2011 brembo squeaking? - Mustang Evolution
Old 12-22-2012, 05:26 PM   #1
Jack Israelyan's Avatar
Does anyone's 2011 5.0 seem to squeak quite a bit from the rear axle?
Jack Israelyan is offline   Reply With Quote
Old 12-22-2012, 05:43 PM   #2
Well, the rears aren't Brembo, they are just regular GT brakes. I haven't heard a peep out of mine in the year I've owned the car, it was bought brand new. I'd take a look...you might just have a lot of buildup of crap back there, which is pretty common on rear disc setups. I also would pull the pads and re-chamfer the edges slightly, as this reduces noise alot.
Old 12-22-2012, 06:21 PM   #3
Sounded like it was comin from the axle/suspension
Old 12-22-2012, 08:13 PM   #4
Redstang1's Avatar
Ya same here. No idea what it is
Redstang1 is offline   Reply With Quote
Old 12-22-2012, 10:34 PM   #5
get some spray silcone lube and shoot the swaybar links, the shock mounts and the spring pads see if it goes away.
Careful where you shoot that ****, you don't want it on any of your external painted pieces, as it stains and is a bear to get off, even with wax and grease remover.
Old 12-23-2012, 09:50 AM   #6
GrayGhost's Avatar
Is the sound occurring while applying brakes? I never heard squeaking from my rear brakes, except when I would step on brake pedal on worn out rear pads. Squeaking went away after new pad/rotor change.
If you think sound occurs during rear suspension travel after moderate bumps in the road, it may just be due to outside cold temps... an issue I'm having with my lowered car. Squeaks go away during warmer weather.
2011 Mustang GT Premium 401A Spec- Sterling Gray, aka "Graycie", 6-Speed MT, 3.73, Brembo Brake Package, Current Mods: FRPP-Brakelines/Brake Ducts/Alternator/Radiator/Oil Pan/Oil Cooler/Trans.Scoop/Alum.Axle Cover, Steeda-Sport Springs/3rd Link/Adj.UCA/Alum.LCA/Rel.Brackets/Adj.PHB & Brace/Adj.F&R Swaybars/Adj.Front Endlinks/HD Strut Mounts/X11 Ball Joint/Bumpsteer/CAI, Koni Sport Shocks, ATI Damper, MGW Shifter, Kooks Catback, Wavetrac Diff, Michelin Pilot Super Sport... 93 Octane Performance Tune by VMP
GrayGhost is offline   Reply With Quote
Old 12-23-2012, 11:48 AM   #7
Am3gross's Avatar
Take them things off and send them to me! I will send you my stock gt brakes that don't squeak!
Like said before I think it has to do with weather also, changing stuff out will more likely fix the issue for this winter and be back next winter...
I would inspect and make sure every thing is good, lubricate what you can and leave the rest be.
2013 ford mustang gt, black, bought 16th of August. Only mod so far is tinted windows.
Am3gross is offline   Reply With Quote
10:49 AM
