2013 Brembo LCA? - Mustang Evolution
Old 01-12-2013, 06:21 PM   #1
2013 Green GT's Avatar
2013 Brembo LCA?
I have read that the Brembo package comes with GT500 LCAs. Can someone please confirm and demonstrate with evidence that it does? Either way, I get poor traction with the stock 3.31 and plan to go 4.10 in the spring. If at this time I have GT500... one, they don't perform well, two what upgrade would be best for the money as there are many options out there? Keep in mind I have a DD, don't plan on doing a supper charger or turbo, might track, will do a cold air intake and tune when gear is done, but want a solid 0-60 time.
2013 Green GT is offline   Reply With Quote
Old 01-12-2013, 06:23 PM   #2
McQueen's Avatar
3.73 is more than enough. We have gt500 bushing in the lca. What 0-60 are u getting right now on the track app?
McQueen is offline   Reply With Quote
Old 01-12-2013, 06:29 PM   #3
4.6
Old 01-12-2013, 06:38 PM   #4
I agree 3.73 will do but I want more. How to make a 4.10 stick beyond tire talk and tune?
Old 01-12-2013, 06:59 PM   #5
nosympathy's Avatar
Better LCA, UCA, Panhard bar, lower car, etc.
Old 01-12-2013, 07:08 PM   #6
The Blue Dragon
GrabberBlue5.0's Avatar
Did the brembo gts start coming with gears other than 3.73 in 2013?
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 01-12-2013, 07:08 PM   #7
I plan to lower later for sure and understand it helps beyond the look, but also have heard the Bembo pack has other extras such as LCAs and stiffer springs... Etc. but just thought I would ask. Thanks for your help.
Old 01-13-2013, 04:27 AM   #8
McQueen's Avatar
Only the track pack comes with 3.73 stock not as an option.
Old 01-13-2013, 05:38 AM   #9
Phoenix335's Avatar
Track pack has the GT500 LCAs, according to the Ford Racing pdf catalog. They are visually the same, i looked myself. The standard GT LCAs are black and the track pack ones are silver.
I'm not sure if Brembo package has the same upgrades.
Edit: From the Catalog
CONTROL ARM UPGRADE KIT
M-5538-A Fits 2005-2013 Mustang GT and V6
• Standard equipment on 2007-2013 Shelby GT500,
2013 Mustang with Track Pack, and 2011-2013
Mustang GT with manual transmission
• Increased bushing durometer and
stiffness for higher
horsepower applications
• For race applications see
tubular control arm kits
M-5649-S or M-5649-R1
Phoenix335 is offline   Reply With Quote
Old 01-13-2013, 07:51 AM   #10
Grabber Blue5.0's Avatar
4.10's will be a big mistake. I would rethink it.
Old 01-13-2013, 07:53 AM   #11
nosympathy's Avatar
Not if he has a manual.
Old 01-13-2013, 07:59 AM   #12
Yes if he has a manual. At the track he would be shifting into 5th before the stripe.
Old 01-13-2013, 11:03 AM   #13
The Blue Dragon
How big of a tire would he need to stay in 4th?
Old 01-13-2013, 11:18 AM   #14
Something around 29".
The most common tire used is a 275/60-15 which is 28" tall. Not many choices in a 29".
For the track with the manual, the best gear would actually be a 3.90 with a 28" tire. Because the 3.90 gear is made by Motive and not Ford most don't want to use it.
For an auto a 3.31 gear with a 28" tire is the ticket.
Old 01-13-2013, 07:59 PM   #15
Overall, going from a 3.31 to 4.10 is 200-550 rpm difference. If I'm going to put in a gear, I need to make it count and also set me apart from the 3.73 I missed out on with the tack pack. I will need larger tires! That's for another tread and has been talked to death. Thanks for the input.
Old 01-13-2013, 08:03 PM   #16
OzzyLiriano's Avatar
I have 3.15, so 3.31 is the ideal gear? What about stock 315 tires which is what im putting on my rims, stay 3.15 or go 3.31
OzzyLiriano is offline   Reply With Quote
Old 01-13-2013, 08:06 PM   #17
McQueen's Avatar
Do what u want because it is your car but this weekend i went to the track and one of the guys ended up going back to 3.73 from 4.10, he has a track pack just like mine.
Old 01-13-2013, 08:12 PM   #18
nosympathy's Avatar
Autos ideal gear is a 3.31 with a torque convertor.
---------- Post added at 10:12 PM ---------- Previous post was at 10:11 PM ----------
I could see if you only drove it on the streets how 4.10 would be nice but a good track course or drag strip and I'd rather have 3.73 myself.
Old 01-14-2013, 12:09 AM   #19
Villero1834's Avatar
Got mine 301a package, with recaro and brembo and had to order the 3.73 on the side , its not included on the brembo package
Villero1834 is offline   Reply With Quote
Old 01-14-2013, 10:02 AM   #20
However, BBP does have all the other track pack stuff bar the oil cooler, torsen, slightly bigger rad and grippier brake pads.
Old 01-14-2013, 10:19 AM   #21
claudermilk's Avatar
No it doesn't. The Boss radiator, oil cooler, trans cooling scoop, and Torsen are Track Pack pieces. These are the extra parts you get with the $800 difference in price between the options. Check Ford's site. BTW, I have a BBP car & don't have those parts.
claudermilk is offline   Reply With Quote
Old 01-14-2013, 10:56 AM   #22
McQueen's Avatar
Yea the track pack comes with all those parts the brembo pack just has the brakes, wheels, lca and stiffer suspension.
Old 01-14-2013, 02:38 PM   #23
If that's your theory, then why stop at 4.10's? Go right to the 4.88's. Remember, sometimes less is more.
For the track then yes 3.31's with a 28" tire is the ideal setup. How tall are the 315's?
Old 01-14-2013, 05:14 PM   #24
Thanks for the input, but also remember that I (maybe you) don't know what other mods this other guy did. Also meaning what rwhp and tq he is running, which makes a big difference. I don't plan on doing much more as mine is a DD. l will lower, and a tune, cold air... That is about it, thus a higher gear, but one that can still be used on the highway, and one the street for a faster 0-60 would work best probably for me. Thanks for your help.
---------- Post added at 06:14 PM ---------- Previous post was at 06:12 PM ----------
I still need to have some type of traction especially as a DD, which also is used on the highway every once in a while.
Old 01-14-2013, 05:20 PM   #25
McQueen's Avatar
He was bone stock just axel back and suspension from bmr.
Old 01-14-2013, 05:29 PM   #26
godsdisciple85's Avatar
There is no way that I would do 3.31 on an auto for the cost of the upgrade it wouldn't affect it enough....in my 2011 5.0 auto 3.73s were perfect at the track and on the street...don't listen to them do the frpp 3.73s....then you can do a lower torque convertor and still be street able IMHO
---------- Post added at 06:29 PM ---------- Previous post was at 06:28 PM ----------
Oh and if anyone wants the gt500 Lcas I have a set for cheap and the solid panhard bar and the shocks struts and springs just FYI
godsdisciple85 is offline   Reply With Quote
Old 01-14-2013, 06:20 PM   #27
I have a manual with stock 3.31, and you just in a round about way supported my argument for going to a 4.10 in stead of 3.73, just for the cost of up grade, limits I have on budget, DD, and majorly only concerned with 0-60 on the street.
---------- Post added at 07:20 PM ---------- Previous post was at 07:16 PM ----------
Thanks for the information about the mods on the gear swap. However, I think a tune could help with curving the torque and HP as to better launch a 4.10, and use the higher RPMs. Did this happen in this case? What do you think in general about a tune and gear?
Old 01-14-2013, 06:42 PM   #28
McQueen's Avatar
If you want you dont have to get a tune just take it to ford and they will plug it in the computer and change the car to 3.73 or 4.10 to correct the speedometer, i did that with my tires when i got wider rims.
I am not a fan of loosing my warranty over and intake and a tune, i would focus on looks and suspension and if you can afford it do a force induction kit that u like. That is all my opinion some make look at it different.
Old 01-14-2013, 06:45 PM   #29
Dude, the only thing I missed in the list is the scoop, c'mon now, read please....
I have a BBP too.
Old 01-14-2013, 06:49 PM   #30
just know that the ford dealership cannot adjust the automatics for new gears...some will say they can then you get the gears and go up there and they oh sorry we thought we could (personal experience)....well they can't trust me!!!only gears that where an option from the factory...so manuals you can get 3.31, 3.55, 3.73 autos 3.15
Old 01-14-2013, 06:51 PM   #31
2011 Kona Blue's Avatar
Just curious but I don't see anyone mentioning a 3:55 gear. I see a lot of fans of the 3:31 gear for the auto's and 3:73 gears. Why not go in the middle with a 3:55?
Old 01-14-2013, 08:57 PM   #32
The Blue Dragon
3.55 is a middle of the road gear, many NA guys that want a kick in the pants will go with 3.73 or 4.10, many drag racers or FI guys will go 3.31.
The 3.55 is just kinda the odd man out so to speak
Old 01-14-2013, 09:02 PM   #33
Currently I have the weak a$$ 2.73 in my 11. Hopefully, after I install my odd man out (lol) 3:55 gears, it will give me a kick in the pants that I'm looking for.
Old 01-14-2013, 09:04 PM   #34
gtstyles2's Avatar
Kinda see why... Who would go from 3.31 to 3.55?? For the same price u can go 3.73... But of course if I had 3.55 jumping to 3.73 is not that much worth it
Old 01-14-2013, 09:14 PM   #35
nosympathy's Avatar
You have a V6 though whole different story.
07:24 PM
