01-04-2013, 10:06 PM
#1 | | Registered User
| upgrades for 2012
Got a 5.0 automatic with jlt cold air kit, boss intake, roush axle back exhaust and tuned by Bama performance. What should I upgrade to next to get the most out of my car. Its my daily driver in the spring and winter and currently in the garage. I want something that will increase performance but still be able to just cruise back and forth to work.
__________________ |
01-04-2013, 10:17 PM
#2 | | Registered User
Do you have a budget?
#3 | | Registered User
| Quote:
Originally Posted by Sprintradc Got a 5.0 automatic with jlt cold air kit, boss intake, roush axle back exhaust and tuned by Bama performance. What should I upgrade to next to get the most out of my car. Its my daily driver in the spring and winter and currently in the garage. I want something that will increase performance but still be able to just cruise back and forth to work. | What tune do you run? The hybrid is fun (but I actually daily drive the race... Had them modify the shift points on it a bit to downshift faster when decelerating abound 20-30 mph... Basically puts me in the right gear to explode without downshift delay at those speed without having to go WOT.
The next mod sounds like gears... 3.73 if you travel highways frequently... 4.10s would be more fun though  .
That is a cost effective mod... Beyond that, suspension and forced induction!
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
01-04-2013, 10:56 PM
#4 | | Registered User
Yea my budget is around 3k. Broke it off with the girlfriend so her loss is my gain.
01-04-2013, 10:59 PM
#5 | | Registered User
| Quote: |
Originally Posted by Sprintradc Yea my budget is around 3k. Broke it off with the girlfriend so her loss is my gain. | Other than cowboys suggestions, headers are always a nice up grade. They would work well with your IM.
01-04-2013, 11:02 PM
#6 | | Registered User
How much you think installation should be on a set of headers. Was looking at kooks
01-04-2013, 11:09 PM
#7 | | Registered User
| Quote: |
Originally Posted by Sprintradc How much you think installation should be on a set of headers. Was looking at kooks | Hard to say, every area is gonna be different. Find a shop that specializes in mustangs, they will be the cheapest. An inexperienced shop will probably charge 10hrs labor.
01-05-2013, 12:46 PM
#8 | | Registered User
Skip the gears and get a converter. Contact Circle D. Trust me you won't be disappointed.
2011 GT Premium 401A Grabber Blue Automatic
American Racing 1 7/8 Longtubes/off road x-pipe, Kooks Catback, BMR lowering springs, BMR lower control arms, BMR control arm relocation brackets, BMR adjustable panhard bar, VMP Tune, Weld RT-S wheels, Hoosier fronts M/T rears
01-05-2013, 01:14 PM
#9 | | Registered User
| Quote:
Originally Posted by Grabber Blue5.0 Skip the gears and get a converter. Contact Circle D. Trust me you won't be disappointed. | May I ask why skip the gears if you're getting a torque converter? Is it possible to use one with 3.73 or 4.10 gears?
01-05-2013, 01:16 PM
#10 | | Registered User
| Quote:
Originally Posted by roushcoyotepony May I ask why skip the gears if you're getting a torque converter? Is it possible to use one with 3.73 or 4.10 gears? | autos seem to run the fastest times with 3.31 gears and a torque convertor I believe it was.
If you have a manual this is a different story. The gear ratios between auto and manual are different.
If others are allowed to ask questions without searching first and trying to at least get their own answers, but I cannot do the same, then I don't care to be on this site anymore. This site is so full of hypocritical people. This site is no where near the same as it was when I first joined.
01-05-2013, 01:18 PM
#11 | | Registered User
| Quote:
If you have a manual this is a different story. | I see interesting good to know and yes i was definitely referring only to auto gts
01-05-2013, 02:22 PM
#12 | | Registered User
I totally forget about the converter upgrade. I had one installed in my 02 mustang and it was well worth it. I think I'll go that route and start calling around for install estimates
01-05-2013, 02:41 PM
#13 | | Registered User
| Quote:
Originally Posted by roushcoyotepony May I ask why skip the gears if you're getting a torque converter? Is it possible to use one with 3.73 or 4.10 gears? | Possible? Yes. Smart? No. Quote:
Originally Posted by nosympathy autos seem to run the fastest times with 3.31 gears and a torque convertor I believe it was. | Quote:
Originally Posted by Sprintradc I totally forget about the converter upgrade. I had one installed in my 02 mustang and it was well worth it. I think I'll go that route and start calling around for install estimates | You won't be sorry.
01-05-2013, 02:57 PM
#14 | | The Blue Dragon
This is just a guess, hopefully gb5.0 will correct me (don't know much about stall converters) but a stall converter allows you to wind up to a higher rpm while stopped on the line, allowing you to launch from a higher rpm. Now if you have shorter gears the higher rpm will cause you to launch harder and be more likely to cause wheel spin than a taller gear would. Therefore 3.15/3.31 > 3.73/4.10 on the auto with a higher stall converter.
Amirite?
01-05-2013, 03:18 PM
#15 | | Registered User
| Quote:
Originally Posted by GrabberBlue5.0 This is just a guess, hopefully gb5.0 will correct me (don't know much about stall converters) but a stall converter allows you to wind up to a higher rpm while stopped on the line, allowing you to launch from a higher rpm. Now if you have shorter gears the higher rpm will cause you to launch harder and be more likely to cause wheel spin than a taller gear would. Therefore 3.15/3.31 > 3.73/4.10 on the auto with a higher stall converter.
Amirite? | Here is a quick review of how a torque converter works.
There are three main elements that combine to transfer the power from the engine to the transmission: the Pump, the Turbine and the Stator. The converter is completely filled with fluid which comes from the transmission. The fluid starts off its flow from the inside of the pump and then it is centrifugally pumped to the outside of the pump. The pump is welded to the front cover which is bolted to the flex plate.
The pump is rotated by the engine and the fluid is pumped towards the turbine where the input shaft of the transmission connects. The fluid then flows to the stator and is redirected and the combined momentum of the fluid helps to spin the pump. This is how a torque converter can multiply the output power which is known as STR or Stall to Torque Ratio.
The fluid then continues this movement as the turbine speed increases. Eventually the turbine is spinning about 90% as fast as the pump. The fluid leaving the turbine now has rotational momentum and will contact the stator which causes the one way clutch to freewheel allowing better coupling which translates into efficiency.
01-05-2013, 07:04 PM
#16 | | Registered User
| Quote:
Originally Posted by Sprintradc Yea my budget is around 3k. Broke it off with the girlfriend so her loss is my gain. | Headers with full exhaust should
Work. Borla headers and stinger cat back should do it. With an x pipe
01-06-2013, 01:26 PM
#17 | | Registered User
| Quote:
Originally Posted by Sprintradc How much you think installation should be on a set of headers. Was looking at kooks | Brenspeed installed my kooks and xpipe in 6hrs. I caught black friday sale...$340 install. Normal cost is $675. Awesome ppl, they have a guest house you stay in for free if you come from out of town. They are in northern Indianna.
01-06-2013, 02:06 PM
#18 | | Registered User
| Quote:
Originally Posted by 13BLKCYOT
Brenspeed installed my kooks and xpipe in 6hrs. I caught black friday sale...$340 install. Normal cost is $675. Awesome ppl, they have a guest house you stay in for free if you come from out of town. They are in northern Indianna. | Man I love that company too, and really wish they weren't so incredibly far out of town for me down in AZ
01-06-2013, 02:16 PM
#19 | | Registered User
| Quote:
Man I love that company too, and really wish they weren't so incredibly far out of town for me down in AZ | Yeah lol, thats a bit of a drive!
01-07-2013, 02:57 PM
#20 | | Site Sponsor
I agree with everyone who recommend a new torque converter! A Circle D convertor will make your GT a lot more fun to drive, especially at the drag strip. Also, some headers would really compliment your Boss intake at the top end of your power band. So, that's not a bad route to go either.
Good luck with your decision!
Shane
01-07-2013, 06:30 PM
#21 | | Registered User
Converter is a solid choice. I had one in my 06 GT and plan on putting in the circle D this spring. Probably the 4C. Met a guy at the strip in November running one. Cars just had cold air tune and tires. Says he was getting 1.8 60s and dropped to 1.5 with the converter. On the street drive like stock until you get into it!
