Front end noise HELP - Mustang Evolution
Old 12-14-2012, 08:53 PM   #1
sinister's Avatar
I bought the h&r super sport lowering springs for my 13 gt now it's making a very loud popping noise coming from the front end when I turn anyone know what this is how to fix it thanks
sinister is offline   Reply With Quote
Old 12-15-2012, 08:05 AM   #2
Clink's Avatar
I had the same problem and took it to dealership, there's a TSB on the front control arms. They should fix for free but it solved my issue.
Old 12-15-2012, 08:06 AM   #3
DWC_SmOziLLa's Avatar
Did you replace the strut mounts?
Old 12-15-2012, 12:32 PM   #4
sinister's Avatar
What is a tsb
---------- Post added at 01:32 PM ---------- Previous post was at 01:32 PM ----------
Nope just the springs
Old 12-15-2012, 12:43 PM   #5
Rosco's Avatar
Originally Posted by sinister View Post
What is a tsb
Technical service bulletin.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 12-15-2012, 01:34 PM   #6
It's your strut mounts. When you pull the assembly apart, the strut mounts decompress and never quite seat back together again properly, although they'll look fine. This will cause the popping noises you're hearing in the front end. If your still running stock struts you'll have to order replacement fomoco strut mounts from your dealer or online. If you decide to replace your struts with aftermarket, you can run the gt500 strut mounts. Good luck!
Old 12-15-2012, 01:47 PM   #7
sinister's Avatar
If I get the gt500 strut mounts will it be a direct replacement I've heard there is some cutting to make them fit
Old 12-15-2012, 01:54 PM   #8
No it's not a direct replacement when used with your factory struts.
Old 12-15-2012, 01:55 PM   #9
The Blue Dragon
GrabberBlue5.0's Avatar
Highly recommend the GT500 strut mounts, less nvh for sure
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 12-15-2012, 02:03 PM   #10
Deepblue_coyote's Avatar
What is a tsb
A TSB is short for technical service bulletin.... It's like a recall but it's not a recall if u walk into the dealer and say my front end makes noises they will replace CA's basically
"If you can leave rubber exiting the apex...you have enough power"
Deepblue_coyote is offline   Reply With Quote
Old 12-15-2012, 02:53 PM   #11
sinister's Avatar
Is there any that are just a direct replacement that will work for me
Old 12-15-2012, 03:23 PM   #12
sinister's Avatar
What If I just got caster camber plates wouldn't they work the same
Old 12-15-2012, 04:21 PM   #13
The Blue Dragon
CC plates will help but they are expensive and require adjustment. Plus they won't be much help on stock dampers
Old 12-15-2012, 04:22 PM   #14
The Blue Dragon
Buy more OEM strut mounts
Old 12-15-2012, 04:25 PM   #15
sinister's Avatar
My car only had 2500 miles on it when I did this now it only has 3200 how would new stock ones that are the same work any different
Old 12-15-2012, 04:27 PM   #16
The Blue Dragon
They won't pop, that's what you're trying to eliminate right?
Old 12-15-2012, 04:47 PM   #17
sinister's Avatar
Yes so ur telling me I will have to buy new ones every 1000 miles
Old 12-15-2012, 04:52 PM   #18
The Blue Dragon
No reread this post from smozilla. What I'm saying is that when you changed springs you damaged the strut mounts, not intentionally not catastrophically, but enough to make them make noises. It's not that all OEM strut mounts make noises, it's that after you took yours apart they began to
Old 12-15-2012, 04:53 PM   #19
The Blue Dragon
Or just replace your dampers and strut mounts and solve all of your problems!
Old 12-15-2012, 04:59 PM   #20
sinister's Avatar
So can I not just get the cc plates and tht will take away the strut mounts or will I still have to have strut mounts
Old 12-15-2012, 05:01 PM   #21
The Blue Dragon
CC plates will replace strut mounts
Old 12-15-2012, 05:18 PM   #22
sinister's Avatar
So that's all I need
06:56 AM
