Avatar
Is there any difference in gains between o/r X pipe and o/r H pipe
Jrsgrabber50 is offline   Reply With Quote
Old 10-12-2012, 09:39 PM   #22
very little from what i hear. both offer a pretty significant gain over stock. The x-pipe may have a slighty higher gain in the higher rpm range.
Old 10-12-2012, 09:42 PM   #23
Lorraine's driver
ab_mach1's Avatar
Yup! In general, they are both good improvements over the stock setup. The H pipe has more of a deeper sound and the X pipe has a higher - maybe a little raspier sound. The X pipe setups yield a little more power than the H pipe setups. IMO, I would go with the setup that has the sound you like, rather than just which one yields more power.
Old 10-12-2012, 11:46 PM   #24
From what I just read the O/R X pipe and the O/R H pipes were both tested on three cars and statically same across the board between the two on all three mustangs the O/R X pipe has 3 hp and 4.6 torque more the than the O/R H pipe which i think is pretty much would be unnoticeable
Old 10-12-2012, 11:52 PM   #25
S197STANG's Avatar
+ 1, you probably won't feel the difference but will definitely hear the difference..also depends on what mufflers your gonna be running..
S197STANG is offline   Reply With Quote
Old 10-13-2012, 12:45 AM   #26
Has any one heard the RTR axle backs?
Old 10-14-2012, 02:29 AM   #27
Yes
They are pretty much magnaflows colored black
Mustang_5.0 is offline   Reply With Quote
exhaust
05:32 PM
