Drive shaft installation ? - Mustang Evolution
Old 10-09-2012, 05:32 PM   #1
SolidRRaxle's Avatar
Looking to pick this up along with an exhaust tonite.... I do not have an extensive tool collection, nor experience. How difficult is the installation? Really only looking to do mods I can handle myself, will build my way up to the harder ones. This is a make or break question for me on this particular purchase. Any help here is appreciated
SolidRRaxle is offline   Reply With Quote
Old 10-10-2012, 04:11 AM   #2
I wondered this same thing a few months ago and did a little research ... there seemed to be a little more to it that just removing the old one and bolting in a new one.
Example:
UCA, 1 piece driveshaft, Pinion Angle... - MustangForums.com
mmike87 is offline   Reply With Quote
Old 10-10-2012, 05:50 AM   #3
Appreciate the link. Hope that guy was just over-complicating things
Old 10-10-2012, 07:06 AM   #4
Napoleon85's Avatar
Example:
That has nothing to do with the driveshaft...
Old 10-10-2012, 08:29 AM   #5
I guess I misunderstood it ... I thought pinion angles were a concern with one piece drive shaft installations? However, I have no idea what any of this means ... which is why I decided that this was not something I was going to do myself.
Old 10-10-2012, 08:33 AM   #6
Napoleon85's Avatar
I mean, it's of concern, but the driveshaft shouldn't have a big impact. Lowering the car is what causes the pinion angle to change, and its adjusted with an adjustable upper control arm.
Old 10-10-2012, 09:59 AM   #7
OK, I see. Thanks. I learned something!
Old 10-10-2012, 11:09 AM   #8
Napoleon, have you done this mod before? Trying to do it with just a set of ramps.
Old 10-10-2012, 11:53 AM   #9
Black5.0's Avatar
I did mine with the rear up on jack stands in my garage. Wasn't hard at all. Take out some bolts, swap shafts, put bolts back in.
Black5.0 is offline   Reply With Quote
Old 10-10-2012, 12:09 PM   #10
Napoleon85's Avatar
No, but it should be relatively easy. I would install a driveshaft loop while I was down there.
Old 10-10-2012, 01:02 PM   #11
Thanks. I picked up the BMR loop. Figure if I acrew it up, should have something there to catch it so it doesn't hit the pavement at 60 mpg and rip off my axle
---------- Post added at 01:02 PM ---------- Previous post was at 01:01 PM ----------
Nice, that is exactly what I was hoping it would be.... I should've waited to purchase but I'm like a little kid with this stuff. Purchased it about an hour or so after I posted this thread
Old 10-10-2012, 01:25 PM   #12
So, then I am to understand that there really ISN'T more to it than simply bolting in a new drive shaft? If so, that's something I am quite happy to have misunderstood.
Old 10-10-2012, 02:05 PM   #13
Black5.0's Avatar
Yeah, I put in the bmr safety loop as well
Old 10-10-2012, 02:15 PM   #14
Napoleon85's Avatar
I don't think so...
Old 10-10-2012, 07:02 PM   #15
The Blue Dragon
GrabberBlue5.0's Avatar
such a great mod too from everything I hear, too bad it's something we need to do ourselves though, I think at the very least it should have had a one piece from factory... and if they're so worried about MPG's it would've benefitted to have aluminum
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 10-11-2012, 01:06 AM   #16
2012Vader5.0's Avatar
I agree a one piece would have been nice to have come from the factory. Beings at 11,240 miles I twisted the factory two piece one.
2012Vader5.0 is offline   Reply With Quote
Old 10-11-2012, 07:25 AM   #17
Napoleon85's Avatar
Holy smokes ... what kind of power were you putting down to do that? I agree though, the two-piece shaft is garbage. I hate how it's always clanking when you engage the clutch from load... if I had a dollar for every time I had to explain what that noise was ...
Old 10-11-2012, 09:14 AM   #18
DWC_SmOziLLa's Avatar
+1, lol. Same here
Old 10-11-2012, 09:15 AM   #19
claudermilk's Avatar
While I haven't messed with the Mustang's driveshaft, I have removed & installed the one on the project car so many times I've lost count. Every time on jackstands. It's a pretty simple part. I'm sure once you get under there it will be obvious how easy it is.
claudermilk is offline   Reply With Quote
Old 10-11-2012, 02:49 PM   #20
No more power than ford put in the car.
Old 10-11-2012, 03:08 PM   #21
Coyote 5's Avatar
Region: Nebraska
The clanking noise ticks me off now but the first couple times I heard it I thought something was jacked up with the trans or the rear end. It's funny how under load or not sometimes it clanks and other times it doesn't.
Does the 1 piece drive shaft have the same the clanking noise as the 2 piece?
Coyote 5 is offline   Reply With Quote
Old 10-11-2012, 04:01 PM   #22
Napoleon85's Avatar
No, 1 piece shouldn't clank.
Old 10-11-2012, 04:19 PM   #23
The Blue Dragon
It's not supposed to clank, the clanking usually comes from the little bit of slop between the joint of the driveshaft pieces
Old 10-11-2012, 06:08 PM   #24
nosympathy's Avatar
Always wondered what that noise was. Lol always thought I was just a terrible driver haha.
Old 10-11-2012, 07:15 PM   #25
Napoleon85's Avatar
Nope, it's just terrible driveshaft design.
Old 10-11-2012, 07:34 PM   #26
nosympathy's Avatar
I watched the video on AM that shows their aluminum one and the stock one. I don't even understand why ford thought that was a good idea, at any point and time, other than it is probably a lot cheaper.
Old 10-11-2012, 07:41 PM   #27
Napoleon85's Avatar
For the same reason we have the MT82. Somehow they had to cut all this cost while still raising the price of the Mustang.
Educated secondary guess is that it must be easier to balance or something...
Old 10-11-2012, 08:52 PM   #28
The stock two piece drive shaft cost the same as one piece 800 roughly depending who you go with.
Old 10-11-2012, 09:52 PM   #29
Napoleon85's Avatar
To you, not to Ford. They have been using them for a long time and probably have an astounding deal from a manufacturer that makes thousands upon thousands for them.
Old 10-11-2012, 10:11 PM   #30
I was referring to the general public, of course they purchase cheaper than they sale. That's basic business.
Old 10-15-2012, 09:45 PM   #31
This is not an install for the avg. joe. If you are putting on the safety loop, know that the entire car needs to be jacked up PLUS a jack stand (didn't have it so had to abandon the entire install) for the transmission. Driveshaft alone is fine (squeeze getting up there of you're using ramps, but could work), but forget loop if you don't have all the equip. Also, don't do just the driveshaft... You'll need to remove it to put on the loop anyway. Hope this helps anyone who searches this out.... But none of us use the search anyway
03:31 AM
