2013 mustang dropped on eibach pro kit (pics of install) - Mustang Evolution
Old 01-07-2013, 07:55 AM   #1
BUSHGUTS's Avatar
before drop
new parts (LCA and relocation brackets and adjustable panhard bar)
shifter bracket (stock vs aftermarket)
in this pic you see a box that is where the shifter bracket connects to. what causes the 3rd gear mis shift is the stock bracket is rubber and the box moves inside that rubber and the factory shift linkage line goes inside that bracket and by that box moving it mis aligns the shift causing you to miss the gear
after drop
the car now has no more wheel hop and now it hooks better. no body roll and it handles like an import, lol. the relocation brackets changed the pinion angle downward resulting in making the tires dig in the ground and gain traction. i also no longer miss 3rd gear. all in all it was well worth it. the car feels more planted and is actually faster because it no longer hops.
BUSHGUTS is offline   Reply With Quote
Old 01-07-2013, 08:12 AM   #2
Nice write-up but, fyi, your relos aren't intended to change the static pinion angle downward. They relocate the instant centre for added or recovered plant and add more leverage to resist the pinion trying to climb the ring gear, which is what twists the housing upward.
Old 01-07-2013, 08:14 AM   #3
BUSHGUTS's Avatar
oh ok. ya the guy that was helping me install said it changed the pinion angle resulting in more traction. he said he has never worked with those relocation brackets before so that was his thought process
Old 01-07-2013, 08:39 AM   #4
audioAl's Avatar
More Zoom Zoom, cool beans!
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 01-07-2013, 06:46 PM   #5
gtstyles2's Avatar
Check out the video on the CJ Pony parts on YouTube on the BMR lca. Since your lowered on Eibachs u have to put it in the middle setting if lowered to get better traction... Top setting is for stock height
Old 01-07-2013, 07:05 PM   #6
Doe_Rae_mi's Avatar
Is that saleen I see hiding back there?
Old 01-08-2013, 02:24 PM   #7
avengnd's Avatar
Awesome!!
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 01-09-2013, 07:28 AM   #8
BUSHGUTS's Avatar
oh crap, will it cause any damage by being in the wrong setting? do i need to support the axle to fix this or can i just unbolt the lca and lower it down?
Old 01-09-2013, 07:35 AM   #9
BUSHGUTS's Avatar
yes sir, a 750hp saleen
Old 01-09-2013, 08:46 AM   #10
06blackvert's Avatar
Looks like you've got lots of goodies on your car! It looks great! I love that color. I like the wing and the wheels (I'm guessing you dipped?). It all looks good together. Dropping the car is my next mod so this gets me pumped for it.
06blackvert is offline   Reply With Quote
Old 01-09-2013, 08:51 AM   #11
BUSHGUTS's Avatar
thanks, im hoping to do more soon. ya the wheels are dipped as well as my hood vents and 5.0 badges
Old 01-09-2013, 09:41 AM   #12
Very very cool. Pics of the stripe? It looks good too. And what do you have in mind next?
Old 01-09-2013, 09:48 AM   #13
BUSHGUTS's Avatar
i want to do the RTR side stripe and get the side scoops, then radials. i ultimately want to get stance sc5 wheels in black
Old 01-09-2013, 09:59 AM   #14
Wow! That'll be a heck of a car when you're done. Nice!
Old 01-09-2013, 10:12 AM   #15
BUSHGUTS's Avatar
^^thanks
Old 01-09-2013, 10:43 AM   #16
2300turboford's Avatar
Omg I thought u wrote on ur car for a second I almost had a heart attack lol
Old 01-09-2013, 10:52 AM   #17
BUSHGUTS's Avatar
hahahaha?
Old 01-09-2013, 10:57 AM   #18
gtstyles2's Avatar
Not sure how to do it exactly I think your axle has to be on jack stands... I have the same BMR lca and relo bracket on order, so eventually I'm gonna attempt the install... I don't think your setting will hurt anything, your just not gonna get the full benefit and won't be planted as u should
Old 01-09-2013, 11:04 AM   #19
BUSHGUTS's Avatar
ya im fixing it tonite on a lift. install wasnt hard at all either
Old 01-09-2013, 02:58 PM   #20
Doe_Rae_mi's Avatar
Wow! Niceee
Old 01-13-2013, 03:35 PM   #21
BUSHGUTS's Avatar
Ok, i just got done moving the LCA to the middle hole. Wow what a difference. Before i moved it today i would just spin. Now no spin at all. On a 5-10 roll, i just mash the gas and all it does is hook, literally. Its so much faster because i have gained tons of traction. Now i cant wait for track day. Honestly the best mods you can do is the shifter bracket, LCA and relocation bracket. Car is more of an animal now. It just accelerates unbeleivably.
Old 01-14-2013, 07:18 PM   #22
2013 Green GT's Avatar
Just to clarify... You have the BMR LCA and relocation bracket. Which setting did you just set it on for this great hook? I was thinking of a similar set up. Thanks.
2013 Green GT is offline   Reply With Quote
Old 01-14-2013, 10:33 PM   #23
BUSHGUTS's Avatar
The BMR relocation bracket i have has 3 holes. There are other relocation brackets that have only 2 holes. Those are the old style brackets. I set my LCA in the middle of the 3 holes. The middle hole is for lowered cars and the bottom hole is for drag racing.
Nice car you have there. I want to get the side scoops to really complete my look. Are you planning on adding a stripe?
Old 01-14-2013, 11:51 PM   #24
cheelyb09's Avatar
Nice
Old 01-16-2013, 06:34 PM   #25
Thanks, no stripes for me, but might blackout the side rockers. Sometimes I like my scoops and louvers, and other days I don't. Overall, a good buy. So you set it on the middle setting. Are you lowered?
Old 01-16-2013, 06:36 PM   #26
BUSHGUTS's Avatar
Ya i put it on the middle setting after i found out that the top is for stock height. Much better traction now
Old 01-16-2013, 08:16 PM   #27
McQueen's Avatar
Did the height measurement change after it settle?
McQueen is offline   Reply With Quote
Old 01-16-2013, 10:15 PM   #28
BUSHGUTS's Avatar
yup, those measurements are after it settled
Old 01-17-2013, 04:39 AM   #29
McQueen's Avatar
Ok thanks.
Old 01-17-2013, 12:27 PM   #30
Site Sponsor
Sponsor
AMWill's Avatar
Awesome write-up, I'm diggin' all the before/after photos. I'm also glad you were able to get rid of the wheel hop, nothings worse than excessive wheel hop...
Enjoy the new suspension!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 01-21-2013, 10:38 AM   #31
Professor Mule's Avatar
Did you change the shocks/struts when you installed the springs or are you still on the factory set? If you are on the stock set is the ride noticeably more harsh? I figure it isn't since the Eibach kit isn't an aggressive drop... But from the looks of it, it's exactly what I'm looking for.
2013 GT | Ingot Silver | MT | 3.73 | Brembos | Tech Pack | Llumar Tint
Professor Mule is offline   Reply With Quote
Old 01-21-2013, 11:34 AM   #32
BUSHGUTS's Avatar
still on stock shocks. the ride isnt too overly aggressive. more like sport feel if anything. but a lot less nose dive and squat now.
---------- Post added at 01:34 PM ---------- Previous post was at 01:32 PM ----------
heres some updated pics
Old 01-21-2013, 11:59 AM   #33
McQueen's Avatar
Is it me or they look just like the frpp k springs???
Old 01-21-2013, 12:46 PM   #34
BUSHGUTS's Avatar
are the ford springs a 1.5" drop in the rear and 1" up front?
Old 01-21-2013, 12:57 PM   #35
McQueen's Avatar
No 1.5 all around, but dont pay attention to that because one thing is what they say and the other is what they actually drop. I know two guys with hotchkis and bmr and they look 100% the same.
2013 mustang
06:36 AM
