Moroso Oil Catch Can 2011 Mustang - Mustang Evolution
Old 12-02-2012, 07:32 PM   #1
doug5.0's Avatar
So I just installed the Moroso oil catch can on the passengers side. Install was pretty easy, hardest part was attaching supplied hose to fittings. Instructions were spot on and all fittings and pieces were well engineered and fit and finish is perfect. Install requires removing original line and re-using OEM connections.
ID:	78941   Click image for larger version
CURRENT: 2016 GTPP, Vortech, Ford/Borla cat back, 1" drop on Vogtland, 1" Hubcentric spacers, APR Front Splitter, RTR Upper Grille.
SOLD: 2011 5.0, Auto, C&L CAI, Dyno Tuned, 3.73s, Boss 302 Intake, Magnaflow Competition axlebacks, Stallion Suspension LCAs, Whiteline Sway Bars.
doug5.0 is offline   Reply With Quote
Old 12-02-2012, 07:35 PM   #2
nhcowboy's Avatar
Looks clean. Nice job.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 12-02-2012, 09:23 PM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
Looks good! Keep us updated on how much oil it catches
New quick exhaust video
AUGUST 2012 MOTM!!!!
GrabberBlue5.0 is online now   Reply With Quote
Old 12-02-2012, 10:45 PM   #4
NewMtang's Avatar
How much was it? I put the JTL Oil Separator on for $119.99. Took it off at slightly over 1,000 miles. I found just about 1/8 in oil.
Old 12-03-2012, 12:03 AM   #5
Charlie_santos's Avatar
How did you reuse the stock connectors?
Old 12-03-2012, 12:37 PM   #6
doug5.0's Avatar
I prefer to buy at local shops. GTR in Rancho Cucamonga priced it the same as AM.
Old 12-03-2012, 12:45 PM   #7
doug5.0's Avatar
The stock piece is made of lightweight PVC, I just cut the 90 degree connectors out with a razor and attached to supplied hose from Moroso. All in all about 30 minutes because you have to remove strut tower bar, attach bracket, cut hose etc. I just preferred the look and design of this over JLT, I don't think either does more or less than the other.
---------- Post added at 11:45 AM ---------- Previous post was at 11:44 AM ----------
Thanks!
Old 12-03-2012, 04:41 PM   #8
claudermilk's Avatar
I just ordered a pair of new fittings from Ford, so I still have the stock line just in case. The Moroso is about $20-ish more than the JLT. I checked mine after a couple of thousand miles & there is some oil in there, so it's working.
claudermilk is offline   Reply With Quote
2011 mustang
12:14 PM
