i need some help with my boss manifold - Mustang Evolution
Old 01-13-2013, 02:05 PM   #1
Region: Arkansas
i bought the new boss intake manifold from american muscle. the install was very easy. anyway, after i installed the manifold and tune i went for a test drive. when driving and in gear the car does just fine, but when i press the clutch and put the car in neutral it dies?!?!? this happens about 40% of the time. american muscle couldnt really help me. wondering if someone else has had this same problem or knows what to do.
blakebrooks is offline   Reply With Quote
Old 01-13-2013, 02:25 PM   #2
Yellow50's Avatar
three things
1) did you do the idle relearn after you installed the tune
2) did you torque all the bolts on the manifold in pattern they are supposed to be torqued.
3) are all the vaccum lines on and snug?
Yellow50 is offline   Reply With Quote
Old 01-13-2013, 04:28 PM   #3
Region: Arkansas
it does seem like it is idling lower than usual. how do adjust the idle "relearn"
i appreciate the help
Old 01-13-2013, 04:31 PM   #4
It's not me, it's you.
primer2tone's Avatar
Is your MAF connector plugged in properly? What did you do with the purge valve?
Old 01-13-2013, 04:42 PM   #5
Region: Arkansas
the instructions said that the purge valve was no longer needed so i just moved it out of the way....And with the mass air i just pulled it out of the stock air tube, and placed it in the aftermarket one
Old 01-13-2013, 04:54 PM   #6
Loc: Austin,TX
I would start with the simple stuff first like stated above. Check every connection to make sure everything is snug. If still no luck it may be in the tune.
Old 01-13-2013, 05:24 PM   #7
I agree double check that you torqued everything correctly
Garrett7 is offline   Reply With Quote
Old 01-13-2013, 09:41 PM   #8
I didn't remove my purge valve. I relocated it to the block. And honestly, I didn't torque the manifold bolts down either. So unless you've got some bolts that are seriously loose, I don't see that as being the problem.
Old 01-14-2013, 05:43 AM   #9
Loc: Austin,TX
Same here. Relocated the purge valve and didnt torque the mani to their specs. Torque specs on that thing are so that you don't crack the plastic on the install.
Old 01-14-2013, 12:55 PM   #10
Site Sponsor
Sponsor
AMWill's Avatar
blakebrooks,
It sounds like you still need to preform the "Idle relearn" process. Without doing the idle relearn, you'll experience very similar symptoms (surging idle, dying idle, etc) to this when installing a major air flow upgrade. Follow the link provided above and do every step exactly as explained. Once you're finished, get back to me and let me know how the car's running. If you're still having problems and all the connections are properly secured, I'll have our Lead Bama Tuner take a look at your tune to see if there's any adjustments that can be made.
I'll look forward to your response!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 01-14-2013, 02:27 PM   #11
KARgt13's Avatar
FYI, this is straight out of the manual. When you start it after this it will sound like you're bringing a dead beast back to life, just let it do it's thing because when I did it it sounded like crap for the first thirty seconds.
KARgt13 is offline   Reply With Quote
Old 01-14-2013, 02:45 PM   #12
Napoleon85's Avatar
Originally Posted by AMShaneLesky View Post
blakebrooks,
Shane
This. Pull your negative battery cable for a few then try that procedure. It's ironed out quite a few idle/stalling issues before.
Old 01-15-2013, 07:16 AM   #13
Loc: Austin,TX
Never had any issue with idle or surge after the install.
Old 01-15-2013, 04:51 PM   #14
Site Sponsor
Sponsor
AMWill's Avatar
OP,
Have you had any luck with the Idle Relearn process? I hope everything got straightened out after! Let me know if you're still having the issues and I'll get you in contact with our lead Bama tuner (Mike Wilson). If there's any adjustments that can be made to the tune, he'll be able to find it!
Shane
10:21 AM
