modifications that dont void warranty - Mustang Evolution
Closed Thread
Old 12-20-2012, 08:06 PM   #1
What all can I do to my 2011 gt that won't void the warranty? This may be a common question but I'm still figuring out the mobile app. Thanks in advance for the help
bossgt06 is offline
Old 12-20-2012, 08:09 PM   #2
Cosemetics . Hood , louvers pretty much body kit stuff . Rims wheels tint stripes exhaust grills. Interior lighting , seats dash panels remove back seats roll cage custom interior sound system . Haha I think I just have you my shopping list forgive the grammar just names my list lol
Moto111 is offline
Old 12-20-2012, 08:11 PM   #3
Does a cat back exhaust void the warranty?
bossgt06 is offline
Old 12-20-2012, 08:14 PM   #4
nosympathy's Avatar
if you remove the cats, yes, change out the headers, yes.
pretty much the only part of your exhaust you can touch is the axle backs.
now some dealers don't care. Mine for example because I am not in a state controlled by the EPA BS don't care I don't have cats. If your in an EPA controlled state, you might find this to be not true, as they can receive a hefty fine from the EPA for working on a car without cats.
nosympathy is offline
Old 12-21-2012, 06:17 AM   #5
KARgt13's Avatar
I think if you put in a cat back it will only void the warranty on anything after the cats. But if something happens to your engine and they somehow pin the problem as being caused by your cat back they won't fix it under warranty.
KARgt13 is offline
Old 12-21-2012, 07:53 AM   #6
its a very tricky thing as every dealership can make their own decision, even if they tell you one thing they could change their mind as well.
To be 100% safe regardless what anyone tells you stick to apperance for a while and you will probably be just fine with an axle back
SpectorV is offline
Old 12-21-2012, 07:57 AM   #7
The Blue Dragon
GrabberBlue5.0's Avatar
License plate bracket lol
New quick exhaust video
AUGUST 2012 MOTM!!!!
GrabberBlue5.0 is offline
Old 12-21-2012, 07:59 AM   #8
tc x 4's Avatar
I hope I didn't void mine taking it off.
tc x 4 is offline
Old 12-21-2012, 08:01 AM   #9
claudermilk's Avatar
Anything you change out will not be under warranty. Anything Ford can prove caused an issue will not be under warranty. It just takes a little common sense.
If you install an axle-back exhaust and the radio goes out, you will have no warranty issues. If you install a supercharger & blow the engine, you are going to be on the hook for the repair cost.
claudermilk is offline
Old 12-21-2012, 08:18 AM   #10
nosympathy's Avatar
If you rune a tune you can theoretically be on the hook for anything.
Old 12-21-2012, 08:24 AM   #11
tc x 4's Avatar
In a court of law, you are absolutely correct. However, in the real world, someone's gonna have to pay a lawyer when they tell you tuff luck.
tc x 4 is offline
Old 12-21-2012, 08:30 AM   #12
Clintg's Avatar
Anything roush supposedly does not void your warranty, if mind you, it is installed by a ford roush dealer. Always, always, always read the illustrious fine print though.
Clintg is offline
Old 12-21-2012, 09:09 AM   #13
KARgt13's Avatar
Even the radio?
KARgt13 is offline
Old 12-21-2012, 09:11 AM   #14
nosympathy's Avatar
Originally Posted by KARgt13 View Post
Even the radio?
Haha wouldn't surprise me.
Old 12-21-2012, 10:35 AM   #15
roushcoyotepony's Avatar
Here's my two cents, I ran a tune from practically day one on my 05 mustang GT and had multiple issues with my electrical and even my PCM replaced under the normal Ford 3yr/36k warranty. And this was with a dealership I hadnt even purchased the car from. In addition my gauges and convertible light bar were replaced under the Roush warranty. I would recommend getting FRPP or Roush products that come with a warranty professionally installed and mod to your hearts content! Good luck!
roushcoyotepony is offline
Old 12-21-2012, 10:53 AM   #16
South3rnBeLLe50's Avatar
I have a jlt intake and roush axle back exhaust and I still have warranty, my fiancé works at ford and had them write up a ticket so ford knows it was installed by a ford dealer.. I think as long as fords aware of certain mods that were placed on its not that big of an issue.
South3rnBeLLe50 is offline
Old 12-21-2012, 11:14 AM   #17
bradtaylornator's Avatar
You can change the lights on your dash and tilt your steering wheel up and down. That seems to be about it for most dealers
bradtaylornator is offline
Old 12-21-2012, 11:16 AM   #18
I talked to ford and they told me I can do the cat back as long as I leave original cats, I'm going to build my own exhaust out of stainless and tig weld the joint. I'm getting louvers for the side windows, flat black racing stripes and 20% tint.
bossgt06 is offline
Old 12-21-2012, 11:18 AM   #19
It's not me, it's you.
primer2tone's Avatar
Being cool with the service writer at the dealership can go a long way too. My guy at Champion Ford is freakin awesome! He's a mustang guy too and always hooks me up with discounted oil changes and warranty work. He's told me in the past if I have any engine issues, return it to stock and bring it in. My suspension is the only thing that I will not return to stock. If I have any suspension issues I'd expect to eat that cost because lowering a car especially as much as mine is, is going to create other problems that I don't expect the dealer to pay for when it was my doing.
primer2tone is offline
Old 12-21-2012, 11:33 AM   #20
Bladezx's Avatar
That is a pretty unrealistic example as if your radio goes out they have to prove that the cat back caused it. Since its just piping and a muffler I highly doubt that will effect anything on your car . The only it does is affect the flow of the exhaust. As for warrant I don't think anything should void it unless it affects the power train. Anything engine or transmission related or messes with electronics. I'm pretty sure stuff like
Spark plugs or batteries or even bigger oil pans etc shouldn't affect it
Bladezx is offline
Old 12-21-2012, 01:25 PM   #21
Loc: Austin,TX
Screw a warranty. I bought this car to "Mod" it and I know of something goes wrong it's my fault. It is what it is.
DDTCM is offline
Old 12-21-2012, 01:53 PM   #22
Grabber Blue5.0's Avatar
The JLT intake requires a tune. So you better be running a tune or maybe you're leaving out some missing information.
Grabber Blue5.0 is offline
Old 12-21-2012, 03:23 PM   #23
Of course I have a tune why would I not have one?
Old 12-21-2012, 03:24 PM   #24
KARgt13's Avatar
FRPP tune?
KARgt13 is offline
Old 12-21-2012, 03:24 PM   #25
Bama tune
Old 12-21-2012, 03:34 PM   #26
lx92coupe's Avatar
Even the radio?
Since I installed flowmasters I can not hear the radio. So I guess it can void the radio warranty
2013 GT Roush Stage1 TVS
lx92coupe is offline
Old 12-21-2012, 03:35 PM   #27
nosympathy's Avatar
Bama tune
Then you don't have a warranty as ford won't install a bama tune. Just an frpp tune. Not that the dealership you go to won't. Mine doesn't care. Just if you take it to another dealership they have every right to over ride that ticket and not cover things under warranty.
Old 12-21-2012, 03:39 PM   #28
I was told I'd be fine since I had it done at a ford dealer. Idk if its different where y'all live.
Old 12-21-2012, 03:44 PM   #29
nosympathy's Avatar
It isn't where you live...dealerships can do what they want. What I am telling you is if you go to another dealer even if they are just 10 mins away and tell them your having XYZ problem with you car and it is tuned by Bama and was "installed" at another dealer, they wont care. They have every right to not do any work under warranty.
Like I said. Dealerships can do what they want. Mine doesn't care I removed the cats, doesn't care my car is tuned, doesn't care I did the work myself. We are in agreement that they don't cover parts I buy and install and parts that cause damage to the car that are not factory.
The dealership I didn't buy from and don't go too, might treat me the opposite. I could have the battery legitimetly go bad and they could deny me getting one under warranty as my car is custom tuned.
Old 12-21-2012, 03:45 PM   #30
Because you didn't mention it here. Like I said, you left out information.
FRPP tune?
With the JLT CAI? Impossible.
Exactly, no more warranty.
You were told wrong. No more warranty at least with the drivetrain for you. The fact that a Ford dealer installed it means nothing. No matter who you know there.
Old 12-21-2012, 03:49 PM   #31
Well then you must be calling everyone including my fiancé who is a mechanic at ford a liar. Or anyone else is my area with the same mods with warranty still.
---------- Post added at 05:47 PM ---------- Previous post was at 05:47 PM ----------
At grabber blue
---------- Post added at 05:49 PM ---------- Previous post was at 05:47 PM ----------
Believe me just because I'm a girl doesn't mean I don't do my research I'm well educated on cars. And I will never put something on my car that isn't covered.
Old 12-21-2012, 03:49 PM   #32
nosympathy's Avatar
Well then yes I am. They are wrong. Sorry. Life is tough. You may have a ford dealer that is nice to people who tune cars.
Per ford as a company, you have no warranty.
If they ever have to pull in an outside specialties tech and he finds out you are tuned that way he can deny repairs himself.
Old 12-21-2012, 03:51 PM   #33
We will agree to disagree
Old 12-21-2012, 04:00 PM   #34
At grabber blue
You're clueless and it has nothing to do with you being a girl. So what you're saying is you have found a loop hole in the system? So all we have to do is have a dealer install anyone's tune and it will be covered under warranty?
Old 12-21-2012, 04:01 PM   #35
KARgt13's Avatar
Wasn't sure if an FRPP tune would adjust for aftermarket CAI or not. My badddd
KARgt13 is offline
Closed Thread
05:18 PM
