Problem with SYNC - Mustang Evolution
Old 10-24-2012, 04:11 PM   #1
JJB82's Avatar
Problem with SYNC
My sync stopped working. I heard that disconnecting the battery for 30 min will reset the car and solve the problem. I have a tune installed from a ford racing pro cal tuner. My question is. Will disconnecting the battery for 30 min result in me loosing my ford racing tune and return my car to stock?
JJB82 is offline   Reply With Quote
Old 10-24-2012, 04:30 PM   #2
nosympathy's Avatar
I honestly cannot remember if it does or not. But honestly since the tuners usually marry your car, putting it back to stock will save you paying to have the tuner unlocked when it sees your car is stock and won't tune it.
Old 10-24-2012, 04:36 PM   #3
nhcowboy's Avatar
No... Your tune will remain. But you will need to perform the idle relearn procedure (per the manual).
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 10-24-2012, 05:03 PM   #4
JJB82's Avatar
whats the idle relearn procedure?
Old 10-24-2012, 05:57 PM   #5
nhcowboy's Avatar
Check the manual for the exact procedure, but basically... From a cold start... With AC OFF. LET IDLE WITHOUT EVER TOUCHING THE GAS for about 10 minutes... Then turn AC on and idle another 10.
12.538 ET @112.33
Old 10-24-2012, 06:36 PM   #6
LAS97GT's Avatar
No. It won't.
---Las97GT
03:34 PM
