Another catch can question - Mustang Evolution
Old 01-20-2013, 12:15 AM   #1
OrganDonor's Avatar
So after reading all the other threads saying how everyone should get a catch can, that Ford should have put them on from the factory, I finally got one, after 25,000 miles on the car.
After pulling the stock tube from intake to valve cover off, I noticed both ends dry as can be. not even a drop of oil. Did any of you notice this when installing your catch can? Is it really needed?
Are you guys really getting oil out of these?
I was tempted to just put it back on and send the catch can back, then thought, what the heck, i got it, might as well put it on.
2014 Shelby GT500...
OrganDonor is offline   Reply With Quote
Old 01-20-2013, 12:48 AM   #2
1slosix's Avatar
Im pretty sure most people on here just make their own. One guys has a clear bulb on it and it does show there is oil present over time. Remember its an oil mist not so much beads.
carving corners like a boss
Old 01-20-2013, 01:28 AM   #3
I get a spoonful of oil in there every 1500 miles or so.
mmike87 is offline   Reply With Quote
Old 01-20-2013, 01:30 AM   #4
CorDog009's Avatar
Same here.
'13 Deep Impact Blue GT, auto, BBK cat deletes, GT-500 A/B's, C&L tuned DiabloSport inTune, sound tube delete, BBK 85mm TB, JLT oil separator, NX plate kit.
CorDog009 is offline   Reply With Quote
Old 01-20-2013, 10:40 AM   #5
maldog's Avatar
Region: Nevada
+1 ^
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 01-20-2013, 11:05 AM   #6
sprdave's Avatar
I made a homemade one,and couldn't beleive how much oil it catched.
sprdave is offline   Reply With Quote
Old 01-20-2013, 11:10 AM   #7
sprdave's Avatar
Old 01-20-2013, 11:24 AM   #8
OrganDonor's Avatar
Thanks for the feedback guys.. Was just curious ssince the stock tube was bone dry, and clean..
Guess if mine catches none, that would be a good thing too right?
Plus it looks good..
Old 01-20-2013, 11:24 AM   #9
Venomouz831's Avatar
Can I use this on a new edge?
)02 Gt, Founder of WE2G
Old 01-20-2013, 11:37 AM   #10
1slosix's Avatar
yep....i've been waiting to head to home depot to grab the air dryer i need to make one.
Old 01-20-2013, 11:57 AM   #11
CorDog009's Avatar
That's what I did on all my LS1 cars. Much more simple. This time I just went with the JLT since it's a direct bolt-on.
Old 01-20-2013, 12:24 PM   #12
Kool what all would I need? And what does this help in
Old 01-21-2013, 02:22 PM   #13
svilla00's Avatar
it definitely does what its suppose to. I can show you what it looks like when i get home. Mine should have a decent amount in it.
svilla00 is offline   Reply With Quote
Old 01-21-2013, 02:34 PM   #14
NewMtang's Avatar
Having two left thumbs, I purchased one from AMERICAN MUSCLE (Thanks Dan). I put it on at 535 miles and cleaned it at 1,038.4 miles (503.4 miles). I had less than 1/8" of oil in it.
I then went from 1,038.4 miles till I had 1,280.6 (242.2 miles). Found less oil this time.
Old 01-22-2013, 09:49 AM   #15
Site Sponsor
Sponsor
AMWill's Avatar
OrganDonor,
If it's not catching anything, it just means you have minimum blow-by (good thing). However, pressure has to build up at some point, so it's still worth having. Let us know what it looks like after a 1k miles or longer!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 01-29-2013, 05:09 PM   #16
svilla00's Avatar
Here's mine after 4,000 miles. It definitely catches stuff from my engine.
Old 01-29-2013, 05:18 PM   #17
GE3G's Avatar
Happen when you Constantly reving high
GE3G is offline   Reply With Quote
Old 01-29-2013, 06:26 PM   #18
gtstyles2's Avatar
Is that milky looking?
Old 01-29-2013, 06:34 PM   #19
svilla00's Avatar
Yea, but it was also 2 degrees outside. It's normally more brownish.
Old 01-29-2013, 07:15 PM   #20
gtstyles2's Avatar
That doesn't look normal, I never seen that in mine, there's definitely moisture in the crankcase. How many miles? And when was your last oil change??
Old 01-29-2013, 07:18 PM   #21
svilla00's Avatar
Car only has 6,000 miles. Last oil change was at 4,000. Fuel combustion produces a large amount of water vapor. All engines, even brand new, have blow-by to some extent. That's why they all have Positive Crankcase Ventilation. The oil fill neck can stay cool a long time in cold weather, making the perfect place for condensation to form.
Old 01-29-2013, 07:51 PM   #22
gtstyles2's Avatar
Definitely keep your eye on that, I only have 8,800 miles on my 11. I used to burn a pretty substantial amount of oil within my 1st 5,000 miles but that's a thing of the past now and I'm solid now, with very little blow-by buildup but I never looked milky like that
Old 01-29-2013, 07:57 PM   #23
svilla00's Avatar
I'll keep an eye on it, but before it was winter it was normal colored. I have a feeling its just the cold weather and me not letting the car warm up long enough before driving it.
Old 01-29-2013, 08:14 PM   #24
gtstyles2's Avatar
U should take a look under your oil cap, and check your oil, the cold might have a slight effect but it's best to nip it in the bud before its a more serious problem later
Old 01-29-2013, 08:15 PM   #25
svilla00's Avatar
Will do, thanks for the help!
Old 03-26-2013, 01:40 AM   #26
OrganDonor's Avatar
I never would have believed it if I hadn't seen it myself. I have never had to add oil between oil changes, check oil every week and has never been low.
After 2 months having this catch can, I opened it up to see if there was any oil in it. I thought for sure it would be dry, but nope, about 1/4 cup came running out the tube.
I honestly thought it was going to be a visual mod under the hood, but I am a believer in this now..
Thanks to every one who said this was a very smart mod...
Old 03-26-2013, 03:54 AM   #27
bucko's Avatar
Originally Posted by maldog View Post
+1 ^
And another +1
Old 03-26-2013, 09:21 AM   #28
Wilhelm0075's Avatar
Region: Nevada
I just purchased an installed the JLT passenger side one and am curious how much oil I'll see. Do people do the driver side as well? I see they now sell both sides, but wasn't sure if that's overkill
Wilhelm0075 is offline   Reply With Quote
Old 03-26-2013, 03:26 PM   #29
Grabber Blue5.0's Avatar
Another option are breathers.
Name:	JPC Breathers.jpg
Old 03-26-2013, 06:56 PM   #30
I was thinking of doing breathers as well. I've done it in the past with prior cars with no issues. Anybody else done breathers as opposed to forking up the coin for catch cans?
BTW. I dig the painted intake tube.
---------- Post added at 08:56 PM ---------- Previous post was at 08:52 PM ----------
I was thinking of trying breathers as well. I've done it in the past with prior cars. Anybody else doing this as opposed to forking over the coin for catch cans?
BTW. I dig the painted intake tube and the breathers look better to me than catch cans. Any issues with them?
WCatoe is offline   Reply With Quote
Old 03-26-2013, 07:06 PM   #31
nosympathy's Avatar
Where do you get those at? Quick google search and I am not finding them
Old 03-27-2013, 03:44 AM   #32
2011+ GT/Boss Breather Package - Justin's Performance Center
You could probably put your own kit together for a little less money but this kit is pretty nice and it's a 5-10 minute install. No issues with them.
Old 03-27-2013, 06:13 AM   #33
Tpost08's Avatar
So it does the same as the catch can. Just cheaper? Because I've been looking at the catch can and trying to decide if I was going to get it. But this for half the price, would be ideal if its the same thing.
Tpost08 is offline   Reply With Quote
Old 03-27-2013, 09:06 AM   #34
nosympathy's Avatar
Well reading around online I am not so sure about them. Eliminates the PCV system and isn't technically emissions legal. Which I could care less about. Also allows unmetered air into the crank case which can cause poor performance. There are a lotta people saying don't use them on the newer engines.
Old 03-27-2013, 11:26 AM   #35
Joey8's Avatar
I'm thinking about getting the bobs oil separator. At of you guys have tips for install. I'm really not the most engine savvy guy so some detailed info would be great. Also if I buy the separator from bobs does it come with all the parts needed for install? Bc I see you can order standard 2 or 4 clamps on the website. Thanks.
2014 Sterling Gray GT (Ordered1/24) (Built2/25) (ETA3/12) (Picked Up 3/21)l 443.9/417.8 l
l l 6 Spd l Prem Pkg l Nav l TP l LthrRecaros l AmericanRacing 1 7/8 LTs l O/R H l JLT CF CAI lVMP Tuned l BorlaS Quads w/ResDel. l GT500Valance l KoniStr.T l K-Springs l GT500 Mounts l BMR UCA&LCA l BMR Relos l BMR Panhard l SpeedDawg Knob l 5.0 LloydsMats l Redline HoodStrts l Bobs CF Oil Sep. l 15% Tint l CDC Grille l StrtScn2 ChinSpoiler l GT/CS Fogs w/4500k l RTR DeckLid l CF Engine/CoilCoversl
Joey8 is offline   Reply With Quote
05:28 AM
