2010 BMR rear 1.5" lowering springs - Mustang Evolution
Old 12-20-2012, 05:07 PM   #1
FORDuhl6's Avatar
I picked up a pair of rear lowering springs for my GT. what do y'all think about just doing rears?
Is that okay cause my car has a pretty good rake to the front.
Thanks for the help
FORDuhl6 is offline   Reply With Quote
Old 12-20-2012, 05:29 PM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
I would recommend against it. I think the 1.5" drop will be too much and give the rear the appearance of sagging. Also with the aftermarket spring rates in the rear and the stock spring rates in front it may give you a weird ride quality
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 12-21-2012, 10:48 AM   #3
FORDuhl6's Avatar
Anyone else have an opinion
Old 12-21-2012, 11:14 AM   #4
DWC_SmOziLLa's Avatar
Totally agree with GrabberBlue, bad idea.
Old 12-21-2012, 11:29 AM   #5
The Blue Dragon
I think roush has rear leveling springs. I would check that out
Old 12-25-2012, 01:57 PM   #6
i just put in the bmr springs and let me tell you they are the best, but do front and rears I love the stance and the ride, but I did the bmr lower a arms too and swaybar and all i can say is wow, zero body roll....!
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 12-25-2012, 04:59 PM   #7
FORDuhl6's Avatar
I wonder if I could buy just the fronts from somewhere?
Congrats on the awesome new mod buddy!
Old 01-08-2013, 09:02 PM   #8
FORDuhl6's Avatar
No problem just got a set of H&r ss springs. Can'twait!!!
08:01 PM
