Suspension - Mustang Evolution
Old 12-15-2012, 04:24 PM   #1
sinister's Avatar
Suspension
I have installed the h&r super sport springs what do I need next got the adjustable panhard bar now are cc plates the same as strut mounts or do I need strut mounts with cc plates bc mine are popping bad now
sinister is offline   Reply With Quote
Old 12-15-2012, 04:35 PM   #2
back n a stang's Avatar
what year car man? If it's what I think......well let me ask....are you using your OE (stock) Struts/Shocks? Plates of course are the heat nut they will heat your wallet too. How much drop were the springs? You using CC bolts for now? Post some more info.
Old 12-15-2012, 04:55 PM   #3
sinister's Avatar
It's a 2013 gt I have the h&r super sport springs its a 1.5 front drop and 2 inch rear I have the panhard bar just not installed yet for the rear also i sloted my alignment bolts to allow for the proper alingment its within spec now I am using the stock shocks and mounts only thing I have replaced is springs what I realy just need to know is can I just buy the cc plates and does that replace the strut mounts or do I have to buy strut mounts to go under the cc plates I can't find no mounts besides the factory ones and mine only has 1000 miles on it an already pooping
Old 12-15-2012, 05:00 PM   #4
The Blue Dragon
GrabberBlue5.0's Avatar
CC plates replace strut mounts, with that said I would replace the dampers anyways because with the car lowered the stock dampers are going to wear out much faster. I replaced my stock dampers at 42k miles and had the car lowered for about 20k. I now have Koni strt on there and after driving the car a few times it is very clear that the stock dampers were so worn out that I was riding on just the springs.
The stock dampers were designed to ride at the stock height and nothing less. Do yourself a favor and replace them now, don't be like me and wait lol.
Also I recommend lca relo brackets
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 12-15-2012, 05:16 PM   #5
sinister's Avatar
How do I know what shocks will work and I will have to get coil overs on the front how do I know which ones will fit with the springs I have or work best for them
Old 12-15-2012, 05:27 PM   #6
Slotted the front was not a smooth move. Need to put that PH bar on. You don't need coil-overs. As Grabberblue50 said the STR.T is great for the money. If you want alot out of the car I would strongly consider the yellow sports which are adjustable. Especially with you habving a 2'' drop in the rear.Alot of drop and the str.t is not really that great. 1.5 and 2 in the rear is a pretty strong good amount of drop.I also agree with relocation brackets. With that drop in rear I would be looking at UCA as well.Get your pinion angle correct.
Old 12-15-2012, 05:46 PM   #7
sinister's Avatar
The front has to have them it is the only shocks they are for the front is coil overs bc that's what they are I would just have to put the spring on it right
---------- Post added at 06:46 PM ---------- Previous post was at 06:44 PM ----------
And slotting the front is better than camber bolts bc the camber bolts are about twice as small as the stock bolts
Old 12-15-2012, 08:26 PM   #8
The Blue Dragon
Koni advertises the strt as being usable from stock ride to a drop of 2+ inches
Old 12-15-2012, 10:08 PM   #9
sinister's Avatar
Were is the best place to get these at
Old 12-16-2012, 07:17 AM   #10
The Blue Dragon
PM sent
05:52 PM
