Exhaust making interior shake. Help! - Mustang Evolution
Old 10-15-2012, 09:17 PM   #1
Mustang32Bill's Avatar
The vibration from my exhaust it making sounds in my car towards the back seat/window. Anyone else have this problem? It's sounds like plastic vibrating or something.
---------- Post added at 10:17 PM ---------- Previous post was at 10:15 PM ----------
Shake* lol
Mustang32Bill is offline   Reply With Quote
Old 10-15-2012, 09:24 PM   #2
gtstyles2's Avatar
Shake* lol
I get the same with my S Type Borla axleback... I figured it was normal
Old 10-15-2012, 09:35 PM   #3
Silversky545's Avatar
I have same problem it's starts around 2k rpm and is gone around 3k
But this is my fourth axle back all of witch did the same thing...
Sounds horrible... I'm embarrassed of my car because of this problem... hopefully mid mounting them will fix the issue
Silversky545 is offline   Reply With Quote
Old 10-15-2012, 09:39 PM   #4
Will I'm running loudmouth lol so I know I'm going to get some noise but it sounds terrible and I can't tell what it is. I might just sit back there and make my girlfriend drive it to see.
Old 10-15-2012, 09:42 PM   #5
asmith2109's Avatar
Like noise other then drone?
asmith2109 is offline   Reply With Quote
Old 10-15-2012, 09:45 PM   #6
Yeah.. It sounds like plastic shaking and hitting something
Old 10-15-2012, 09:52 PM   #7
I didn't even install my catless x yet lol
Old 10-15-2012, 09:57 PM   #8
asmith2109's Avatar
Have yu checked yur hangers?
Old 10-15-2012, 10:05 PM   #9
It's coming from inside the car. The exhaust is tight no movement at all.
Old 10-16-2012, 09:41 AM   #10
asmith2109's Avatar
I'm not sure then...
Old 10-16-2012, 06:10 PM   #11
Yea it definitely comes with any kind of exhaust other than stock. The sound comes directly from the trunk. pull your back seats down and drive around bit. You'll see how loud it really is. The only thing that I think will work is to install some sound dampening under the spare tire area. I'm gonna be doing it this weekend. It should make rattle go away and keep a lot of road noise out.
Bluebaretoe is offline   Reply With Quote
Old 10-16-2012, 06:17 PM   #12
RSW
RSW's Avatar
I get it too... I've got Roush Axel Back... I have a vert so I thought it was the top hardware on the inside behind the plastic rear panels...
RSW is offline   Reply With Quote
Old 10-16-2012, 06:23 PM   #13
13BlkSunshine's Avatar
It sounds like the rattle I was experiencing....for me it was a hanger and I checked three times and everything seemed tight...someone from the forum posted this and I did exactly that and it fixed the rattle...
It's most likely one of the exhaust hangers from your after market axle backs, I had the same problem and so have dozens of others. One of the front hangers is vibrating against the metal bracket that houses the rubber bushing that your hanger slides into. Just take a pair of vice grips or channel locks and bend the hanger back a little nearest the 90 degree angel bend toward the front of the car. That should take care of it.
2013 Mustang GT/CS: Black On Black/6 Speed MT/BAMA 91R Tune/Glass Roof/Electronics Pkg/Comfort Pkg/3.73s/Roush Axle-Backs/C&L CAI/JLT Oil Separator/Tint 30/5
Gripping the wheel, his knuckles went white with desire! The wheels of his Mustang exploding on the highway like a slug from a .45. True death: 400 horsepower of maximum performance piercing the night...This is Black Sunshine-White Zombie
13BlkSunshine is offline   Reply With Quote
Old 10-16-2012, 11:42 PM   #14
ThinBlueLine's Avatar
I thought it was just me! It happens around 3k. It sounds like its coming from underneath the rear passenger seat!
BAMA TUNED
LETHAL O/R H, GEN2 OVER AXLE PIPES & GT500's
DRIVESHAFT SHOP ALUMINUM DS W/ BMR LOOP
MGW SHORT SHIFTER
CDC CHIN SPOILER W/ BLACK BILLET GRILLS
BLACK JLT OIL SEPARATOR
ThinBlueLine is offline   Reply With Quote
Old 10-17-2012, 12:08 AM   #15
2012Vader5.0's Avatar
I had a rattle that was caused by the exhaust coming over the axle that had been miss mounted. The rattle was the exhaust clanging against the metal clamp to the fuel filler neck. Fixed it by losening the clamp forcing the exhaust higher and then tighten the clamp. Problem fixed for me.
2012Vader5.0 is offline   Reply With Quote
Old 10-17-2012, 07:54 AM   #16
Shake* lol
Do you live in an area where it gets cold? I ask because mine didn't start to make a noise until the temp dropped below 50. Than when I crank the heat for a while the vibration goes away. That's how I figured out that the noise was coming the interior. I run a off road x pipe with roush axel backs so i wasn't surprised when **** started to vibrate with the temp change.
Old 10-17-2012, 12:46 PM   #17
After awhile it will stop but usually at 3k rattle
Old 10-17-2012, 01:13 PM   #18
That is how mine was too....I had checked the exhause a couple of times and everything seemed tight but it was a hanger.
Old 10-17-2012, 02:03 PM   #19
DaBluedude's Avatar
Check your rubber isolators.
2003 Mach 1
exhaust
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
Back-pressure Mile high JDF General Mustang Discussion 11 09-03-2012 05:22 PM
Exhaust: Pro Dumps Mdavis1024 1979-1995 Mustang GT 6 01-15-2012 07:50 AM
Doesnt like these exhaust Blackedout Pre-2005 V6 Mustang 40 06-30-2011 08:50 PM
07:03 AM
