Need help - Mustang Evolution
Old 01-09-2013, 07:30 PM   #1
Tatsumake's Avatar
Need help
All of a sudden my brake lights are staying on. I don't know if it has anything to do with the fact that it has been raining all day but also my traction lights are saying they're off.
Tatsumake is offline   Reply With Quote
Old 01-09-2013, 07:39 PM   #2
nhcowboy's Avatar
I assume it has happened even after taking the key out and restarting?
I know once when I started with wheels turned and immediate turned rapidly, my advanced trac lit up saying there was an error... I think wheel speed sensors (possibly abs) didn't register or calibrate...
Perhaps water has jacked with the sensors on yours?
My car was fine the next day.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 01-09-2013, 07:44 PM   #3
Tatsumake's Avatar
I guess I'll unplug the battery tonight to avoid it getting drained.
Old 01-09-2013, 07:48 PM   #4
lBRAlD's Avatar
Good idea, water most likely made a short. If you had a general idea where it is you could spray wd-40 on it and it would stop it for a good while.
lBRAlD is offline   Reply With Quote
Old 01-09-2013, 07:51 PM   #5
nhcowboy's Avatar
Hmmm. So my brake lights didn't stay on after my key was removed... And the alarm set.
I think disconnecting the battery for a while sounds like a good start... But it sounds like something is shorting out... Almost like the parking lamp is engaged.
I have to assume you don't leave it in auto lamp control?
12.538 ET @112.33
Old 01-09-2013, 07:59 PM   #6
Tatsumake's Avatar
I have it programmed for 30 secs. The headlights go out as normal. I hope is not a bad short.
Old 01-10-2013, 07:50 AM   #7
Tatsumake's Avatar
Seems that whatever the short was it is now fixed, it does smell burnt inside.
Old 01-10-2013, 07:51 AM   #8
nhcowboy's Avatar
Yikes.... You must have something exposed and water indeed shorted it out... Take that in to the dealer!!!
12.538 ET @112.33
Old 01-10-2013, 07:59 AM   #9
Tatsumake's Avatar
Will do... And I will also stop driving through water.
Old 01-10-2013, 06:08 PM   #10
Tatsumake's Avatar
Well... It keeps doing it. After the car sits for a while the brake lights come on again on their own.
Old 01-10-2013, 06:09 PM   #11
nhcowboy's Avatar
Dry outside? If it is only the brake lights... How do the brakes feel? Is it possible that you have a brake fluid leak causing the pedal position to sink ... I have no idea but perhaps a loss of brake pressure could cause the brake pedal's position to cross a threshold and activating the lights?
Either way, I'd get it into a dealership tomorrow.
Still sounds like something could be shorting out though.
12.538 ET @112.33
Old 01-10-2013, 09:50 PM   #12
Tatsumake's Avatar
Breaks feel normal. I don't know how I'm going to get it to the dealer, I work all day.
Old 01-11-2013, 06:28 AM   #13
GE3G's Avatar
Maybe a bad relay or brake switch... Just get checked out big guy, no biggie ur all good thats what warentee is for...
GE3G is offline   Reply With Quote
Old 01-11-2013, 07:41 AM   #14
tc x 4's Avatar
You have a short, fix it before you start a fire.
Old 01-16-2013, 02:52 PM   #15
Tatsumake's Avatar
Fixed!!!! Woot woot! I found the circuit breaker and somehow it's good now.
---------- Post added at 03:52 PM ---------- Previous post was at 03:52 PM ----------
Thank you all.
07:32 PM
