2013 coilsprings or coilovers?? - Mustang Evolution
Old 11-11-2012, 08:39 PM   #1
Villero1834's Avatar
I just got my 2013 2 days ago and , i was actually impressed by the way it handles , true is that the car can use some lowering but i dont think that i want to mess around with the shocks , the oem are on my level of confort and the car doesnt jump at all , i have the brembo package which is suppoust to have a stiffer susp as well. So i was gong to get coilovers but now im thinking that coilovers might be overkill , since i cant really go much lower on my 19s as to enjoy a full drop with coilovers i might just take a good set of springs. Anyways i would like to hear your opinion and also i would appreciate pics thx
Villero1834 is offline   Reply With Quote
Old 11-12-2012, 05:18 AM   #2
McQueen's Avatar
Coilover might be too much specially if you are not going to hit the track every weekend, springs by itself would give you the look and unless you lower more that 1.5 inches your brembo shock and struts will not to uncomfortable.
I am personally going with this set up:
Frpp k springs
Tokico d spec adjustable strut/ shocks
Gt500 mounts
Bmr adjustable ban bar
Bmr lower control arm
It is all just under $1000 and installation i will recommend doing it with a shop if it is your first time.
McQueen is offline   Reply With Quote
Old 11-12-2012, 05:26 AM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
I think lowering springs would be great, just keep in mind that some of that comfort you feel now will go away because the stock dampers will be outside of their designed operating range
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 11-12-2012, 05:55 AM   #4
gtstyles2's Avatar
A lot have done springs only and are happy with the ride. I did the Eibach Pro Plus that includes the struts and shocks and I'm very happy with the ride... Stiffer but feels nice and controlled, I just wasn't able to change to change the strut mounts since the GT500s didn't fit and had to reuse the factory ones which I hear isn't recommended. Didn't have much of a choice as everything was already apart, as a result I'm getting squeaking noises in the front at times, mostly when I start driving and it goes away
Old 11-12-2012, 09:57 AM   #5
Any pics of lowered 13's i know there are different set up, i would love to see the differences between them
Old 11-12-2012, 10:15 AM   #6
BlueDemon's Avatar
Region: New Mexico
I just replaced the rear springs with Roush coils 1 inch drop. Took 45 min to do both. Looks leveled and zero problems. Not bad for about125.00.
http://www.stage3motorsports.com/cat...spension/#!v=1
2013 5.0, 6 speed manual, Brembo Pckg, 3.73 gears, American Thunder 40 series Flowmasters, 1 inch Lowering springs from Roush, J&M LCA, J&M Adj.Panhard bar, 20% Tint all around.
BlueDemon is offline   Reply With Quote
Old 11-12-2012, 10:35 AM   #7
claudermilk's Avatar
You do realize it's the springs that primarily determine the suspension stiffness? Any lowering spring is going to be stiffer. Yes, coilovers tend to have higher spring rates than just lowering springs, but those are all stiffer than stock as well. The struts & shocks just keep the springs from bouncing forever. That's why they are properly called dampers. We've all seen the slammed ricers bouncing down the road, that's because they have too much spring rate for the dampers (and are probably riding on their bumpstops as well).
The suspension is a system & you're better off getting a set of struts/shocks to go with the springs. Just my $0.02.
claudermilk is offline   Reply With Quote
Old 11-12-2012, 10:42 AM   #8
nosympathy's Avatar
So you only lowered the rear and that was it? How much different does it drive?
Old 11-12-2012, 12:52 PM   #9
BlueDemon's Avatar
Region: New Mexico
Yea just the rear. Ride feels the same to me.
Old 11-12-2012, 01:15 PM   #10
nosympathy's Avatar
Not trying to say anything demeaning just curiosity.
Why only lower the back? Was it just for looks then or were you expecting something else?
I haven't been able to look at your photo full screen on a comp yet but I would imagine the car looks off being lowered in the back but not the front? Or was that what you were aiming for?
Old 11-12-2012, 01:33 PM   #11
BlueDemon's Avatar
Region: New Mexico
Yea you're right. It was just for looks. If you measure your car you will see it is higher in the rear than the front. I also did not want to mess with the stock geometry of the front suspension. So i was able to get rid of the stink bug look by just lowering the rear by one inch which is the difference in height between front and rear.
Try this:
measure the rear and then add weight in the trunk or have two of your buddies jump in the back seat till the rear drops one inch. Step back and take a look. If you like the look order the springs and 45 minutes of your time. If not remove items from car and have a beer....beer does sound good right now.....I'm going to get a beer.
Old 11-12-2012, 01:54 PM   #12
nosympathy's Avatar
Try this:
Haha fair enough thank you for the honest response! I haven't decided what I want to do yet and it is nice to have multiple ideas.
Old 11-12-2012, 07:08 PM   #13
Dude no disrespect but ur car looks weird , i mean i can tell that its way lower in the back than up front , its not leveled properl it looks like an old cadillac with a broken sensor , i hope its just the picture
Old 11-12-2012, 07:46 PM   #14
BlueDemon's Avatar
Region: New Mexico
Lol that's a good one. It is the picture. I found another picture.
Old 11-12-2012, 07:48 PM   #15
sinister's Avatar
I have the h&r super sport lowering springs on my 13 gt it lowerd it 2 1/4 in the rear and a inch and something up front looks very good to me and rides great and corners 100x better
sinister is offline   Reply With Quote
Old 11-12-2012, 07:54 PM   #16
BlueDemon's Avatar
Region: New Mexico
Here ya go. Hope these are better.
ID:	75755   Click image for larger version
Old 11-12-2012, 07:59 PM   #17
Venomouz831's Avatar
Get coilovers you won't regret it
)02 Gt, Founder of WE2G
Old 11-12-2012, 10:30 PM   #18
Thats more like it
@venom yep i think im going to end up getting coilovers , the new car smell will wear out quick and im gonn go full performance , and if i get just springs im going to end up double spending
Old 11-12-2012, 10:59 PM   #19
Thats more like it
Yea trust me they are worth it! They are better than just springs and you can stiffen em or make em softer. Also you can lower or raise them
Old 11-13-2012, 01:46 AM   #20
Jrsgrabber50's Avatar
Yea coil overs are definitely worth it that my next mod after I get my exhaust , If your having problems hooking up I'd recommend lca's and uca's I think the adjustable ones are between $160 and $180 for lca's and bout the same for uca's
Jrsgrabber50 is offline   Reply With Quote
Old 12-01-2012, 05:55 PM   #21
13StangGT's Avatar
I have the Brembo pkg and 19's what brand of coil overs would you recommend? I have seen a lot of good comments on H&R, steeda, and Eibach's.
13StangGT is offline   Reply With Quote
Old 12-01-2012, 06:34 PM   #22
Griggs racing, steeda, Megan racing, hnr, koni,
Old 12-01-2012, 06:52 PM   #23
13StangGT's Avatar
Thanks.. In that order?
Old 12-01-2012, 07:15 PM   #24
No lol. Read their reviews on them. If money isn't an issue go with airide
Old 12-01-2012, 07:18 PM   #25
nosympathy's Avatar
The airide suspension looks badass, but the one thing no one seems to want to answer is the life expectancy of them. I just can't believe they won't go bad faster than other more normal systems.
Old 12-01-2012, 07:24 PM   #26
Yea they are badass. That's true but they should come with some warranty if they ever go bad
Old 12-01-2012, 07:26 PM   #27
nosympathy's Avatar
Yeah haha. That is the thing, I can see putting money aside for them, as I love how they work, just would hate to spend that much and have them go bad in 5-10 years.
Old 12-01-2012, 07:42 PM   #28
Yea that would suck.
Old 01-04-2015, 12:39 PM   #29
Eibach Sportline Springs
BMR Adjustable Panhard Bar
Stock Shocks and Struts.
Stock 19" Premium Wheels
DF5 20/8.5, 20/10
Nitto Invo 255/35 Front 295/35 Rear
Sent from my HTCONE using Mustang Evolution mobile app
ID:	172870   Click image for larger version
14cyote is offline   Reply With Quote
12:32 PM
