Small upgrade. Installed! - Mustang Evolution
Old 12-05-2012, 08:07 PM   #1
SolidRRaxle's Avatar
Steeda ultimate sway bar kit
AM alum driveshaft and BmR loop
Bilstein hd shocks/struts
H&R race springs
UPR LCAs, steeds ultimate adj UCA
MM adj panhard
SolidRRaxle is offline   Reply With Quote
Old 12-05-2012, 08:11 PM   #2
Very nice did u do all the work yourself
Baldeagle is offline   Reply With Quote
Old 12-05-2012, 08:13 PM   #3
Nah. UCA and safety loop kept me from trying.
Paid for this setup. Will be doing the procharger myself tho
Old 12-05-2012, 08:18 PM   #4
That's cool,
Old 12-05-2012, 08:43 PM   #5
BlackBetty5.0's Avatar
How is the ride? How much of a drop was it?
BlackBetty5.0 is offline   Reply With Quote
Old 12-05-2012, 09:08 PM   #6
1.5 rear, 1.4 front. Not the most comfy ride ever (3 hours in the seat might be the max for a road trip), but holy balls does it hold the road. 0 body roll, I can feel the power spin up faster with the driveshaft and also the LCAs pushing the tires down. Drove almost half a tank after picking it up, loved it. When I went to fill up and reached for the gas cover it was then that I realized 1.5 is significant.
Shocks and struts are adjustable, so can soften it a little if I want.
Also, got CC plates added. Left that off the original post
Old 12-05-2012, 09:20 PM   #7
Defiant 5.0's Avatar
Sexy. Those track pack wheels look great with that stance.
2011 Mustang GT 6mt
Mod List: H&R Super Sport Springs, Eibach Camber Bolts, Steeda Panhard Bar, BBK Cold Air Intake, Stack Racing Chrome Strut Tower Bar, Boss 302 Coil Pack Covers, Barton Shifter, Barton 2 Post Bracket, 4.10 Gear, 2013 Track Pack Wheels, QA1 Single Adjustable Rear Shocks, Roush Axle-back exhaust, CDC Chin Spoiler, Saleen Grille,
Defiant 5.0 is offline   Reply With Quote
Old 12-05-2012, 09:20 PM   #8
Very nice! The new look alone is probably worth a stiffer ride. You should have no problem putting that power down once you slap on that procharger!
Old 12-06-2012, 09:05 AM   #9
claudermilk's Avatar
You didn't want to do the UCA, but you are going to do a SC? I've read the big bolt on ther UCA can be a PITA, but that & the loop are pretty straightforward bolt-ons.
Oh, nice setup.
claudermilk is offline   Reply With Quote
Old 12-06-2012, 10:46 AM   #10
If it were a positive disp, I would see your point. Ian going procharger this d thereupon cutting hoses, snipping number etc. seems pretty easy, just time intense.
The loop required too much and UCA. I only have ramps, but that is not nearly enough
Old 12-06-2012, 10:47 AM   #11
nosympathy's Avatar
Yeah you wouldn't be able to do that with ramps haha. Gotta have jack stands.
Old 12-06-2012, 05:55 PM   #12
Yeah, in fact from what I've learned you don't want to jack it up from the side once you have a custom suspension. Either both sides at the same time, on a lift or from the pumpkin (obviously that only works on the rear). As I tried to determine how many jacks and jack stands I came to the realization that it was worth the $1k. Also, my relo brackets are welded, not bolted, so that was an additional plus.
Old 12-06-2012, 06:24 PM   #13
avengnd's Avatar
Sweet!
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 12-06-2012, 06:25 PM   #14
Johnny5.0's Avatar
Bad *** bro...hows the overall improvement feel on a scale of 1-10? How about on hard launches?
Johnny5.0 is offline   Reply With Quote
Old 12-06-2012, 06:27 PM   #15
Man that looks good!
blackmustang12 is offline   Reply With Quote
Old 12-06-2012, 06:52 PM   #16
Thank you! This was my Christmas present.
Johnny5.0, I did a review as a separate thread (that way it is searchable for anyone considering this in the future)
Old 12-07-2012, 08:40 AM   #17
I'm going to be hard to convince since my brother in law and I have basically rebuilt a 351W Pinto project on jack stands. Jack stands are cheap. One floor jack & 4 jack stands, never an issue; having a lift would be easier, but the lack of one has not prevented a single task yet.
Looking at the product pics of the BMR loops, they aren't much more complex than the Summit one we have on the Pinto & it was not hard.
Jacking from the side after lowering should not be an issue--I spent years doing it on my last car after lowering. The only part that is trickier is you have to have a floor jack that will fit. I anticipate no issues after lowering the Mustang.
I can see the ease with welding on the undercarriage from a lift. But again, the Pinto got full subframe connectors on jackstands. That is 2x2 square stock through the floorpan.
Like I said, I'm going to be hard to convince.
Old 12-07-2012, 08:47 AM   #18
It's not me, it's you.
primer2tone's Avatar
That looks sharp!
Old 12-07-2012, 08:57 AM   #19
Thanks
Claud... Not gonna argue you here. This is my baby and I am overly cautious. Google. There is a reason a lot of cars have a center point to jack up as well as the sides. It impacts the geometry and at least the alignment. If google doesn't convince you, I'm ok with that
Old 12-07-2012, 11:56 AM   #20
hpisloud's Avatar
Damn...dem NASCAR boys must be throwin fits after every pitstop, then. One stop camber is one way, different the next...toe is set one way one pitstop completely opposite the next. What's the point of even taking tread wear/temp data if the alignment is a constantly changing variable?
If your alignment goes out of whack from the abnormal load you see due to jacking up the car from the side...it's just not a good product built for normal driving conditions. It would never stand up to stresses from potholes or weirdly uneven pavement.
hpisloud is offline   Reply With Quote
Old 12-07-2012, 03:29 PM   #21
Yeah... I don't have a stock car or a pinto, I have a mustang with a uni-body frame that has been shown to twist. If I have subframe connectors, welded, I might be less worried.
Look guys, as I said I am overly cautious and I also got the relo brackets welded which I can't do. If you think that's a little over the top AND have actually done this installation in your garage then you win more smart, handy guy points than me
Old 12-07-2012, 09:03 PM   #22
UltArc's Avatar
H&R race springs
MM adj panhard
What year?
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 12-07-2012, 09:10 PM   #23
Lorraine's driver
ab_mach1's Avatar
Those are awesome upgrades. I'm diggin it!
Instagram: @ab_mach1
Old 12-10-2012, 08:43 PM   #24
Thank you! 2013
Old 12-11-2012, 12:05 AM   #25
acornsmoke's Avatar
looks nice. trying to decide on what springs to Lower with -_-
acornsmoke is offline   Reply With Quote
08:21 AM
