Question about SCs - Mustang Evolution
Old 01-28-2013, 05:35 AM   #1
Question about SCs
What is the base level PSI on PDs and centri's and what is an estimate on the RWHP for those systems at that psi. Also do they come with BAPs?
2012 6 speed GT with a 8psi Hellion Single Turbo Kit tuned by BBR, GFB Geforce II controller, ID1000 injectors, BAP, GT500 Mufflers no cats, MGW shifter, Dual Aeroforce Interceptor gauges and AMR Wheels. BMR upper control arm and bracket, Whiteline panhard brace, BBR LCA's and Panhard Bar. 552/597 at 7.8 psi
6SpeedFreak is offline   Reply With Quote
Old 01-28-2013, 07:01 AM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Depends on the size... I thought you were in love with your turbo setup
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 01-28-2013, 07:19 AM   #3
McQueen's Avatar
Vortech at 6.5psi with boss manifold made a whooping 610 or so whp.
McQueen is offline   Reply With Quote
Old 01-28-2013, 07:25 AM   #4
I am in love with my turbo..I just want some comparisons...I think im going to turn up my psi...I was just curious as to what the others systems came with at a base level...Just wanting to compare to them...Right now I don't have a BAP and tuner says need more fuel for him to turn it up any and feel safe...But My turbo is awesome and I would recommend to anyone...my MPG went up 5mpg on road trips...it is super awesome!!!!!
---------- Post added at 09:25 AM ---------- Previous post was at 09:23 AM ----------
Was that with Headers? Cats? BAP? was it SAE? Mustang or Dynojet? also what was the TQ?
Old 01-28-2013, 07:30 AM   #5
Could you post the graph?
Old 01-28-2013, 07:32 AM   #6
McQueen's Avatar
It was done by AM on a white stang gt/cs.
http://blog.americanmuscle.com/video...s-up-our-dyno/
Old 01-28-2013, 07:45 AM   #7
The Blue Dragon
Exactly my point when I said it depends on setup... You need to ask a more specific question if you want a more specific answer
Old 01-28-2013, 07:57 AM   #8
The Blue Dragon
Now to give you a vague answer, most full entry level kits will get 6-7 psi and will not come with a BAP
Old 01-28-2013, 08:05 AM   #9
ok wonderfull now all I want to know is the HP and TQ that you will get with that and the stock calibration SAE
Old 01-28-2013, 08:08 AM   #10
Paxton base tuner kit, ID1000 injectors, Vortech boost referenced BAP, Boss intake, stock airbox, lethal o/r H pipe, GT500 axlebacks, No headers. 622rwhp/466rwtq STD in 95 degree heat. 8psi
2012 black base 6MT, 3.73s, Steeda shifter, Rev auto CAI, stage 3 comp cams, Cobra jet intake, CJ monoblade TB, JBA long tubes o/r h pipe, GT500 AB, tuned by AED
KalEl370 is offline   Reply With Quote
Old 01-28-2013, 11:54 AM   #11
Thanks for the graph....BBR told me I need a BAP and the ID1000s before they feel safe turning up the power on my car. Was just curious as to what others were seeing...I have a very conservative tune and put down 499/538 STD but the tuner at the dyno said I was about .5 rich and could use a bit more timing. I guess I will go ahead and order the BAP and ID1000s and see what it will do. Im on 6 psi may go up to 10 when I add the other items.
Old 01-28-2013, 12:01 PM   #12
The Blue Dragon
The 47 lb injectors are good up to 600 hp, and unless you really plan on turning up the power I would just buy the ID 750's. save some money, those are good far past 600 rwhp.
what I hear you saying is that BBR is just trying to cover their ***. Mostly
Old 01-28-2013, 12:07 PM   #13
I think they just don't want to take a chance with a mail order tune. The dyno and tuner I went to was a local guy and he said it was a very safe tune...They are playing the safe side and I totally agreee with them,...I figure the ID1000s are what I will go with just in case I ever change to the larger turbo and want some serious power. Boost is addictive to say the least!
10:07 AM
