Failed Roush Splitter install - Mustang Evolution
Old 01-21-2013, 05:53 PM   #1
Mechanically, this is very simple. But I will be damned if I could get my lowered car high enough to get the drill under the rocker panels.
I tried everything ... ramps not high enough, stands not high enough, etc. Finally gave up and I'll pay someone to do this simple install just because it's ticked me off.
AND I have a short drill, too ... just not enough room with a drill bit in there to get under the rocker panel.
Silly to have to abort a simple install for a reason like this.
mmike87 is offline   Reply With Quote
Old 01-21-2013, 06:03 PM   #2
KARgt13's Avatar
Try boards under the stands? Only thing I can think of.
KARgt13 is offline   Reply With Quote
Old 01-21-2013, 06:05 PM   #3
avengnd's Avatar
I feel your pain, I just jacked one side up and drilled quickly then let it down, then moved to the other side (the rear as well). It sucks but it worked. i jacked it up high enough for my drill to get under it.
~ Alan Mustang Livin' and www.mustanglivin.com
2014 Shelby GT500
avengnd is offline   Reply With Quote
Old 01-21-2013, 06:09 PM   #4
I went as high as the jackstands would go - wife refuses to let me under the car in any way if it's not on ramps or stands.
Old 01-21-2013, 06:11 PM   #5
maldog's Avatar
Region: Nevada
Good attempt at it, but sometimes it's better to have somebody else do it.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 01-21-2013, 06:12 PM   #6
IanM's Avatar
I've got a low-profile racing jack, I jacked the car up by the rear suspension mount point and placed a jack-stand there, then jacked up the front end of the car.... with that I was able to get the car plenty high to get my drill under it and drill with no problem. I installed the splitters into the stock locations before drilling the additional holes, and just didn't push the clips all the way in, leaving maybe a 1/4 inch out. Once I got them all in, I drilled the final holes, put the fasteners in, pulled off the tape for the adhesive, and pushed the rest of the clips all the way in. I watched this video a few times also...thought it might be helpful.
2011 Grabber Blue GT California Special, 3.73 Gears, 6-Speed Manual, Steeda CAI, Steeda 93 tune, aluminum driveshaft (The Driveshaft Shop Co.), MGW shifter, Roush axle-back exhaust, Roush Side Rocker Panel Splitters, Ford Racing BOSS 302 front splitter, sound-tube delete, painted plug covers, JLT oil separator. Shelby transmission scoop & powder-coated trunk brace & many more items...
IanM is offline   Reply With Quote
Old 01-21-2013, 06:13 PM   #7
avengnd's Avatar
I didn't use stands just the floor jack.
2014 Shelby GT500
Old 01-21-2013, 06:18 PM   #8
Using just the floor jack, what did you use as jack points?
I have the harbor freight low profile racing jack.
Old 01-21-2013, 06:24 PM   #9
IanM's Avatar
Yep, that's what I use too, i've got the aluminum 2 ton jack from Harbor Freight... might be the same one. I use the rear lower control arm mount, and put the jack stand under the control arm since it's nearly level when i get it jacked up. For the front, I use the front control arm mount points, being careful not to touch the bushings at all, just under the front of the the foot-well area.
Old 01-21-2013, 06:25 PM   #10
avengnd's Avatar
Check out this thread...the pic shows two blue arrows, those are the spots I used.
Lift / Jack Points
2014 Shelby GT500
Old 01-21-2013, 06:26 PM   #11
If I have relo brackets will I be able to put a jack there in the rear?
Old 01-21-2013, 06:32 PM   #12
alrefire's Avatar
maybe you could jack up only one side of the car. start by jacking up the rear, put a jackstand on the right or left side, then jack up the corresponding side in the front, and put a stand on that.
you could get under there, drill your holes, and get out.
just don't keep it too long
Old 01-21-2013, 06:44 PM   #13
Problem was with the stands fully extended, the car was still too low for the drill. Not much, but too low.
Old 01-21-2013, 06:46 PM   #14
IanM's Avatar
That's what I did, worked fine.
Always use jack stands, no matter what. I have 2 sturdy sets in staggered heights, just in case I need more than 2, or a shorter/taller option.
NEVER EVER TRUST A JACK... I wouldn't bet my life on a jack. One of my brothers had a car fall on him, he was ok, but got VERY lucky while working on an exhaust issue on his car. Since then, i've always been sure to use them, and have a phone where I can reach it in the event of an emergency (if working alone).
Old 01-21-2013, 06:49 PM   #15
McQueen's Avatar
That is why i did my full roush kit before doing suspension lol.
I used a dremel drill.
Make your own ramps from wood.
McQueen is offline   Reply With Quote
Old 01-21-2013, 06:50 PM   #16
McQueen's Avatar
Go as high as you want!
Old 01-21-2013, 07:02 PM   #17
alrefire's Avatar
Funny story
I ordered 2 jacks
4 came in
I got lucky
Old 01-21-2013, 07:04 PM   #18
avengnd's Avatar
Funny story
I ordered 2 jacks
4 came in
I got lucky
Sweet deal.
2014 Shelby GT500
Old 01-21-2013, 07:19 PM   #19
Thomas11CS5.0's Avatar
Two ways to do this you can cut the drill bit down to make your drill shorter or put a 6x6 block on top of you jack and some boards or blocks under jack stands to make them taller
Thomas11CS5.0 is offline   Reply With Quote
Old 01-21-2013, 07:28 PM   #20
alrefire's Avatar
Just a random question, wouldn't that possibly snap the boards?
Old 01-21-2013, 08:02 PM   #21
Nope, if it works with my almost 6000 pound truck it should work for a Mustang.
Old 01-21-2013, 08:50 PM   #22
Maverick2004054's Avatar
I built something like this after I lowered my car, looks almost identical and worked like a charm installing my splitters!
Maverick2004054 is offline   Reply With Quote
Old 01-21-2013, 10:11 PM   #23
torch1's Avatar
Another easy option is to get a set of 6 ton jack stands. Makes it really easy to get under the car.
torch1 is offline   Reply With Quote
Old 01-21-2013, 10:42 PM   #24
UltArc's Avatar
Foundation blocks. If they can support my house, they can support my car.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 01-22-2013, 12:12 AM   #25
tc x 4's Avatar
They will support a car, but if you put them on there sides, you run the risk of it crushing you.
Old 01-22-2013, 12:23 AM   #26
UltArc's Avatar
Originally Posted by tc x 4
They will support a car, but if you put them on there sides, you run the risk of them crushing you.
I don't understand what you mean. How would the bricks crush me?
Old 01-22-2013, 12:38 AM   #27
tc x 4's Avatar
Lol, not the blocks, the car. If your not using a solid block, the holes need to be vertically, not horizontal. They don't have much strength on there sides.
Old 01-22-2013, 12:39 AM   #28
UltArc's Avatar
Ah! I got solid blocks. So no worries
Old 01-22-2013, 12:39 AM   #29
tc x 4's Avatar
I see where you got that now. Lol
Old 01-22-2013, 11:25 PM   #30
etc1006's Avatar
Right angle adapter for your drill. You're only drilling plastic.
http://www.harborfreight.com/3-8-eig...uck-92188.html
etc1006 is offline   Reply With Quote
Old 01-23-2013, 09:50 PM   #31
GE3G's Avatar
I backed my stang up on a set of ramps that came with my grandfathers 1989 toyota supra and my 16yr old cousin instaled them for me at 1am in the morning... We fit the drill no problem and im lowerd.... He had no problems.. When we drilled the fron I drove up on some stacked 2x6s...little guy did a wicked job... I let him drive my stang for his services kept it in 2nd gear thats it
GE3G is offline   Reply With Quote
Old 01-24-2013, 04:42 AM   #32
3/8" Angle Drill Attachment with Keyless Chuck
Yeah, that's exactly what I need. Thanks.
Old 01-24-2013, 10:48 PM   #33
etc1006's Avatar
Old 01-27-2013, 02:37 PM   #34
Done and done.
What a difference a week makes. Annoyed that I didn't see it last week, but it's done now.
Drive one side up one some 2x4's to give it a slight lift ...
I realized that I COULD slide the Harbor Freight low profile jack under the differential housing .... put a block of wood on the foot and jacked up the rear, slid my ramp under the wheel, jacked the front and did the same.
The body settles too much with stands on the axles, and by using the ramps it worked much better. It was so simple I feel like an idiot ...
Install was smooth except one push pin will not go in all the way - it's out about 1/16" of an inch or so. They are single use only, so I can't pull it out and I tried to tap it in with the dowel and a mallet to no avail.
I will need to get a replacement plug and yank it out ... but it's not going anywhere so I am not going to lose sleep over it.
Come on Roush - you couldn't include 1 or 2 extra cheap-o plastic plugs in the box?
Old 02-03-2013, 06:23 AM   #35
OzzyLiriano's Avatar
Done and done.
I just did it yesterday, dude it was mad easy i lifted it with the car lifter lol
OzzyLiriano is offline   Reply With Quote
04:30 PM
