catch can and then???? - Mustang Evolution
Old 11-18-2012, 08:53 AM   #1
bigsmitty24's Avatar
Ok so went to Fastlane Motorsports toys for tots event and won a $100 UPR gift card. Gonna get the billett catch can with it. Figured while im there id go ahead and order some of my Christmas presents. Should i get a catch can for the drivers side or the LCA? What brand of LCA should i go with?
bigsmitty24 is offline   Reply With Quote
Old 11-18-2012, 10:00 AM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
BMR, white line, UPR, Steeda, BBR to name a few
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 11-18-2012, 10:34 AM   #3
doug5.0's Avatar
I just ordered LCAs from Freedom Racing. I've heard good things so I thought I'd give them a shot. American made, and great customer service so far. I'll post about my install and results when I get them.
http://www.shopfreedomracing.com/Pre...-FRST-9002.htm
CURRENT: 2016 GTPP, Vortech, Ford/Borla cat back, 1" drop on Vogtland, 1" Hubcentric spacers, APR Front Splitter, RTR Upper Grille.
SOLD: 2011 5.0, Auto, C&L CAI, Dyno Tuned, 3.73s, Boss 302 Intake, Magnaflow Competition axlebacks, Stallion Suspension LCAs, Whiteline Sway Bars.
doug5.0 is offline   Reply With Quote
Old 11-18-2012, 12:10 PM   #4
CorDog009's Avatar
I'd get LCAs instead of the drivers side catch can for now.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 11-18-2012, 05:19 PM   #5
What is the difference in the adjustable LCAs and the others? Also heard about bushings making a difference. The car is a DD and will be lowered soon. Should i go with the adjustable ones or not?
Old 11-18-2012, 05:49 PM   #6
Black5.0's Avatar
http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
---------- Post added at 06:49 PM ---------- Previous post was at 06:49 PM ----------
This is a good read.
Black5.0 is offline   Reply With Quote
Old 11-20-2012, 02:42 AM   #7
MedxGT's Avatar
WTH does a catch-can do? Does it have to be emptied?
Sorry. Just looking for a plausible answer.
MedxGT is offline   Reply With Quote
Old 11-20-2012, 03:33 AM   #8
It's not me, it's you.
primer2tone's Avatar
It catches oil that would end up inside your intake manifold and on top of your valves. This is an area that you do not want oil to get into.
Yes, you do have to empty it. JLT has a very user friendly version that you just unscrew the bottom. It's like a cup and all your oil that would have ended up in your intake is now in this cup. You dump it out wipe it out and screw it back in. I empty mine about every 2K miles.
Old 11-20-2012, 09:31 AM   #9
jdavis96gt's Avatar
Region: West Virgina
Why drivers side? I thought passenger side was the side for a catch can.
Old 11-20-2012, 10:15 AM   #10
Bladezx's Avatar
That picture looks to be passenger side.
---------- Post added at 11:15 AM ---------- Previous post was at 11:14 AM ----------
Here's mine.
Wouldn't you be able to put that oil back in? Instead of discarding it or is it at that point where it's too dirty to even reuse etc
Bladezx is offline   Reply With Quote
Old 11-20-2012, 10:18 AM   #11
jdavis96gt's Avatar
I know but OP said drivers side. That's what I meant, my bad.
Old 11-20-2012, 10:51 AM   #12
I don't see why not? It's not any dirtier then the oil in the motor. I've just been in the habit of dumping it out and topping it off with fresh oil.
I do want to get another one for the driver side. Not as much oil gets by but I don't wanna take any chances. This car was expensive for me and I hope to keep it a long time.
Old 11-20-2012, 12:58 PM   #13
The Blue Dragon
You can add the catch can to both sides, passenger side has higher pressure and is more likely to push out oil than the driver side. Not as much goes through the drivers side so drivers side is not much of an issue usually
Old 11-21-2012, 08:56 AM   #14
claudermilk's Avatar
I'd just discard it. Not enough to put back, and it's going to be contaminated.
claudermilk is offline   Reply With Quote
06:29 PM
