front end sounds - Mustang Evolution
Old 10-24-2012, 04:58 PM   #1
runthatsleeper's Avatar
front end sounds
hi everyone i need some help. i lower my 2012 gt about 3 weeks ago and now when i turn the wheel either way it sounds like something in the front is cricking and i can feel a little thru the wheel. i was wondering if anyone could know what it could possibly be ? i was think maybe something wasn't greased etc. i also had the lower control arms done on the car like a month ago because of those cricking but its a different type of sound. and also does anyone know if when doing lower control arms if the strut bar has to be taken off? i only ask because i recently look under my hood and noticed that the stock one was missing.
runthatsleeper is offline   Reply With Quote
Old 10-24-2012, 05:26 PM   #2
2013_stang_gt's Avatar
definately find out whos got your tower brace.
2013_stang_gt is offline   Reply With Quote
Old 10-24-2012, 05:28 PM   #3
Yea I think think they forgot to put it back one at the dealer ship
Old 10-24-2012, 05:44 PM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
Whoa... You better get back that brace... That shouldn't cause creaking though. Any time you change suspension geometry you're likely to get noises
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 10-24-2012, 05:46 PM   #5
It's not me, it's you.
primer2tone's Avatar
I be strak raving mad!
The noise may go away. Mine did. But comes back every so often. :/
Old 10-24-2012, 05:48 PM   #6
It's just weird that is wasn't doing that when they were put in
Old 10-24-2012, 06:00 PM   #7
It'll settle in. If not, take it back but they'll just blame your springs.
Old 10-24-2012, 06:19 PM   #8
92mustang2.3's Avatar
Did you replace the upper strut mounts when you lowered it cause the factory ones suck ?
92mustang2.3 is offline   Reply With Quote
Old 10-24-2012, 06:35 PM   #9
bradtaylornator's Avatar
I had to get the upper struts replaced on mine 1 week after i got my car. They said it wouldn't hurt anything it just sounds like a beat up junker rolling through a parking lot
bradtaylornator is offline   Reply With Quote
Old 10-24-2012, 06:38 PM   #10
poloka's Avatar
+1. Make sure and have car aligned if you didn't but the stock should last for a bit. I've got 10,000 miles on my stock ones right now and only pop just slightly when backing out of driveway on a cooler day. Other than that they are still good.
2011 GT 5.0 Supercharged Phase 2 TVS2300
http://www.mustangevolution.com/forum/f376/t290294/
poloka is offline   Reply With Quote
Old 10-27-2012, 12:22 PM   #11
does anyone have idea what this sound might be because i think its getting worse and it only does it when i turn the wheel ?
Old 10-27-2012, 12:25 PM   #12
Replace strut mounts
Old 10-28-2012, 10:59 AM   #13
Yep replace strut mounts mine did the same thing
Old 11-02-2012, 10:41 PM   #14
Just in the front ? Or should I do all 4 corners ? How much are they ?
Old 11-03-2012, 04:06 AM   #15
Mine was covered by dealer it was the upper struts on front. They would pop and squeak at real low speeds and over bumps. The dealer said that it is a big issue that ford has looked into. I had two drive around for 2 months with the sound cause the parts were on a national backorder
---------- Post added at 05:06 AM ---------- Previous post was at 05:03 AM ----------
Just to clear up, by big issue i mean the dealer said alot of people the have this issue, Not that it could be a catastrophic failure lol, didn't wanna give anyone the wrong idea
09:49 AM
