Rear diff breather?? - Mustang Evolution
Old 01-14-2013, 08:22 PM   #1
gtstyles2's Avatar
http://youtu.be/BomULDs1mnk
I rarely get to go underneath my car and I noticed the left side of the diff to be kinda wet and then I notice on top on the left side of the pumpkin on too there's something kinda loose. Just wondering if this is normal I never seen or knew about this... Check the vid
Old 01-14-2013, 08:56 PM   #2
Nichg's Avatar
It's totally normal and I have seen it the same on every 11 and up mustang I have seen. Did the same thing on my 12 and 13 mustang, and that part in your video that is loose is the "breather" to make sure that the diff does not pressurize and to allow for fluid/heat expansion (like a relief valve in a sense). All vehicles and equipment have similar type "breathers". As long as you check you differential fluid level and it is to spec you are all set to go.
Nichg is offline   Reply With Quote
Old 01-14-2013, 09:01 PM   #3
gtstyles2's Avatar
Kinda figured when I saw it, didn't know if it was normal to be that loose. Have 3.31 now, gonna get the 3.73 in the spring and I just wanna make sure everything is good before I get it done cuz of course once I get the new gears my diff won't be under factory warranty anymore
Old 01-14-2013, 09:04 PM   #4
Nichg's Avatar
That's good thinking! As long as your level is where it should be and your diff fluid doesn't have any silver fillings in it then your all good.
04:27 PM
