Crooked Exhaust Tips! - Mustang Evolution
Old 10-20-2012, 04:36 PM   #1
Mitch_Gibbons's Avatar
Question Crooked Exhaust Tips!
My exhaust tips are like off center does anyone know how to fix them so they look good?
Mitch_Gibbons is offline   Reply With Quote
Old 10-20-2012, 04:40 PM   #2
98StangKid's Avatar
Crawl underneath and see if you can adjust the hangers, if not just run it by your local exhaust shop.
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 10-20-2012, 05:06 PM   #3
gtstyles2's Avatar
It's simple, go underneath and loosen the ball clamp that holds the left muffler and push it upwards then tighten, they are adjustable.... The right one seems to look fine
Old 10-20-2012, 05:18 PM   #4
Lorraine's driver
ab_mach1's Avatar
+1
Instagram: @ab_mach1
Old 10-20-2012, 05:24 PM   #5
Thank you and the right one you can't really see it in the picture but it is in the top left corner I have to center it and bring down a little bit!
Old 10-20-2012, 05:43 PM   #6
nhcowboy's Avatar
You might also have to adjust the clamps on the mid pipe and then rotate the over axle pipes slightly. I had to do that to help clearance issues with the Muffler and the hanger bracket (rattling).
I had to fiddle with that a lot to get it centered on both tips properly.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 10-20-2012, 06:51 PM   #7
Loc: Austin,TX
Exactomundo buddy. This is my method also. Try fixing it at the axleback first but if it doesnt help try foolin with the mid pipe and twisting the overaxles like said above.
Good luck!
exhaust
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
Back-pressure Mile high JDF General Mustang Discussion 11 09-03-2012 05:22 PM
Exhaust: Pro Dumps Mdavis1024 1979-1995 Mustang GT 6 01-15-2012 07:50 AM
exhaust tail pipe tips shsfresh87 General Mustang Discussion 2 01-11-2012 09:07 PM
08 Mustang GT stock exhaust w/polished tips and stock springs Pete08GT Mustang Parts for Sale and Wanted 2 09-24-2011 08:19 PM
10:23 AM
