Stalling/rough idle after start up? - Mustang Evolution
Old 12-18-2012, 01:57 PM   #1
Anyone out there have a problem with stalling or rough idle after start up? If I start the car and hit the gas or even just touch the gas within ten seconds it will spit and sputter, if I wait ten seconds then touch the gas its fine?
Any ideas? And yes its tuned and everything but its done it from day one before any mods?
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 12-18-2012, 02:07 PM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Are you referring to the fact that shortly after starting the vehicle and you quickly tap the gas it kinda cuts out?
New quick exhaust video
AUGUST 2012 MOTM!!!!
GrabberBlue5.0 is online now   Reply With Quote
Old 12-18-2012, 03:06 PM   #3
Yes if I start it regardless if it's cold or hot it will sputter or stall if I touch the gas within ten seconds of starting it? And like I said its done it since it was brand new, no mods..
Old 12-18-2012, 03:10 PM   #4
nhcowboy's Avatar
Have you done the idle relearn steps as listed in the manual following the tune or last time you disconnected the battery?
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 12-18-2012, 03:18 PM   #5
Jake's Avatar
+1 this is most likely the problem
Jake is offline   Reply With Quote
Old 12-18-2012, 03:27 PM   #6
The Blue Dragon
I've done that and it did not help. It just happens for some reason. It has done that with every tune I've had
Old 12-18-2012, 04:46 PM   #7
2012Vader5.0's Avatar
You're not the only one this happens to me also at times, I couldn't even begin to explain how embarrassing it feels when it happens. I got a way around it. Just hold the throttle pedal very little and let the clutch out like your using like the gas it will keep you outta the middle of on coming traffic.
2012Vader5.0 is offline   Reply With Quote
Old 12-18-2012, 04:53 PM   #8
Yes it is embarrassing but im glad im not imagining things...and yes I've done the idle relearn many times, but as I stated before it has done it stock from the factory, and I thought maybe it was the throttle body, but nope, I will continue to just wait my ten seconds and it doesn't do it?? Its the only thing I hate about my car, and maybe the cup holders right behind the stick too, that sucks also...
Old 12-18-2012, 04:56 PM   #9
I got shorter arms than most so the cup holders aren't as bad for me, still just use sodas with twist caps. Had a styrofoam cup puncture and create a lake 2 weeks after getting the car.
Old 12-18-2012, 04:59 PM   #10
I guess a cupholder is a nice problem to have
Old 12-18-2012, 05:58 PM   #11
Haha if cup holders were the only problem I would have happy.
Old 12-18-2012, 07:53 PM   #12
gtstyles2's Avatar
That's normal, I was nervous when I got the car new and it did that... They all do it, I guess the ecu needs a few seconds to get the timing straight right after start... If u happen to run into another 5.0 do the same, they all do it
12:03 PM
