Suspension information - Mustang Evolution
Old 01-28-2013, 05:58 PM   #1
redbeast0712's Avatar
Region: Nevada
I have had mustangs for years but I have never done anything to suspension to any of them. I want to learn about suspension and what are some options. I currently have a 2013 that I plan on keeping for awhile and I would to do some suspension upgrades. The first thing I would like to do is get wheels and tires then go all out suspension then supercharge for the last thing. I still want a comfortable ride so I don't want to lower all that much. So what are some of your opinions?
redbeast0712 is offline   Reply With Quote
Old 01-28-2013, 07:03 PM   #2
TommyV's Avatar
One of the best combos is the Koni STR.T's and Steda Sport springs. Lowers it between 1in. and 1.5 in. Handling is greatly improved with much less nose dive when braking. I like my RTR wheels and Nitto tires, but there are many great combos out there.
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 01-28-2013, 07:37 PM   #3
Region: Nevada
Thanks ill take a look at that.
Old 01-28-2013, 07:58 PM   #4
nosympathy's Avatar
You are going to want to look into lower control arms, relocation brackets for the LCA if you lower the car, upper control arms, panhard bar.
I am all for the Koni Str.t too. I have them coming in tomorrow from AM myself.
Old 01-28-2013, 08:24 PM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
I agree 100% with nosympathy, lcas, uca, relo brackets. If you want to keep a smooth ride, Koni STR.T is the way to go. These will make your car feel and handle the way it should have from the factory.
Also look into some beefy sway bars like eibach, those will get rid of some of the chassis flex and give you that "car rides on rails" feeling
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 01-28-2013, 08:28 PM   #6
Region: Nevada
Thanks for all the options is of this hard to install. I would like to learn it myself.
Old 01-28-2013, 08:50 PM   #7
The Blue Dragon
It's time consuming but not hard if you have any sort of mechanical inclination
Old 01-28-2013, 09:19 PM   #8
svilla00's Avatar
Could you link to them on AM? I could only find the 05-10 version on AM?
svilla00 is offline   Reply With Quote
Old 01-28-2013, 09:37 PM   #9
Region: Nevada
Yeah I'm sure I could do it I've been able to do my own work. It doesn't look to hard but just thought I would ask. Do I need any special tools?
Old 01-29-2013, 04:31 AM   #10
nosympathy's Avatar
Those are the right ones. Paired with the correct strut mounts they fit our cars just fine
Old 01-29-2013, 04:37 AM   #11
The Blue Dragon
Spring compressor
Old 01-29-2013, 05:12 AM   #12
svilla00's Avatar
So just the gt500 strut mounts and I'm good to go?
Old 01-29-2013, 06:34 AM   #13
KARgt13's Avatar
Since we are all learning here, any difference between getting the 05-10 shocks/struts vs. 11-13? And if you go 11-13, what strut mounts can you get that work since the gt500 don't?
KARgt13 is offline   Reply With Quote
Old 01-29-2013, 08:58 AM   #14
The Blue Dragon
Those no mechanical advantage to having 05-10 vs 11-13
Old 01-29-2013, 09:11 AM   #15
Redstang1's Avatar
Spring compressor
I didn't need a spring compressor, just needed a friend to push down on my after market ones. The stock springs do come out with force though but the don't break anything so it's all good
Redstang1 is offline   Reply With Quote
Old 01-29-2013, 09:16 AM   #16
KARgt13's Avatar
Thank you, I've been wondering and probably buying Eibach Pro-kit with shocks/struts in the very near future.
Old 01-29-2013, 11:42 AM   #17
nosympathy's Avatar
Depends. Which springs? If your a 1-1.5" drop or less then yea GT500 strut mounts. Anymore more and consider caster camber plates.
Old 01-29-2013, 01:37 PM   #18
Redstang1's Avatar
If you want to se the gt500 mounts you have to buy the ford racing struts. They don't work with stock or eibach struts. So I was told
Old 01-29-2013, 02:02 PM   #19
KARgt13's Avatar
05-10 springs able to be used on 11-13? If so you can just buy a 05-10 kit and get gt500 mounts.
Old 01-29-2013, 02:19 PM   #20
gtstyles2's Avatar
Yup GT500 strut mounts will not fit Eibach springs... I learned the hard way
Old 01-29-2013, 02:21 PM   #21
The Blue Dragon
The GT500 strut mounts are designed to be used with the 05-10 style struts
Old 01-29-2013, 02:38 PM   #22
gtstyles2's Avatar
Since I had to reuse my factory mounts I noticed a clunk on the right side at first, now I don't notice it anymore, I think I'm good for now... If it comes back I'm assuming my only choices for mounts are probably Maximum Motorsport or Steeda?? Unless a newer, more affordable solution to the current GT500 style that'll fit ours
Old 01-29-2013, 03:11 PM   #23
svilla00's Avatar
Well I pulled the trigger today and went with the following:
This is for a 13 GT with brembo package:
05-10 Koni Str.t's shock/struts
Steeda Ultralite Springs
05-13 Gt500 mounts
Bmr lca's
Bmr lca reloc brackets
Bmr pan hard
05-13 FR jounce bumper kit
Does what I have work or did I screw up in my research?
Old 01-29-2013, 03:13 PM   #24
nosympathy's Avatar
05-13 Gt500 mounts
Bmr lca's
Bmr pan hard
Looks good. Might want to pickup a UCA at some point too.
Old 01-29-2013, 03:15 PM   #25
05-13 Gt500 mounts
Bmr lca's
Bmr pan hard
And camber bolts 25$. Or instead of buying new bumpstops you can cut the top of the stockers
JayblesStang is offline   Reply With Quote
Old 01-29-2013, 03:18 PM   #26
svilla00's Avatar
It's on my list, it was out of stock when I went to buy it today. Thanks for your help
---------- Post added at 05:18 PM ---------- Previous post was at 05:17 PM ----------
I will pick up some camber bolts just not sure how to use them lol.
Old 01-29-2013, 03:20 PM   #27
The Blue Dragon
05-13 Gt500 mounts
Bmr lca's
Bmr pan hard
Sounds like you made the right choices
Old 01-29-2013, 03:37 PM   #28
svilla00's Avatar
Great! I was worrying all day if I bought all the right parts. Didn't want to make another suspension thread and get yelled at for not using the search function :p.
09:50 PM
